shonandai
EVA Air 2196 Emergency Landing At NRT
Mon Mar 28, 2005 11:17 pm
Eva Air flight 2196 from Taipei to Tokyo ran into severe turbulence at about 100km from NRT. According to NHK 46 people were injured.
251 passengers and 16 crew were aboard what looked like an Airbus A330-200.
The aircraft was in its descent to NRT when the turbulence was encountered at about 18:11 local time. The plane was SSE of NRT at the time and was over the ocean. The emergency landing was at 18:30 local time.
The was an advisory in efffect at the time of the incident warning of turbulence from 7000 to 12000 meters.
Some speculation on NHK as to whether the seat belts signs were on at the time in light of the large number of injuries. Some passengers were reported to have hit the ceiling and one passenger reported "cracks" in the cabin wall.
shonandai
RE: EVA Air 2196 Emergency Landing At NRT
Tue Mar 29, 2005 12:05 am
New information says the turbulence was 200km from the airport over Miyakejima Island.
Number of injuries revised upwards to 49.
shonandai
Tue Mar 29, 2005 12:14 am
lamedianaranja
Tue Mar 29, 2005 2:08 am
Thankfully nothing serious happened.
Incredible if the seatbelts on sign was turned on and still some pax were thrown from their seats. Don't they listen?!?! Do they wanna lose their teeth (or worse), like I ask my kids when they refuse to buckle up in the car?
I wish that all skies were orange and blue!!
OB1504
Tue Mar 29, 2005 2:15 am
Quoting Lamedianaranja (Reply 3):
I would call an emergency landing due to more than 49 passengers seriously injured serious.
I don't think the seatbelts on an airplane can keep you from being thrown up by turbulence and simply sliding out (for lack of a better word), even if it is fastened tightly.
stephen007
Tue Mar 29, 2005 2:29 am
N754PR
Tue Mar 29, 2005 2:47 am
My seat belt is on for the whole flight.... I just love it when the signs go out.... click, click, click, click!!
Bush, your a sad, sad man.
caboclo
Tue Mar 29, 2005 4:52 am
I don't know how things are in the rest of the world, but in America the seatbelt signs are frequently ignored, as well as repeated warnings from the FAs. People are nuts.
Freight dogs have more fun
lamedianaranja
Tue Mar 29, 2005 5:23 am
From the article posted in reply5:
"I have not been informed of any serious injuries. The injuries are reported to be slight or of medium degree," Yoshikazu Yamamoto, an official at the centre, told AFP by telephone.
Injuries of all kind are bad of course but a serious accident IMO involves a damaged aircraft/ serious injuries. Once again, thankfully this didn't happen. I didn't wish to play down the incident
 Cool
khenleydia
Tue Mar 29, 2005 6:23 am
Quoting OB1504 (Reply 4):
From car wrecks I have gone on, especially rollovers, I have seen was wearing seatbelts can do and what they can't. If they are worn properly, even the lap belts should keep you in your seat. However, with that said, in severe wrecks, part of what causes injuries to people in the back seat are the belts basically keeping their pelvis in one location while the rest of their body goes every which way. I imagine the same thing is true with severe turbulence.
Of course, if they DON'T wear the properly, then all bets are off.
KhenleyDIA
Why sit at home and do nothing when you can travel the world.
chiawei
Tue Mar 29, 2005 8:10 am
BTW, the aircraft has been grounded pending further check in NRT.
The aircraft was suppose to fly back empty, but it was determined that there could be serious damage done to the airframe and it has been grounded in NRT.
Aaron747
Tue Mar 29, 2005 8:36 am
That's crazy - unless there was all kinds of manuevering done by the crew above manuevering/penetration speed, a little encounter with severe turbulence shouldn't be any concern to the structural integrity of the aircraft. Nothing snapped off on touchdown right? Give me a break.
Carpethead
Tue Mar 29, 2005 9:07 am
Regardless of the seat belt signs there are some human factors involved here.
There was a line of t-storms in that area where the flight passed through. It wasn't that huge that it couldn't be negotiated around.
Shouldn't the EVA flight crew notified Tokyo ATC for a deviation. If the Tokyo ATC didn't accommodate that request, then it should be the fault of the ATC. If there were conflicting traffic, then ATC should have moved that conflicting traffic further from the area of t-storms. The last thing you want is a passenger or any plane heading straight into a line of t-storms.
chiawei
Tue Mar 29, 2005 11:47 am
According to news report (from EXTV). There was crack in the interior panel.
They are probably grounding the aircraft for pre-cautionary measure.
But still kind of strange to keep the aircraft grounded at NRT, since both JAL/ANA does not fly A330. I don't think there is resource for EVA to perform a detail check.
The original plan was to ferry the plane back to TPE for inspection. But later it was decided to ground the aircraft at NRT.
Sometime the damage is not visible and no parts will seperate from aircraft.
just hope that the aircraft is okay and the one critical injured passenger is okay (all other has been treated and released).
Aaron747
Tue Mar 29, 2005 4:47 pm
of course there were cracks in interior panels - passengers or objects came into contact with the paneling and most of it is thin plastic. I'm talking about the airframe - which has been designed to handle more than 125% of loads that would ever be encountered across the normal envelope of flight conditions.
knoxibus
Tue Mar 29, 2005 6:53 pm
Latest I have (verbally) is that ANA & EGAT have performed the required check on the A/C.
Authorities, EVA & ANA are curently discussing A/C release.
So far scheduled to leave at 17.30 Taipei time.
1 person still hospitalized...10 cabin crews injured. Must have been strong turbulences.
No matter what anybody tells you, words and ideas can change the world.
ktachiya
Tue Mar 29, 2005 6:56 pm
Quoting Chiawei (Reply 13):
NW has a huge presence there, I think they can provide the resources for the checks. Or other KE? CI? Can also help with this? Eitherway, I would be freaked out seeing a damaged ac heading back to TPE.
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
zanadou
Tue Mar 29, 2005 9:34 pm
From: http://www.japantimes.co.jp/cgi-bin/getarticle.pl5?nn20050329a4.htm
Rough air hurts 46 on EVA jet approach
Narita-bound Airbus warned of turbulence; passengers thrown to ceiling
Forty-six people were injured Monday evening when an EVA Air jetliner from Taipei was hit by turbulence as it was preparing to land at Narita airport outside Tokyo, according to police and transport ministry officials.
The injuries were not life-threatening but 12 of the injured needed to be hospitalized, the officials said. The Taiwan carrier's Airbus A330-200 with 267 passengers and crew members was hit by turbulence at 6:11 p.m. and made an emergency landing at Narita around 6:29 p.m.
Seven ambulances were dispatched to transport the injured to Narita Red Cross Hospital located near the airport.
The airline and authorities have not announced the names and nationalities of those injured.
The Land, Infrastructure and Transport Ministry's office at Narita airport said EVA Air Flight 2196 was hit by turbulence about 100 km south-southeast of the airport at an altitude of about 5,500 meters over the Pacific Ocean. The plane was making its final approach at the time.
Passengers onboard said the plane rapidly lost altitude right after an announcement saying the aircraft was entering an area of turbulence. The seat belt sign was on at the time but some people were thrown out of their seats or from the floor and hit the ceiling, they said.
"All of a sudden, about seven people in front of me were afloat in the air," passenger Sachiko Tatara, 48, said.
"The plane shook violently three times. People were thrown to the ceiling, just like in a movie," said Chen Shu-li, a 32-year-old Taiwanese student studying in Japan.
Oxygen masks came out and luggage was scattered in the cabin. Some injured people were bleeding and young children were crying and screaming.
The Meteorological Agency's Narita Aviation Weather Service Center said it had been issuing warnings since 11 a.m. to planes in the area.
The Japan Times: March 29, 2005
(C) All rights reserved
--->Zanadou Big grin
shonandai
Tue Mar 29, 2005 10:16 pm
Latest from Japan Today.
Seems that the incident is classified as an aviation accident under Japanese law as one of the passengers broke a bone.
See
http://www.japantoday.com/e/?content=news&cat=1&id=332248
