bkkair
CA 744, Goes Off Taxiway At LAX Enroute To PEK
Mon Mar 14, 2005 2:21 am
Air China 744 hit a soft spot off the taxiway at LAX enroute to PEK and got stuck at 0155 Sunday. The 330 people aboard were taken off the plane, the fuel removed to make it lighter however it seems the 744 is still stuck.
I haven't found any pictures of this yet.
http://www.mercurynews.com/mld/mercu...a/northern_california/11126946.htm
NYCA330
RE: CA 744, Goes Off Taxiway At LAX Enroute To PEK
Mon Mar 14, 2005 2:47 am
They just showed video of it on CNN.
brink777
Mon Mar 14, 2005 4:34 am
Any photo links yet?
tundra767
Mon Mar 14, 2005 5:22 am
Funny, I was at LAX this morning about 1am and watched it push back from the gate.Was thinking to my self " Geez they have a long way to go tonight." I must have just missed it.
tundra767
Mon Mar 14, 2005 8:14 am
Just back from LAX. The Air China plane is still there its now parked over were the old TWA Air Freight building was.
boeingatl
Mon Mar 14, 2005 8:46 am
I'm in LA now. Saw the plane right off aviation avenue, fire trucks and stuff all around. And no camera. According to local news it made a wrong turn and it's right gear got stuck in 3 ft of soft asphalt. It has now been moved, but is behind a building so no photo op. But have to say, it's livery was pretty dirty looking.
boeingATL
lightsaber
Crew
Mon Mar 14, 2005 11:34 am
The weather was perfect today, so the pilot will really have to dig for excuses.  duck
Lightsaber
ltbewr
Mon Mar 14, 2005 11:55 am
According to later afternoon news reports, the airport emergency services placed wire mats under and behind the affected landing gear on the soft taxiway area and used tugs to pull the a/c out of the problem area.
It will be interesting to find out what happened. As was the beginning of the flight, the pilot wouldn't be tired, like at the end of the flight. Perhaps the pilot was given some bad taxing directions or they misunderstood the taxing directions.
mfamguy79
Mon Mar 14, 2005 12:16 pm
Interesting as I saw this plane land from Beijing yesterday afternoon!! Who would have guessed that it would have ended up in this mess!
Naveen
jumbojet
Mon Mar 14, 2005 12:43 pm
its not like they have a spare 747 lying around, so what does the airline do? Stick them up in a hotel and rent one?  Smile
1MillionFlyer
Mon Mar 14, 2005 12:53 pm
I was there last night, but I missed seeing that Sad
I saw it on KTLA news earlier when there towed it out. Glad it wasn't damaged
Golf Foxtrot you are cleared for departure
CCA
Mon Mar 14, 2005 1:27 pm
P1 in A330, A340, A346, B742, B744, B748.
legacyins
Mon Mar 14, 2005 1:37 pm
I can only imagine the flight crew had no idea what happened when their aircraft hit the " soft spot". I am assuming they tried to get loose from the area by increasing the engines? I wonder how much time went by before they said " LAX, we have a problem"?  Smile
Lockheed1011
Mon Mar 14, 2005 2:28 pm
CCA,
Thank you so........ much for the pictures!
Arnaldo
lincoln
Mon Mar 14, 2005 2:50 pm
Quoting CCA (Reply 11):
Here are some pics.
http://www.jetphotos.net/viewphoto.p...35784
Is it just me or does it look like someone had painted "Caution" (with part of the o and the n covered by a patch) on the asphalt right behind the rear tire... if only it had been a tiny bit larger...
Lincoln
DAL7e7
Mon Mar 14, 2005 3:01 pm
From that angle, it doesn't look like that much of a problem.
Trey in TVI
DAL7e7 is wondering... Do pilots take crash courses?
lincoln
Mon Mar 14, 2005 3:16 pm
Just saw it on the local LA FOX 10:00 news (KTTV-TV) -- all pax were bussed to a hotel at about 5:00, the tires were replaced, and it departed this evening. Also noted that the geer had gone "1 to 3 feet into the ground"
Aparently several pax were concerned about using the same aircraft and they went out with 27 pax fewer than were boarded the first time around. (The pax that FOX was interviewing were told that it was a "mechanical problem" and didn't find out until the reporter told them what the real issue was)
Lincoln
