junior1970
SCD Welded Shut When 747 Converted To Full Pax?
Tue Mar 29, 2005 2:49 am
I don't know if this is the right forum for this question. I apologize if it isn't.
On the picture, on the back of the plane you can clearly see the SCD still in place, but the plane has been permanently converted to a full pax plane.
Is the SCD being welded shut or just closed and locked like it's always been when still in combi config ?
Photo © Michael W. Rosa
Thanks for your input.
cedarjet
RE: SCD Welded Shut When 747 Converted To Full Pax
Tue Mar 29, 2005 2:54 am
I would think they would just lock it. Modifying the aircraft permanently would be expensive and probably lower it's value at the same time - combis are relatively unusual and can be quite desirable. MEA leased out it's three 747-200 Combis (and it's own ops became 707-only) during the Lebanese civil war and paid it's entire wage bill with the income.
herctech
RE: SCD Welded Shut When 747 Converted To Full Pax?
Tue Mar 29, 2005 4:03 am
that and you cannot weld the particular aluminum alloy that the door and skin of the aircraft would be made of.
junior1970
Tue Mar 29, 2005 4:06 am
Thanks guys. I appreciate your quick responses.
imatams
Tue Mar 29, 2005 4:51 am
There's no point welding it shut. 742 convertibles also fly with a locked cargo door when they're in pax-mode, so why go through the trouble welding it if it can be just locked?
IM
DL_Mech
Tue Mar 29, 2005 1:11 pm
Usually, deactivated doors are bolted to the fuselage structure with brackets. They are easily reopened and reactivated by removing the brackets.
This plane is built to withstand anything... except a bad pilot.
