duke
Green Stuff On New Planes
Mon Mar 28, 2005 3:50 am
Why are planes that are being test flown sometimes covered by some kind of olive-green material (paint? primer? paper?)?
dacman
RE: Green Stuff On New Planes
Mon Mar 28, 2005 4:26 am
It's called ambertec and it is a protective covering that is applied to the skin of the aircraft prior to painting. Once in the paint shop it is stripped from the aircraft and the aircraft painted.
Mike (lgbguy)
dacman
"Airliner Photography is not a crime"
jeb94
Mon Mar 28, 2005 2:19 pm
Um...its primer. FR primer.
dacman
Mon Mar 28, 2005 2:27 pm
Jeb94,
I co-authored a story a few years ago on the painting of a new 717 and the green coating is ambertec, not primer. As I stated above, it is removed (or stripped) before the aircraft is painted.
Mike (lgbguy)
dacman
FriendlySkies
Mon Mar 28, 2005 2:31 pm
Dacman:
I think he was being sarcastic...note the fact that he said "FR primer" at the end of his statement. FR is an Irish carrier.  Wink
Tod
Tue Mar 29, 2005 3:20 am
Isn't Ambertec the yellow stuff and Alodine the green stuff?
kc135topboom
Tue Mar 29, 2005 11:54 am
Ambertec is green Alodine is yellow-green.
Ambertec is not a primer
Alodine is a primer
AR1300
Tue Mar 29, 2005 12:00 pm
Gosh,I feel like a neanderthal in this thread.I have no clue what those things are , but I get the point.
Mike
You are now free to move about the cabin
jeb94
Tue Mar 29, 2005 12:45 pm
Alodine is not a primer. Its a metal treatment, not a paint. Primers are paint. Never heard of ambertec before but then I'm a mechanic. I have seen brand new PC12s and Gulfstreams and that is zinc chromate primers.
AC_B777
Tue Mar 29, 2005 1:31 pm
Like this?
Photo © Phil Earle
Photo © Phil Earle
In life, some days you are the bug..... some days you are the windshield!
CCA
Tue Mar 29, 2005 2:02 pm
The building the 777 video shows the green stuff, I assume it's Ambertec as people have said, being washed off with a hose, after I assume something has been put on it to break it down.
Now in a former life, during maintenance we would treat aluminum with Alodine a chemical that leaves a golden look and is for corrosion protection, it should then be painted as soon as possible with primer which was green, the Brits use a yellow primer.
Rgds CCA
P1 in A330, A340, A346, B742, B744, B748.
dmt52
Tue Mar 29, 2005 2:22 pm
Quoting Jeb94 (Reply 8):
Alodine is a surface treatment (conversion coating) made by Henkel Technologies. I happen to work for the company. Alodine is a registered trademark of Henkel.
You can read about Alodine's here: http://www.loctiteaero.com/index.cfm?ID=170
Go Green! Go White!
