jimbobjoe
Non-stop Service US To India
Tue May 03, 2005 11:24 am
Hello all,
Having a bit of a discussion over here...my friends claims that there are non-stop flights between the US an India. However, all I find is that CO has the announced EWR-DEL services as of December 31 and that United had planned some services from ORD before 9/11.
I'm just making sure this is indeed the case.
Also, is the EWR-DEL the 3rd longest in the world? Can one of COs 777s do EWR-BOM?
moose1226
RE: Non-stop Service US To India
Tue May 03, 2005 11:44 am
I don't believe that there are any existing services nonstop between the US and India. There are several that may pop up in the near future, however, especially with AI's selection of the 772LR.
I think ETOPS might be a problem over the Himalaylas, though. In the event of a depressurisation, terrain would prevent the aircraft from descending to a safe altitude, or at least that's how I understand it.
TWA902fly
maybe "USA" as in "North America" and YYZ-DEL on Air Canada?
'902
life wasn't worth the balance, or the crumpled paper it was written on
jcavinato
Tue May 03, 2005 12:05 pm
The OAG only shows an Air Canada 343 doing a non-stop Toronto-Delhi (7270 miles) as the only North America - India at the moment. Several one and two stops, though.
ETOPS: A new client of mine is a big aerospace product producer. At an informal lunch I asked someone what ETOPS stood for. The answer: Engines Turning Otherwise Passengers Swimming.
Bit of grim humor, there.
texdravid
Tue May 03, 2005 3:57 pm
Quoting Jimbobjoe (Thread starter):
United planned, but never flew ORD-DEL.
Canada 3000 planned, but never flew YYZ-DEL.
AC flies YYZ-DEL with A343/345. With the 343, sometimes a technical stop in Europe is required. Flight time is 15-16 hours. Favorite flight of the Punjabi/U.P. community in Toronto.
CO's future EWR-DEL flight will be the first U.S. nonstop to India.
CO 772-ER will not have the range with any significant payload to BOM.
If and when they order the 772LR, then they will.
Tort reform now. Throw lawyers in jail later.
TKMCE
Tue May 03, 2005 4:05 pm
Quoting Texdravid (Reply 4):
NO- they flew but very briefly before they went bust.
I am sure about this.
TKMCE
Tue May 03, 2005 4:10 pm
Here is a newslink on the inaugral flight of Canada 3000
http://www.tribuneindia.com/2001/20011011/biz.htm#2
B747-437B
Tue May 03, 2005 4:13 pm
Canada 3000 operated both DEL-YYZ (2x weekly) and DEL-YVR (1x weekly) flights between October 9, 2001 and November 8, 2001.
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
4xRuv
Tue May 03, 2005 10:38 pm
So what kind of AC will CO use?
aseem
Tue May 03, 2005 11:03 pm
Quoting 4xRuv (Reply 8):
B772ER for sure.
I flew AC054/55 during Christmas hols. I had A343 on AC054, that is YYZ-DEL. It did not stop anywhere in Europe due to opening up of Russian Airspace and travel time was 13:30hrs exact. Even though it was a 4 engine aircraft, it still avoided Himalayas. Flew over Hindukush in Afghanistan, right above KBL and entered India near ATQ.
Return leg, that is AC055 from DEL-YYZ had A345, that flew directly over the pole and took 14hrs. Exited India south of ATQ, then right over ISB. Changed coursed up north right over KBL. Cut across Kazakhistan, Russia, northern tip of Scandinavia, north of Iceland and slicing whole breath of Greenland. Finally entering Canada somewhere between Labrador and Northern Quebec.
That's all I did during 27:30hrs of journey.
rgds
VT-ASJ
[Edited 2005-05-03 16:04:25]
ala re ala, VT-ALA ala
clrd4t8koff
Wed May 04, 2005 1:05 am
I'm a little confused about the whole AC routing......AC 54 is an A343 YYZ-DEL, but on the return, AC 55 DEL-YYZ is an A345. So what happens to the A343 after it gets to DEL? Does it turn around and to go YVR or something and vice versa, where does the A345 come from that operates the return flight?
aseem
Wed May 04, 2005 1:21 am
Quoting Clrd4t8koff (Reply 10):
i didn't return by the same plane..stayed there for 3 weeks. Those days they were alternating between A343 and A345
rgds
VT-ASJ
[Edited 2005-05-03 18:22:34]
COEWR787
Wed May 04, 2005 1:27 am
Quoting Moose1226 (Reply 1):
One does not have to fly across the Himalayas on US to India nonstop. The commonly used corridor to/from the Indian subcontinent from the North-West runs roughly Islamabad - Kabul - Termez - Tashkent - Aralsk. Most flights into India from Russia travel along this route and then branch off in various directions. This route crosses the Hindu Kush (not the Himalayas or the Karakorams) between Kabul and Termez. The high altitudes of Hindu Kush are not big enough to be of concern viz-a-viz cabin dpressurization.
As for flying across Tibet, all aircrafts irrespective of the number of engines that they have suffer the "what to do upon accidental depressurization?" problem, since whether a plane suffers an accidental depressurization is independant of the number of engines that it has. The Tibetan plateau is large enough and high enough to make it impossible for an aircraft to descend to the stipulated altitude in the stipulated time in case of an accidental depressurization. Consequently, irrespective of the number of engines, planes flying across Tibet probably would be required to carry additional emergency Oxygen or some such.
Of course there are flights that originate or terminate in Tibet like the flight from/to Lhasa. I don't know if they do anything special regarding emergency Oxygen. However, having flown on the Lhasa - Kathmandu flight (right over Mt. Everest BTW) I found it somewhat amusing that after they closed the doors at Lhasa the plane was pressurized while taxiing to bring it to 7000' pressure. One could feel the added Oxygen  Smile. Lhasa airport is at somewhere between 11,000' and 12,000' or thereabout as I seem to recall.
