mariner
A319 Range Question
Fri Apr 22, 2005 4:57 am
I've asked this a few times and I've had different responses. Some of those responses don't tie in with what the aircaft seems to actually do.
So - does anyone know what the effective maximum range of the A319 is? By "effective" I mean in service with a full load of pax and baggage and reserves for an alternate airport.
Example: F9's A319's could make DEN-LIR. But could they make DEN-AUA?
Thanks in advance. And please - not the range of the A319LR used for trans-Atlantic.  Smile
cheers
mariner
aeternum nauta
luisde8cd
RE: A319 Range Question
Fri Apr 22, 2005 5:01 am
I know the A319CJ can fly nonstop CCS-CDG. That's about 4800nm
Fri Apr 22, 2005 8:39 am
Quoting Luisde8cd (Reply 1):
Luisde8cd, did you not read this part? "And please - not the range of the A319LR used for trans-Atlantic"
UAalltheway
Fri Apr 22, 2005 8:47 am
Check this out:
http://www.airliners.net/info/stats.main?id=22
Hope it helps.  Smile It contains some general weight to range ratios and stuff so you can figure that out.  Smile
