intothinair
When Will T. 3 And New Runway At FRA Be Completed?
Mon Apr 18, 2005 7:57 pm
We all know that FRA is short of runways, considering how big the airport is.
Does anyone know when the new runway (which will only be used for landings) will be finished?, as well as Terminal 3.
I was also wondering, doesn't MUC also have a lack of runways compared to it's traffic. While FRA handled 119,369 landings per runway last year, and 79,579 takeoffs per runway last year, MUC handled 95778 landings per runway, and 95778 takeoffs per runway last year.
So, MUC seems to have to let more airplanes take off per runway last year than FRA.
Then why do I never hear anything about MUC not having enough runways?
Thanks for any replies!
Cheers, Konstantin G.
TriStar500
RE: When Will T. 3 And New Runway At FRA Be Completed?
Mon Apr 18, 2005 8:00 pm
2009 planned completion of new runway
2012 inaugural of new T3
Subject to changes due to our complicated planning laws and the long-running public participation process.
zvezda
Mon Apr 18, 2005 8:36 pm
How could FRA have 50% more landings per runway than takeoffs per runway? The data are fishy.
intothinair
Mon Apr 18, 2005 9:17 pm
Quoting Zvezda (Reply 2):
This is because FRA has 2 runways where taking off and landing is possible, and 1 runway where only taking off is possible.
I only didvided the total takeoffs and landings by the amounts of runways where taking off/landing is possible.
I'm sure they use one runway where (taking off/landing is possible) they mainly let airplanes land to even out the fact that runway 18 is only used for takeoffs.
So basically, FRA has 2 and a half runways for landing and departing.
Hope this helps.
Thanks for that information Tristar500
fraT
Mon Apr 18, 2005 11:41 pm
If you compare the parallel runways in FRA, they pretty much handle the same amount of landings and take-offs. It's not, that one is for landings and the other one for take offs.
intothinair
Tue Apr 19, 2005 10:32 am
FraT
Yes, you are probably correct on that one.
But I was just wondering, they have runway 18 for takeoffs only, so they have got to let more planes land than takeoff on the parallel runways, or is it because it takes longer to take off than to land, but I can't imagine that this is the reason.
