usair330
Scanners Allowed On Flights?
Thu Mar 10, 2005 5:53 am
Hey Ima be flying to PNS this Sunday and would like to take my scanner with me....It's a Maycom AR-108. Is it legal to take the scanner on the flight with you and listen?
Thanx
Sorry if this question has been asked before. I did a search and couldn't find anything.
KDTWflyer
RE: Scanners Allowed On Flights?
Thu Mar 10, 2005 6:00 am
As far as I know it is. I would be discrete using it though. I used my Radio Shack on a NW B744 from DTW-AMS and it was sweet! I heard Cleveland ARTCC give a turn command and heard it acknowledged by the crew and sure enough, about a second and a half later we commenced the turn!
NW B744 B742 B753 B752 A333 A332 A320 A319 DC10 DC9 ARJ CRJ S340
Newark777
Thu Mar 10, 2005 6:01 am
I'm pretty sure you can bring it with you, as I have never had any problems with it. As for listening in flight, not sure, but I do it sometimes, also without a problem. Just make sure to know the scanner laws of the place you are traveling before you go, especially places overseas. Some states have pretty strict laws also.
Harry
1MillionFlyer
Thu Mar 10, 2005 6:04 am
US airlines prohibit the use of radios on the aircraft during flight....this is not a good idea. If you bring it with you leave it off during flight.
Beleive me I would love to bring one on the plane so I knew what was going on more quickly during the flight.
Golf Foxtrot you are cleared for departure
jonty
Thu Mar 10, 2005 6:12 am
why are you not allowed to use them inflight 1MillionFlyer?
1MillionFlyer
Thu Mar 10, 2005 6:17 am
radios (scanners) absolutley can interfere with navigation (ILS/LOC/VOR) and communication channels, using a GPS or a cell phone is fine, but radios are a no-no
skywatch
Thu Mar 10, 2005 6:44 am
How could a scanner interfere if you are picking up the same frequencies? I have wondered over whether you could take scanners onto commercial flights or not, and I could not see a reason why you could not, unless they think you can hide a bomb in the battery compartment or something!
------Forever Watchin' The Sky------
1MillionFlyer
Thu Mar 10, 2005 6:58 am
anything that is receiving the spectrum of bandwidth of the navigation and communications radios can interfere with reception.
they are also banned for use on US aircraft per "FAR 91.21"
except:
Except as provided in paragraph (b) of this section, no person may operate, nor may any operator or pilot in command of an aircraft allow the operation of, any portable electronic device on any of the following U.S.-registered civil aircraft:
(1) Aircraft operated by a holder of an air carrier operating certificate or an operating certificate; or
(2) Any other aircraft while it is operated under IFR.
(b) Paragraph (a) of this section does not apply to--
(1)Portable voice recorders;
(2)Hearing aids;
(3)Heart pacemakers;
(4)Electric shavers; or
(5)Any other portable electronic device that the operator of the aircraft has determined will not cause interference with the navigation or communication system of the aircraft on which it is to be used.
(c) In the case of an aircraft operated by the holder of an air carrier operating certificate or an operating certificate, the determination required by paragraph (b)(5) of this section shall be made by that operator of the aircraft on which the particular device is to be used. In the case of other aircraft, the determination may be made by the pilot in command or other operator of the aircraft.
this is a great article on the topic
http://www.rvs.uni-bielefeld.de/publ...DOCS/Research/Rvs/Article/EMI.html
[Edited 2005-03-09 23:00:09]
BritPilot777
Thu Mar 10, 2005 7:13 am
Just go United and use Channel 9  Silly
Moheet  Cool
Forever Flight
EMBQA
Thu Mar 10, 2005 7:16 am
So, after reading the FAR's the answer is No. Keep in mind that at the end of the passanger breifing is the standard statement "...a complete list of approved eletronic devices can be found in the back of your in-flight magazine found in the seat pocket in front of you..."
venuscat2
Thu Mar 10, 2005 7:18 am
Quoting KDTWFlyer (Reply 1):
You're pretty lucky that nobody saw it....and that you didn't cause any serious problem.. You could get in BIG trouble for operating a scanner onboard.
neilalp
Thu Mar 10, 2005 8:07 am
Quoting Venuscat2 (Reply 10):
I don't think you would get in BIG trouble. The FA most likely would ask you to turn it off. But this has been discussed many many times.
I'm not sure what you searched but a simple "Scanner onboard" you come up with tons of results....
http://www.airliners.net/discussions...er+onboard&search_order=idorder=id
flysc
Thu Mar 10, 2005 8:19 am
I have taken a scanner on commerical flights several times. They have never said anything to me about it at securtiy. I have yet to actually use it in flight though. It is illegal to use them in flight but as you can see some people are able to get away with it. I didn't feel like risking it and usually entertain myself by looking out the window.
Fly Safely,
Jason D.
I do not fail!!! I succede at finding what does not work!!!
lincoln
Thu Mar 10, 2005 11:56 am
Quoting Neilalp (Reply 11):
Pre 9/11 I would agree with you whole heartedly -- likely: the FA would request you discontinue use and if you didn't comply the police may or may not be waiting for you when you landed (and you may or may not land at the airport you had planned on landing at), depending on the mood of the FA.
Post 9/11 with everyone so anxious about terrorists I think more than a few pax may consider it highly suspicious and possibly take matters in to their own hands if they saw someone trying to use a scanner -- especially after the "no radios or cellphones" annoucement during the safety briefing. The police would probably be waiting for you when you landed.
If you do choose to use it in flight (I strongly suggest that you not), make sure you are extremely discrete about it, and of course use an earphoneSmile. Best cause of action, especially if you're not sure if the carrier allows or disallows the use is just talk to the FA when your boarding...worst they can say is "No", and this would make you a heck of a lot less suspicious.
As others have said, in general if you're told that you aren't alowed to do something on an airplane, there is probably a good reason for it (in this case interference with communication and navigation systems) and you probably shouldn't do it even if you don't get cought.
Lincoln
[Edited 2005-03-10 04:28:16]
Fly2HMO
Thu Mar 10, 2005 12:07 pm
Been there, done that. Just keep a low profile and you should be good.  mischievous
1MillionFlyer
Thu Mar 10, 2005 12:18 pm
Quoting FLY2HMO (Reply 14):
I don't mean to be negative, but isn't it just a little selfish to potentially jeoporidize the aircraft so you can listen to ATC?
OPNLguy
Thu Mar 10, 2005 12:19 pm
Although others have posted that they have "gotten away with it" another factor that you may want to consider is your desired future career (as mentioned in your profile) in law enforcement.
On the chance (however remote) that you get caught/arrested/charged or whatever, wouldn't a record preclude your being a police officer? Is it worth the risk, just to listen to a scanner?
[Edited 2005-03-10 04:22:44]
usair330
Thu Mar 10, 2005 2:24 pm
After reading all your comments (especially OPNLguy) I think that I'll take it with me but ask the flight attendant if it would be ok if I use it .... If she says no... than I will definitely put it away and not even think about taking out....
Thanks for the help guys!!! ... Only at Airliners.net  smirk
