kamboi
Blended Wing Tips Vs Winglets
Thu Apr 07, 2005 3:14 am
I am no aerospace engineer nor a pilot, but for those of you out there, why is it that some planes are now being fitted with "blended wind tips" as opposed to "winglest" on the original production. I know it's a fuels cost issue. But why don't the manufacturer just produce them with the winglets. I was surprised the B777 did not have winglets instead of raked tips, and neither does the new 787. Why is that?
FriendlySkies
RE: Blended Wing Tips Vs Winglets
Thu Apr 07, 2005 3:33 am
The 777s wing is so efficient that winglets would most likely hurt it's performance, or provide any benefits worth mentioning. The raked wingtips do not disrupt airflow as much as a winglet (most noteably the airflowing off the end of the wing), but rather add minimal lift and thus slightly lower fuel burn on very long flights. You won't see raked wingtips on shorter range aircraft, such as the 787-3, as they don't do much of anything for flights under about 9 hours or so.
aeroweanie
Thu Apr 07, 2005 9:45 am
FriendlySkies:
I think you are speaking without much real knowledge. Raked tip and winglets do not "disrupt the airflow" or "add lift".
We've thrashed this subject in quite a number of other threads, both here and in Tech/Ops. I'd suggest that you go look there.
FriendlySkies
Thu Apr 07, 2005 9:55 am
I meant that they disrupt the vorticies coming off the ends of the wings...I'm not sure how much, but I'm fairly certain they have some effect. They do add a small amount of lift because they add area to the wing. If they don't add lift, then their effect is null, because they would just be added weight.
aeroweanie
Thu Apr 07, 2005 12:33 pm
On all aircraft lift = weight in cruise. You can't "add more lift". Wing tip extensions, raked wing tips, winglets, etc. all have the effect of decreasing the drag induced by creating lift.
I'd suggest Googling "induced drag" and reading some of the texts you find.
DfwRevolution
Thu Apr 07, 2005 12:57 pm
Quoting FriendlySkies (Reply 1):
That isn't true at all... the blended vertical winglet is simply more space efficent, which matters big for short-haul aircraft. Already some 737NG customers, FL comes to mind, have not opted for winglets because of gate access.
Quoting Kamboi (Thread starter):
Boeing found that adding several more feet to the 777's wingspan had the same effect of adding winglets, and that stretching the wing did not require the reinforcement necessary for winglets. In otherwords: stretching the wing was more structurally efficet.
Next, the winglet is hardly the epitome of aerodynamics. The 787 features a new generation of winglets known as "super-shark winglets." FD tried something simmilar before going belly-up.
No... Boeing just found alternative ways to optimize the 777's wing
aeroweanie
Thu Apr 07, 2005 2:20 pm
> was more structurally efficient.
Not true. For the same span extension (measured with the winglet laid down flat), winglets produce the same drag reduction or slightly more than wing tip extensions. Wing tip extensions also produce more bending moment than winglets. Hence, the wingtip extension would require more structural reinforcement than required for winglets.
The problem with the 777 wing is that Boeing designed it with relatively high lift coefficients near the tip. They figured that if the wing wasn't carrying much lift there, they would minimize the chord, which drives up the lift coefficients. This makes it difficult to put a winglet on this wing.
Ahem...
The design concepts that have been released and public comments show the 787-3 to have winglets and the 787-8 and 787-9 to have non-planar raked tips.
CO737800
Thu Apr 07, 2005 2:36 pm
I have a question why would Airbus not make so efficient wings like on the 777 and 787
Thu Apr 07, 2005 3:01 pm
Quoting CO737800 (Reply 7):
The are making more efficient wings, on the 380! the 777 and 787 are simply newer and make use of slightly more modern aerodynamics than the 330/340... It's a constant "arms race".
As for winglets vs blended winglets, there are many ways to skin a cat, all leading to more or less the same result.
Winglets can be more appropriate sometimes because the increase in wingspan is less, and the plane can get into the same gates as before. Also, for the 380, any increase in wingspan is verboten due to the 80m box.
