LH450
I Have A Question About This Picture- Who Can Help
Fri Apr 08, 2005 1:08 am
Hi everybody!
I was just surfing around on a.net and found this photo:
http://www.airliners.net/open.file/811641/L/
What is this for a blue liquid coming out of the plane??  Confused I was searching the internet without any results! Who can help?
Thanks!  Smile
LH450
* * * ICQ# 162799116 -add me * * *
boeingforever
RE: I Have A Question About This Picture- Who Can Help
Fri Apr 08, 2005 1:10 am
part of AF new revised livery..hehe
JJMNGR
Fri Apr 08, 2005 1:12 am
It is flush fuid came out from the toilet access.
LH450
I think you could be right Big grin...
DC9Fixer
Fri Apr 08, 2005 1:13 am
Hey Thats LAV Juice!!!. leaking for the fwd lav.
B4REAL
Looks like Lavatory liquid, I know that sounds gross. But I think it is.
copter808
Fri Apr 08, 2005 1:22 am
It's camouflage paint. When it coats the bottom of the airplane, it makes it difficult to see it when viewed from the ground against a blue sky!
Leaking lav juice is the real culprit.
ahlfors
Fri Apr 08, 2005 1:31 am
Maybe AF was trying a new wash-as-you-fly mechanism using leaking toilet fluid. The experiment failed.
LH450
Fri Apr 08, 2005 1:37 am
LOL, you really made me laugh Big grin...The old running gag about Air France's dirty livery  Smile
cheers
Sabenaboy
Fri Apr 08, 2005 1:40 am
Hi,
I would be amazed if it were blue flush fluid because...
Airbus 320's don't use that!
The 320 lav system works with normal water which comes from the same reservoir as the potable water. The LAV system is also serviced at the rear of the 320's.
Perhaps old versions of the 320 use the system with the blue lav fluid, but I've never heard of that.
Sabenaboy
AlitaliaMD11
Fri Apr 08, 2005 2:01 am
I have noticed this blue-flush liquid many times on Air France planes!
Speaking of Air Frances dirty livery. I was in CDG on the 31st of March and got close to an AF 773ER and it has already gotten sooo dirty!
No Vueling No Party
NWA1978
Fri Apr 08, 2005 2:07 am
The blue is not liquid. It is paint that was not able to be washed off after some kids tried to paint the boeing dreamliner livery on the bus!
ntspelich
Fri Apr 08, 2005 2:18 am
Definetly blue juice. It looks like someone didn't make sure that the excess drained out before they closed the fill cap, or didn't make sure that the fill cap was securely latched before they finished servicing the plane.
NTS
United 717 heavy, you're facing the wrong way. Any chance you can powerback to get off of my deice pad?
FlySSC
Fri Apr 08, 2005 2:49 am
KLM's blue livery begins its invasion ...  stirthepot
LH450
Fri Apr 08, 2005 2:52 am
Okay, when will start LH's invasion on the Swiss-colours? Big grin *jk*
TWA902fly
Fri Apr 08, 2005 3:12 am
The blue on the fuselauge is actually coded French for "What will Northwest replace its DC-9s with?"
TWA902
life wasn't worth the balance, or the crumpled paper it was written on
USairways16BWI
Fri Apr 08, 2005 4:39 am
de-icing chemical maybe????
ntspelich
Fri Apr 08, 2005 6:58 am
Quoting UsAirways16bwi (Reply 16):
Nah, glycol is either pink or gree, depending on what type is being used.
LFutia
Fri Apr 08, 2005 7:02 am
hmm. i thought it was Air France's new in-flight cleaning solution. Depart Dirty... Arrive Clean!
flyinTLow
Fri Apr 08, 2005 7:03 am
The thing that amazes me about it is that it is so deep in color. The stuff i have seen spilled on the tarmac usually looks a lot more "watery" in comparison.
- When dreams take flight, follow them -
UAalltheway
Fri Apr 08, 2005 7:10 am
Here's the pic:
Photo © Sascha Haberkorn
And it's the toilet "flush" blue flued stuff. The vent obvously came open mid-flight or something seeing as how it's like going backwards on the aircraft suggesting the wind sprayed it along the side of the aircraft.
A388
Fri Apr 08, 2005 7:31 am
I also thaught it would be de-icing chemicals.
A388
Iberia340600
Fri Apr 08, 2005 7:59 am
Sabenaboy is right. A320's(and just about all the other Airubuses) use potable water for the toilets. Why does this A320 have blue liquid?
Could it be some kind of hydraulic fluid that leaked? That doesnt look like a potable water or lav access door to me...most Airbuses have those either on the other side closer to the middle or towards the back of the plane.
Visca Barça!!
USairways16BWI
Fri Apr 08, 2005 8:05 am
maybe a plane landed, and somehow, the blue stuff from the toilets got out from a rough landing, then the AF plane landed on the same runway right afterwards and the stuff was splashed all over the belly by the nose wheels...just a thought.lol
BCNGRO
Fri Apr 08, 2005 8:35 am
It looks like a smurf strike  Smile
Now, seriously, it really looks like lav juice, but if you guys say A320's use potable water for the toilets I have no idea...
At the bus station, buses stop. At the train station, trains stop. At my desk, I have a work station.
NBGSkyGod
Fri Apr 08, 2005 9:30 am
"It looks like a smurf strike"
LMAO Now that made my night.
Pilots are idiots, who at any given moment will attempt to kill themselves or others.
AsstChiefMark
Fri Apr 08, 2005 9:48 am
Look at it again. I wonder what the windows aft of the wing look like.
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
Dazed767
Fri Apr 08, 2005 10:03 am
Uh, that is the lav access door and yes airbusses can/do use blue juice.
TedTAce
Quoting NWA1978 (Reply 11):
ROFLMAO!!! The Beautiful Blue Liquid that sometime freezes and makes holes in roofs  Smile
This space intentionally left blank
hammer
Fri Apr 08, 2005 10:52 am
unless AF is different, the lav panel on NWA is at the rear of the plane, and they don't have a fill port in the front....
MD11Engineer
Fri Apr 08, 2005 11:04 am
The LH A320s I worked on all had the vacuum toilet system with the holding tank in the area behind the bulk cargo compartment. The service panel is on the right side, just behind the bulk cargo door.
BTW, it was also serviced with a small amount (about 20 liters) of blue fluid for desinfection pruposes and to dilute the sh*t. Flushing is done with potable water from the potable water tank, which on the LH A320 is sited in the snake pit, the area between the forward cargo rear bulkhead and the forward bulkhead of the center wing box (in this area you´ll also find the aircon mixing chamber and the recirculation fans).
I assume that the vacuum toilet system is an option and airlines are free to order conventional toilets with a tank right beneath the bowl. In this case the drain lines and the servicing panel would be right beneath the toilet (which in this case would take the place of LH´s coat storage cabinet.
The door visible in the picture right behind the toilet service panel is the access to the aircraft batteries and the crew oxygen bottles, plus an avionics cooling blower fan. You´ll also find the drains and water traps of the captain´s pitot tubes in there.
Jan
KBGRbillT
Fri Apr 08, 2005 11:12 am
Some A320's do have a forward lav service station. You guys are correct, it does use water from the potable water system for flushing. But a few gallons of "blue juice" are put into the bottom of the holding tank after it has been flushed out to make it smell better during the flight as well as keeping contamination from sticking to the bottom of the tank on the first few uses when it is empty and dry!! It looks like the service port was not allowed to completely drain the residual before it was capped or the dump valve is allowing leakage by it.
malaysia
Fri Apr 08, 2005 11:30 am
Quoting Ntspelich (Reply 17):
It sure looked like Orange Tang to me in ARN, and I spent 3-4 hours watching it slowly runoff the wing in flight till around over SVO.
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
TWAMD-80
Fri Apr 08, 2005 1:13 pm
There's proof that AF doesn't wash their planes often.  Wink
TW
Two A-4's, left ten o'clock level continue left turn!
ntspelich
Fri Apr 08, 2005 1:31 pm
Quoting Malaysia (Reply 32):
Yes, you're right. It's either green or orange. I don't know what was going on in my head when I typed pink. Type IV is green and Type I is a red-ish orange depending on the amount of water that it is mixed with.
THe A320s are like the 737NGs, where they do flush the lavs with clean, potable water. However, when you empty the tanks you do pump in some blue juice for both a deoderizer and disenfectant.
Which, on an unrelated note, I've been told is why WN ramp uniforms are blue. Just in case you get a spill on you.
NTS
xjramper
Fri Apr 08, 2005 1:52 pm
Im not trying to hijack this thread in any way...im just clarifying the glycol issue. Type I is either orange or pink (ones ethanol and the other slips my mind) and deices the aircraft at a warmer temperature. Type IV is green, served at "room" temperature, looks like a ball of snot in the holding tank, and is anti-ice.
XJR
Look ma' no hands!
N751PR
Fri Apr 08, 2005 2:44 pm
Quoting Nbgskygod (Reply 25):
Likewise here. Nearly had Coke come out of my nose after reading that.  Silly
Quoting FlySSC (Reply 13):
I guess it's KLM's way of continuing it's existence after the merger.  Wink
"Ladies and Gentlemen it's happy hour. You will get two approaches for the price of one."
manu
Fri Apr 08, 2005 9:40 pm
Quoting BCNGRO (Reply 24):
So the ozone hole isn't caused by CFC's? But AF aircraft stealing the sky?
Propman
Fri Apr 08, 2005 9:59 pm
It's someone's attempt to improve AF's so dull livery.
Jets are for kids
Cleared2Land4
Fri Apr 08, 2005 10:57 pm
POO JUICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
United Airlines... "It's Time to Fly."
KBGRbillT
Sat Apr 09, 2005 12:34 am
Pink/redish type I deicing fluid is propylene glycol and the orangy type I is ethylene glycol.
LH450
Sat Apr 09, 2005 12:47 am
Thanks everybody for your answers  bigthumbsup
You really helped me guys!
cheers
LH450
