CRJ900
Mid-cabin Lav On 737s...
Thu Mar 31, 2005 8:42 pm
I have noticed on CO and AS seat maps that they have mid-cabin lavs on some of their 738 and 739s, and it looks like a novel idea, stopping the Y riff-raff from using the precious F lav up front.
But from a technical perspective, does installing a mid-cabin lav require lots of maintenance and reworking of cargo space, underfloor wiring etc etc, or is it a fairly easy thing to do, so that CO and AS can install or remove mid-cabin lavs without too much fuss?
Anyone in-the-know here?
Come, fly the prevailing winds with me
Tod
RE: Mid-cabin Lav On 737s...
Fri Apr 01, 2005 3:43 am
I don't think it would be tough at all.
The forward lav vacuum waste plumbing should be going right past that area anyway.
Sink drain and potable water might take a bit of design effort, but nothing earth-shattering. I haven't looked yet, does the 738 and 739 have just the one aft drainmast, or did they add another one for the mid area. That would simplify the drain routing.
Lav wiring comes from above and should not be an issue.
If it's located over the wingbox, the floor structure changes should be minimal.
Zero impact on cargo capacity.
Maintenance should not differect than any other modern lav.
IFixPlanes
Fri Apr 01, 2005 5:25 am
Quoting Tod (Reply 1):
The sink drain related to the forward Toilet is located a few feet forward of main wheel well. So I think it´s no big deal to install a additional Toilet in the mid area.
Ingo
never tell an engineer he is wrong ;-)
