lightsaber
Crew
When Is The 5th ATL Runway To Open?
Wed Apr 06, 2005 1:37 pm
I searched the previous posts and was unable to find a definitive link as to when the 5th runway at ATL opens. Last I heard it was summer of 2005, but does anyone know THE DATE (day, hour)? It should be soon.
I believe this will allow ATL to overcome ORD as the airport with the greatest number of movements per year. Ok, there might be a gate limit, but obviously another runway will reduce delays and allow current gates to have a greater utilization rate.
Thanks in advance,
Lightsaber
RDUDDJI
RE: When Is The 5th ATL Runway To Open?
Wed Apr 06, 2005 4:48 pm
Will RWY 10/28 give ATL the ability to do triple simultaneous aprch's like DEN?
Sometimes we don't realize the good times when we're in them
IanatSTN
Wed Apr 06, 2005 5:18 pm
Am I correct in thinking that the 5th runway is slightly shorter than the other 4, and will be predominately used by regional jets/737's/717's etc?
Ian.
Ian@STN ::
DAL767400ER
Wed Apr 06, 2005 10:32 pm
Quoting IanatSTN (Reply 3):
That was the original plan. The runway was planned as a 6,000ft runway, to be used basically for RJ operations. However, the airport authority decided it would be better to build a full 9,000ft runway, just like 09R/27L and 08L/26R, to be usable for all airliners to land, and also to take off (except longhaul flights). Another factor for the lenghtening was the idea that in the future there will be new South Terminal between 10/28 and 09R/27L, which would make good use of 10/28 as a departure runway.
Quoting RDUDDJI (Reply 2):
Either that or triple simultaneous departures. The runway is some 4,300ft apart from 09R/27L, IIRC.
lightsaber
Crew
Thu Apr 07, 2005 12:01 am
Quoting DALMD88 (Reply 1):
May 2006
http://www.atlanta-airport.com/Defau...e.htm
Thanks. So its on schedule? That web page has been there for over a year.
Quoting DAL767400ER (Reply 4):
Yep! Although I've notice the taxiway arrangement doesn't leave as much land for the South Terminal as earlier plans.
Yep!
The adverse weather capacity is set to increase 34% from:
http://www.faa.gov/events/benchmarks/DOWNLOAD/pdf/02-Atlanta.pdf
Lightsaber
srbmod
Thu Apr 07, 2005 12:58 am
Quoting Lightsaber (Reply 5):
Very much on schedule. All that pretty much remains is to finish up the overpass/tunnel on I-285 and then laydown the concrete for the runway and the taxiways.
Actually the planned location has plenty of room. Here's a rough outline:
http://home.earthlink.net/~srbmod/sitebuildercontent/sitebuilderpictures/atlrun.jpg
The red represents the new runway and taxiway area. The purple represents the rerouting of Riverdale Road and GA 314 (I meant to also highlight the rerouting of Sullivan Road on the SW corner). The blue represents the bridge/tunnel where the runway spans I-285. The green is the area in which the new Southside Terminal will be built.
DeltaGuy
Thu Apr 07, 2005 1:07 am
Was wondering, are there any security concerns for this new runway underpass? Would think they'd raise a few, maybe prohibiting semis from going under, etc etc. Will be one heck of a structure though.
DeltaGuy
Lindy
Thu Apr 07, 2005 1:29 am
Hey Guys,
Little off topic. I will visit ATL this Saturday and I understand that South parking garage is not the best place in the morning. I will arrive at ATL around 8am and I will have 5 horus before I can check in to hotel. Where I can go for pictures? Also consider that I won't have a car.
Rafal
BTW - Anyone is willing to join me this Saturday for pictures at ATL?
[Edited 2005-04-06 18:30:03]
BWIADCA - Nikon D100
NWA1978
Thu Apr 07, 2005 2:47 am
Speaking of the new runway, does anyone have any pic's of the progress? I dont know how much one would be able to see but i have not been to atl for a while so I have no clue what it looks like.
gigneil
Thu Apr 07, 2005 2:50 am
Yes, it will, although DEN is now qualified for quadruple simultaneous ILS approaches.
N
DAL767400ER
Thu Apr 07, 2005 3:05 am
Quoting Nwa1978 (Reply 9):
Best way would be to use a.net's photo database. Just look for Airport Overview's of Atlanta within the last 2 years. There are quite a few pics where the new runway is visible, although in the pics it still is more of a sand track.
N1120A
Thu Apr 07, 2005 3:12 am
Quoting DeltaGuy (Reply 7):
Given that many other airports have tunnels under their runways, including LAX which has them under the 2 longest runways, and big trucks run under all the time, I don't think it will be an issue. That tunnel is Sepulveda Blvd., which is very busy 24/7 and where one would notice a stopped car. Same with the interstate highway that will go under the new ATL runway
lightsaber
Crew
Thu Apr 07, 2005 3:14 am
Quoting Srbmod (Reply 6):
Srbmod, Not to nitpick, but you drew the original layout. If you look at the link I put at the end of post 5 and scroll down to the outline of the airport you'll notice the taxiway is now diagonal cutting right through the Green box where the south terminal is supposed to go. They went for cutting transit times short term. Obviously taxiways are easier to build than runways, but the diagonal taxiway was selected at the same time they went to a 9,000 ft runway (from 6,000 ft).
Yes, I would love to see pictures. Doubly so if their from the air.
Quoting Gigneil (Reply 10):
Wow! Can you imagine what DEN will be like with the full 12 runways? Now if they would only get on the ball at IAD for the new runway and LAX/SFO for the runway reconfigurations.
Congratulations to ATL. Keeping with the expansion during the downturn is going to make it look like they planned it just right. While I would have liked to see the south terminal opening at the same time, I think all of us understand cuts had to be made in the last few years.
Out of curiosity, does anyone else remember that when this started the proposal was for TWO new runways?
Lightsaber.
srbmod
Thu Apr 07, 2005 4:45 am
Quoting Lightsaber (Reply 13):
The FAA link is incorrect. I work out @ ATL and have watched the progress out the project. If the taxiway was going to be diagonal, they would have already laid the dirt for it, plus they would have had to do a bridge/tunnel for the NLVR around the airport perimeter inside the SIDA if they did the taxiway diagonally. Loop Road is closed just past South Cargo because of the new taxiway, which goes straight across towards 10/28.
What killed that was the cost of acquiring the land. It was going to cost nearly twice as much as the fifth runway just because of the land costs. The proposed area where a sixth runway would have involved displacing around 10,000 people, several schools, and quite a few businesses. A chunk of that land is a former landfill, and that isn't exactly the best type of land to build on (Plus you have the issue of having to constantly burn off the methane being produced as well.), so it would probably have had to been the safety zone at the end.
lightsaber
Crew
Thu Apr 07, 2005 5:08 am
Quoting Srbmod (Reply 14):
Good to hear, I'm happy to find out I was mis-informed.  Smile That leaves plenty of room for the south terminal. I saw plans go from a straight taxi way to the diagonal... Apparently they went back and I missed the switch! Cool enough.
Thanks everyone!
Lightsaber
ps
I've broken 300 posts!  bigthumbsup
Users browsing this forum: Alexa [Bot], alphonze, Baidu [Spider], Bing [Bot], eta unknown, iahcsr, IslandRob, quiet1, SInGAPORE_AIR and 173 guests
