NYCAAer
777- The Driest Cabin Ever?
Mon Apr 11, 2005 10:09 pm
Has anyone else noticed this when flying the 777?
I'm a flight attendant and worked aboard the 767-300 last fall and and in December and January. Since February, I have been flying the 777 exclusively, and when I get off the plane I'm dehydrated. My lips are chapped, my mouth is dry, even my skin feels drier. I'm drier coming off a 6 hour LHR-JFK trip on the 777 than I am working a 9 hour ZRH-JFK on a 763. I drink tons of water to no avail. I can't imagine 14, 15 hours on the 777.
I know the 777 had some problems with people passing out in flight when it was first introduced in the mid-90s, but those problems were rectified. Anyone have any info on the 777 in this respect?
Treg
RE: 777- The Driest Cabin Ever?
Mon Apr 11, 2005 10:15 pm
I agree with you 100%. And after especially nasty SFO-FRA flight with UA 777 I have started to avoid the beast. 340/747 families are much better in this regard. Maybe it is just a subjective feeling but I have felt really bad after every 777 flight  Sad
Sabena332
Mon Apr 11, 2005 10:19 pm
I also read long time ago in some magazine that passengers suffered from nosebleed while flying on the 777.
I never noticed anything different on all my 777 flights.
Patrick
[Edited 2005-04-11 15:21:44]
NYCAAer
Mon Apr 11, 2005 10:53 pm
I thought I read somewhere that Airbus equips its aircraft with cabin humidifiers, but I've also read somewhere else that cabin humidifiers aren't feasible because they contribute to corrosion of the fuselage. I don't know which statement is true. I never had any problems on the A300. The other planes I've worked in my career (either Boeing or McDonnell Douglas) have been fine, too.
EXMEMWIDGET
Mon Apr 11, 2005 10:54 pm
Last Fall, my wife and I flew DFW-LGW on an AA 777. We both started to feel very dehydrated after about 3 hours in the air. We did all of the rehydrating things that we could do....drinking lots of water, using saline nose spray, and using some sort of bottled face mister that my wife (an AA F/A) brought with her. These things helped, but the flight was still a bit uncomfortable. We returned LGW-DFW on an AA 767 with none of the dryness that we experienced on the 777.
Tod
Mon Apr 11, 2005 11:28 pm
The is nothing about the 777 air system that would make it any drier than a 747 or 767. None of them have pax humidifiers and all of them have flight deck humidification. Some 744 have a humidifier for the door 5 crew rest. Pax humidification would be nice, but the main problem is the stuff that grows inside of humid ducting. It's a trade-off, while extremely dry air is inconvienent, breathing the mold and germs from moist ducting can make you sick.
The amount of recirculated air make have a small impact though, since it has been moisten by the last person the breathed it. yuck
Quoting EXMEMWIDGET (Reply 4):
Try starting your hydration efforts the day before. By the time you get on board, it's too late to really be effective.
AA737-823
Mon Apr 11, 2005 11:55 pm
Unfortunately, humidifying the air is not a safe idea. First, as someone mentioned, gross things grow in moist air, and even more so in moisture- creating devices. Have you ever had a humidifier in your home? They grow jelly in the bottom. Mine did, anyway. And smelled bad. Yuck.
I digress.
The other problem is indeed corrosion.
One of the great benefits of the 787's composite structure will be its resistance to corrosion. Boeing says that, due to this alone, humidity will be up to 15% or so in the cabin. Common relative humidity levels in current aircraft are 5-8%. THAT makes Arizona feel like Houston!
I was in an A330 crossing the Atlantic in 2001. It was a great ride, but BOY was I dry. I noticed it about four hours in. I drank bottle after bottle of water, but my lips cracked and bled, and my hands got all crackly.
One big problem is that, at altitude, there isn't much moisture to be had. All cabin air comes straight from the engine compressors, through the a/c packs, and into the various ductwork. And that air outside (unless you're flying through a cloud!) is waaaay dry.
To my knowledge, there are no significant differences between the operation of Boeing AC packs (between 767, 777, or 747) and Airbus AC packs. The all pretty much do the same thing (compress, decompress, and decompress again) to the air.
I hope my info helps you out some. I guess I could sum it up by saying that yes, 777 air is very dry, but so is the air in other Boeings, Douglasses, and Airbusses.
R
Lemurs
Tue Apr 12, 2005 12:12 am
Quoting Tod (Reply 5):
That's an important point that's often lost in travel tips. Your body can only retain so much moisture at a time before just passing some through. Unless you've made a point of hydrating yourself over the hours leading up to the flight, you'll probably just urinate out what you've been drinking. Another important factor is salt (more specifically, electrolytes). Having a sport drink, or even some salty snacks will help you retain more moisture than drinking just water.
There are 10 kinds of people in the world; those who understand binary, and those that don't.
WesternDC1010
Tue Apr 12, 2005 4:35 am
Yes, I agree.
In my opinion, American's 777-223's seem to be dryer than United's 777-222's. I just traveled from LAX to LHR and back on AA's 777's last week and they seem to have been the worst when it comes to lack of humidity. N753AN (LHR-LAX) was worse than N777AN (LAX-LHR). I had to get up and get water every 2 hours.
- Ron
Western DC-10-10
Western Airlines - The Only Way To Fly
FriendlySkies
Tue Apr 12, 2005 4:41 am
I flew 4 777s in a row (ORD-SFO-HNL-SFO-ORD), and didn't notice any difference to a 737, A320, or any other aircraft.
However, I will say this is one of the more interesting threads I've seen to date.
JBLUA320
Tue Apr 12, 2005 4:45 am
Ive also never felt dry on any of my 5 777 flights. The only aircraft I've truly felt parched on was the 757-300.
JBLU
TheBigOne
Tue Apr 12, 2005 5:18 am
When flying from LHR to PHL on a BA 777 last year, I was discussing flight rosters with the FA, when the topic of the 777s lack of humidity came up. I said that I found the 777 had the most comfortable environment (including air) when compared to the 747. The FA however did not agree with me and said that she felt like she had a perpetual cold when flying the 777. According to her, BA crews were starting to get a little unhappy regarding the dryness on the 777 and had consulted with BA's health and safety department. According to the FA, tests were carried out on both the 777 and the 747 (as the crew said they preferred the cabin environment of the 747), but that tests showed both aircraft had very similar humidity levels. The crews have continued to fly 777s, but apparently many prefer the 747.
p.s. Before anyone starts bashing me over the head, please note that I am only narrating a discussion between myself and a FA, and I recognize that she is not an authoritative source on BA's cabin humidity!
Reach for the stars - they are closer than you think!
kim777fan
Tue Apr 12, 2005 5:28 am
I didn't really notice any undue dryness on my one trip which was a DEN-SFO leg and a return leg of SFO-ORD. I thought the plane was incredible myself, but those aren't particularly long flights in the overall context of things.
I do know that with new composite materials, the 787 is supposed to have much better humidity than prior generation aircraft which should help alleviate some of the jet lag problem.
Maybe composites can be incorporated in a new "777NG."
AirWillie6475
Tue Apr 12, 2005 12:02 pm
This is weird because on a 777 documentary it stated that the 777 is the most passenger friendly plane to date. It even eliminates fart smells according to a 777 flight attendant. It also stated that there was a better cabin air environment.
kim777fan
Tue Apr 12, 2005 12:22 pm
I wonder if an airline can advertise that their planes eliminate fart smells or if there's some FCC regulation precluding that.
jacobin777
Tue Apr 12, 2005 12:33 pm
Quoting NYCAAer (Reply 3):
EK really humidifies their A345's with LOTS of humidity......feels like I just walked into a tropical rain forest!!
Quoting Lemurs (Reply 7):
thats exactly what one should have, and avoid coffee and alcohol!
Quoting WesternDC1010 (Reply 8):
WesternDC1010...how as the trip? I plan on either flying either AA SFO-LAX-LHR or AA SFO-ORD-LHR, but I'm not 100% sure.....obviously there are pros and cons to both ways, but some input would be appreciated....thanks..  Wink
"Up the Irons!"
uaord2000
Tue Apr 12, 2005 12:55 pm
I couldn't agree more. The 777 for some reason is the most uncomfortable plane when it comes to a dry cabin. As a flight attendant, we put pots of steaming water behind some seats in front of bulk heads to help humidify the air on long flights. It really seems to help.
roseflyer
Tue Apr 12, 2005 1:12 pm
Actually people are correct in saying that the 777 system may make them feel dryer. Part of the inovations with the 777 was a pressurization system that turned over the air inside the cabin faster then any other plane before. It is roughly 3 minutes, which is insanely low. I don't have any figures for other planes though. Hamilton Sundstrand makes the Airbus pressurization systems for the air circulation and it is known to be quieter but produce less volume then Boeing, which is why the Airbus planes are often quieter inside. Boeing put turnover as a bigger priority because it allows for clean air and less diseases and particulate matter in the air.
I am not a doctor at all and haven't taken biology since high school, but the faster circulation may cause these symptoms. The air is pretty much the same, but there is more of it moving as the ducting system is at a lot higher pressure on the 777. This "blowing" can take moisture out of your system faster and might be the result for these claims. If you are feeling dry always turn off the air nozzle above your seat as moving air will take more moisture away from you skin.
aerorobnz
Tue Apr 12, 2005 1:14 pm
On my 777 flights on both 772/773 I haven't had a problem. Admittedly 2 of those flights were only around 3 and 1/2 hours, but the other was 10 hours 20 min, and I didn't notice being any more dehydrated than I am usually on the ground.
Flown to 128 Airports in 48 Countries on 81 Operators. Visited 56 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
AEROFAN
Tue Apr 12, 2005 1:15 pm
Oh thank GOd. I thought that this only happend to me. I experiene the same symptoms whenever I fly VS to and from London. Yet I just flew Air pacific to and from Fiji in a 747 and experienced none of the problems. Wonder why????
apollo13
Tue Apr 12, 2005 1:41 pm
Yeah it is from the air because one time i was flying on a southwest flight from OAK to MSY, and on approach to MSY, we passed several storm cells, and boy did I feel all humid and wet compared to being over the desert where is was cracking!
WesternDC1010
Tue Apr 12, 2005 2:45 pm
Quoting Jacobin777 (Reply 15):
The trip was OK, but I prefer United's service between LAX and LHR over AA's. The in-flight service aboard AA was adequate, but the last time I flew UA, the alcohol was free and they showed more recent films and television programs as part of their entertainment. Plus the flight attendants were more cheeful and kept us well-fed and watered. With the dryness experienced on both aircraft, the less time spent on AA's 777, the better. So I'd do the SFO-ORD-LHR segment, if I were you.
AlitaliaMD11
Tue Apr 12, 2005 2:54 pm
I have found myself very dhydrated on the B777-200 before. Every time that I have flown on it. More recently when I flew back to New York in November and I flew CDG-JFK on a AF B777-200 I was really un-comfortable and dhydrated, and I ended up getting a really bad soar throat from it!
I went back to the galley to get some water, but it didn't really help.
On the rest of the Boeings, 727,737,757,767,747, I have not felt dhydrated before nor on any Airbus planes.
No Vueling No Party
njdevilsin03
Tue Apr 12, 2005 3:12 pm
Interesting Topic indeed. Flew CO 777 MCO-EWR once didn't feel any type of dehydration effects at all but that may be because it was only a 2 hour flight and it didn't take off till around Midnight or so.
717, 727, 731, 732, 733, 734, 735, 73G, 738, 752, 753, 762, 763, 777, DC9, MD80, DC10, L1011, ERJ, CRJ, ATR, DH8, A300,
chicoco
Tue Apr 12, 2005 3:38 pm
I recently flew LA A343 SYD/AKL/SCL return. My mouth as as dry as sandpaper, and could not get over the dehydration for hours after arriving in SCL. On the return leg I had two 1.5 litre bottles of mineral water, they were both finished by the time we reached AKL. I really don't seem to find much difference between long haul aircraft.Next month I will be flying JL SYD/NRT/FCO, and return.I do know for a fact that JL supply bottled mineral in flight .Lets see how different to the A343 to the 744 is.
Boeing7E7
Tue Apr 12, 2005 3:42 pm
Try a DC-10 from MSP to HNL...
Talk about dry. Humidity shock when you get to HNL.
hawk44
Tue Apr 12, 2005 3:49 pm
Anybody have any data on how many pax have suffered severe dehydration or severe health issues related to dehydration onboard the T7?
Hawk44
Never under estimate the power of US
WunalaYann
Tue Apr 12, 2005 4:58 pm
Guys, I'm starting to freak out, now!!!!!!!!!  scared .
I'm flying CDG-MEL with EK, on a 773 for CDG-DXB, then on a 772 for DXB-SIN-MEL...
Argh!!!!!
Y.
wunala
Tue Apr 12, 2005 5:37 pm
I always fly with a good moisturiser, and a facial spray, incase I dont get it in my amenities pack. I find the combo works well, and never suffer the effects of dryness in the air. I don't avoid alcohol either, but I pass on the filter coffee every time. Its a skinny latte or nothing.
Although 1 top tip I will pass on, is to check before assuming that you have picked up the facial spray. I once used the mouth spray, and its a little sticky, but does give you a lovely pepperment scent.
Mir
Tue Apr 12, 2005 6:54 pm
I haven't been on a 777 for some time now, but I remember one trip EWR-AMS (CO) that I was just miserable on. Granted, I had a nasty cold and sore throat already, but that trip was just murder.
On the return flight, I was feeling a good deal better, but I do recall the cabin as a bit dryer than most.
-Mir
flyabunch
Tue Apr 12, 2005 7:10 pm
There are trade-offs to everything. I think I would rather have high rates of air turnover and fewer pathogens flying around the cabin. If you just listen to the passenger sounds as everyone is settling down when the close the doors, it sounds like a hospital ward with all the coughing and sneezing going on. Dry air also has a lower carrying capacity for germs.
I have flown on every current airplane type except 340's and I have not noticed any real difference in dry factor. I think the biggest single factor that people are noticing in this thread is flight length. The longer the flight, the more noticable the cabin dryness is going to be. Since most 777 flights are relatively long, it is more likely that people will notice the dryness.
Hydration is the most important factor and coffee and alcohol only make the problem worse..but I still like a drink or two on a flight!
Mike
