Avianca
CO From IAH To FRA?
Wed Mar 23, 2005 7:02 am
when will CO reopen the IAH route from FRA again? Without a problem they could fill up B767-400 on the route, but for beginning it woul be better to use the B767-200. There are enough passengers for the route in special including the transferpax to LatinAmerica and Cargo.
Any chance to get the flight 2006?
regards
Avianca
Cory6188
RE: CO From IAH To FRA?
Wed Mar 23, 2005 7:05 am
I would bet that CO would love to have the route, but they simply don't have enough widebodies to start it. As it is, they are stretching their widebody fleet as much as possible, and they are sending many more 752s over the Atlantic. Even EWR-LGW has one!
Newark777
Wed Mar 23, 2005 7:08 am
It doesn't help either with that 777 out with the tail strike.
Harry
Sabena332
Quoting Avianca (Thread starter):
Did they already fly FRA-IAH in the past? What equipment did they use? Sorry but somehow I never heard about these flights.
I agree that they could easily fill up a 762/764 on this route, currently they are expanding very quick, maybe FRA-IAH is on the plan for next year.
Patrick
ConcordeBoy
Wed Mar 23, 2005 7:10 am
That, and IAH-MAD would be another winner no doubt.
Newark777
Wed Mar 23, 2005 7:13 am
Quoting ConcordeBoy (Reply 4):
That's probably why they fly it already, CO 62/63.  Wink
Harry
Sabena332
Wed Mar 23, 2005 7:15 am
Quoting Newark777 (Reply 5):
These flights are IAH-EWR-MAD v.v. and not nonstop if I remeber correct.
Patrick
Avianca
Quoting Sabena332 (Reply 3):
I am checking this, after your question I am also not more 100% sure. I know 100% that they operated DUS-EWR and MUC-EWR in the past....
Let me check the issue with the FRA-IAH flight...
regards
Newark777
Wed Mar 23, 2005 7:16 am
Quoting Sabena332 (Reply 6):
Ok, just checked again, I stand corrected.  Sad
Harry
Avianca
Wed Mar 23, 2005 7:18 am
also the FRA flight in the moment is FRA-EWR-IAH with same flight number, but mostly with aircraft change in EWR.
Sabena332
Wed Mar 23, 2005 7:22 am
Quoting Avianca (Reply 7):
Too bad that they quit DUS-EWR, CO was well known for a great variety of aircraft types in DUS. They sent the DC-10, the 764, the 762 and also the 752.
Patrick
CALMSP
Wed Mar 23, 2005 4:06 pm
actually the 75 ewr-lgw is only an additional flt
fraT
Wed Mar 23, 2005 5:08 pm
Without additional 767s or 777s we won't see service from FRA or MAD to IAH. All aircrafts will be needed for the new routes to China and LOS.
So my only hope is that the oil prices will go down and CO will be able to get some more widebodies for these routes.
Avianca
Thu Mar 24, 2005 2:30 am
it seems that CO never served FRA nonstop from IAH.
Before 09/11 CO served daily DUS from EWR, and daily FRA with B777 (FRA).
After 09/11 CO canceled DUS and downgreaded FRA to B767-200.
regards
Avianca
CALMSP
Thu Mar 24, 2005 3:03 am
FRA is now a 777....it switches so often from a 764-777.
philhyde
Thu Mar 24, 2005 3:22 am
What about LH440 IAH-FRA and how would the load factors on that flight justify (or not) any additional IAH-FRA flights?
Just a thought...
Phil
IAH Spotters
Canon junkie - Aviation Nut
CALMSP
Thu Mar 24, 2005 3:41 am
thats one reason why i feel MAD would be served first.....why jump into somethign where we would be competing directly with someone? downtown isn't that dumb.
fraT
Thu Mar 24, 2005 3:44 am
Quoting Avianca (Reply 13):
FRA-EWR was never flown with a 762. It always was a 764 after the downgrade from a 777. Good to see the 777 back in FRA this summer.
godbless
Thu Mar 24, 2005 6:24 am
Quoting FraT (Reply 17):
Just have a look at the pictures from 2005 alone:
Boeing 777-200: (January 6, 2005)
Photo © Michael Klein
Boeing 767-400: (February 7, 2005)
Photo © Peter Unmuth - VAP
And now, take a close look...
Boeing 767-200: (January 23, 2005)
When was it that CO flew EWR-FRA double-daily? Must have been around 1996 or so.
Max
avek00
Thu Mar 24, 2005 7:34 am
I wouldn't be so sure that CO would make a killing on IAH-FRA - part of any success depends on which side of the Atlantic generates most of the traffic. Methinks that most of the O&D traffic on that route comes from the European side, making it more feasible for LH to operate than CO.
Live life to the fullest.
Avianca
Thu Mar 24, 2005 7:41 am
I have a official letter of CO Cargo that they downgraded the EWR flight after 09/11 to 762.
Yes i also think they had the double daily to EWR from Frankfurt in the mid-90s.
klwright69
Fri Mar 25, 2005 5:03 am
Yes, CO had double daily EWR--FRA. It was flight 50 and flight 58.
dutchjet
Fri Mar 25, 2005 5:29 am
Its odd that CO has yet to introduce the long promised IAH-FRA nonstop flight; it likely would be very successful on both an O&D basis (connecting the business centers in Texas with Germany) and on a connecting basis due to the power of CO's Houston hub. There were strong rumors that IAH would get nonstop service to Frankfurt and Madrid a few years ago - those cities would complement the then existing nonstops out of IAH to London and Paris.
A couple of things happened:
- CO said it was waiting for the new international facilities at IAH to be operational. The facilities have opened but no new flights from IAH to Europe have been announced.
- CO has been very successful on its European flights out of EWR which keep a good portion of the CO 767/777 fleet very busy. The latest round of expansion focuses on 757 transatlantic services, but most existing European destinations are served with wide-body aircraft on a tight schedule, some with double daily service.
- CO aligned with KLM and now CO is a SkyTeam member, thus IAH-Amsterdam was added so that CO could take advantage of the KL hub at AMS (now EWR-AMS will be double daily and IAH-AMS on certain days has two flights.) The focus on AMS has made Frankfurt less intersting to CO - Frankfurt is Star Alliance territory - connections to Europe and the world are now offered by CO via AMS, few connections could be offered via FRA since CO does not have alliance partners there.
- The difficult US visa regulations also affected CO's plans for a European expansion out of IAH - CO hoped to promote IAH as a connecting point for latin american travellers going on to Europe (as an alternative to MIA).....many travellers from latin america now avoid stopovers in the USA due to the visa regs and try to travel via Canada, Mexico or go direct to Europe where possible. The visa regs certainly put the IAH-MAD flight on the back burner (CO wanted to tap into the large market travelling from central america to Spain) and also made the IAH-FRA flight less interesting.
- And, as pointed out, CO's 767 and 777 fleet are already operating on rather intense schedules, especially during the peak summer seasons - new flights to China out of EWR are planned, not to mention the EWR-Lagos service (and possibly EWR-Moscow) that is in the works all of which need 767/777 aircraft. Thus far, CO has been unwilling to invest in more widebody aircraft (other than the order for the 787s).....so IAH-FRA is on hold. There are rumors that CO may downgrade EWR-GVA from a 762 to a 757, or operate EWR-DUB with double daily 757s instead of the 764 which would free up widebody aircraft, but so far those ideas remain rumors.
I think that CO will announce this route in time, the question is when?
Avianca
Fri Mar 25, 2005 7:35 am
Quoting Dutchjet (Reply 22):
yes Fra is Star territory, but never forget that the area round of Frankfurt is still full with Us-American soldiers. Flights are heavy booked with passengers relating to the US-Army.
regards
