lnglive1011yyz
Approvals Needed For First A380 Flight?
Sat Apr 23, 2005 10:55 am
So far we've had our fair share of "what if" posts, "First flight dates.." posts, and "What kind of animal does it look like?" posts, but to this point, no one has asked some obvious questions:
For the first flight of the A380 (and, for that matter, any new airliner not previously produced), here's a few questions:
-=- What kind of paperwork/approvals are needed in order for them (Airbus) to conduct flight test?
-=- Do they (Airbus) need to notify certain governmental agencies?
-=- Does Airbus have a certain region/area that they take the plane to test in? Do they fly over populated areas OTHER than the take off/landing sequences...?
-=- Other than being a well-respected Pilot, do the flight test crew need to be trained in special ways? If so, what?
1011yyz
Pack your bags, we're going on a sympathy trip!
lnglive1011yyz
RE: Approvals Needed For First A380 Flight?
Sun Apr 24, 2005 1:25 am
Can anyone shed some light?
1011yyz
NAV20
Sun Apr 24, 2005 1:39 am
Normally you can't operate any aeroplane unless it has a current Certificate of Airworthiness. Those are issued not by the manufacturers but by government inspectors (from the FAA in the USA).
I don't know what the procedure is for prototypes. Presumably. provided that the inspectors are as sure as they can be that the aeroplane is safe, they issue a limited certificate, allowing the aeroplane to fly in certain zones and in certain ways, limiting the number of people they can carry etc. Then the certificate is gradually up-graded on the basis of successful continued testing.
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
MD11Engineer
Sun Apr 24, 2005 4:09 am
I assume that this plane will first fly under a permit to fly as an experimental, until all the necessarydata has been proven during the test flights (this is what the test flights are for). They will test stuff like low speed behaviour, possible flutter, stall speeds, engine out performance, climb performance, c of g sensitivity, etc. . Once the authories are happy that the plane is fullfilling all the legal requirements, it wil get a type certificate, on which the airworthiness release is based. As an experimental, it can not be used for revenue flights.
Jan
