andz
What Is Trailing From The Tail?
Thu May 05, 2005 3:13 pm
Check this pic of the 380 taking off for its second flight, what is that thing attached to the top of the tail?
Photo © French Frogs AirSlides
Mir
RE: What Is Trailing From The Tail?
Thu May 05, 2005 3:19 pm
Probably some kind of air data sensor, but I'm not sure of it's function exactly.
-Mir
Kerberos
Thu May 05, 2005 3:30 pm
Looks like someone forgot the dog was tied to the bumper...
Sorry... National Lampoon moment.
This is your captain speaking. I’ve turned off the no-smokin’ sign. Hell, if the plane is smokin' why can't you?
DLKAPA
Thu May 05, 2005 3:39 pm
Quoting Mir (Reply 1):
Actually it measures the wake turbulence behind the tail of the aircraft.
scotron11
Thu May 05, 2005 4:25 pm
Quoting DLKAPA (Reply 3):
Yeah, I read an article how some folk are protesting the expansion of the Airbus facility in Hamburg because they're scared the wake turbulence caused by the A380 will demolish a church which is nearby. Also of blowing tiles off the roofs of houses.
Gee, if it ain't one thing, it's the other!
airbusA346
Thu May 05, 2005 5:31 pm
Heres one on the A318
Photo © Gerd Beilfuss
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
Doona
Thu May 05, 2005 5:34 pm
I remember seeing one on the tail of an A319 at Farnborough a bunch of years ago... never knew what it was though...
Thu May 05, 2005 6:21 pm
Certainly looks like an Airflow sensor.
regds
MEL
aeroweanie
Fri May 06, 2005 1:28 am
Quoting Scotron11 (Reply 4):
Guess again. Its a trailing cone, which provides an accurate static pressure for reducing the flight test data.
Jamie757
Fri May 06, 2005 1:34 am
It's actually an optional bracket that can be used for towing banners. Developed in conjunction with Ryanair.  Wink
Rgds.
"I feel like a turkey who's just caught Bernard Matthews grinning at him!"
Doona
Fri May 06, 2005 1:49 am
Jamie757: Good one...  bigthumbsup
vzlet
Fri May 06, 2005 1:55 am
A trailing cone on an A310:
Photo © Mark Carlisle
And, here's a datasheet from a company that makes specialized air data measuring systems:
http://www.prodynamics.com/pdf/100100_de.pdf
(Some good technical links in the datasheet.)
[Edited 2005-05-05 19:37:17]
"That's so stupid! If they're so secret, why are they out where everyone can see them?" - my kid
curlyheadboy
Fri May 06, 2005 2:01 am
Does this mean that the boom protruding from the A380 tail will go away when flight testing is complete? Hope so, since it's a small feature i don't like too much...
If God had wanted men to fly he would have given them more money...
jamesbuk
Fri May 06, 2005 4:16 am
maybe its if the a380 runs out of fuel theyll refuel it with the boom  sarcastic  lol by the way i was joking does it have to be a certain distance back from the tail
You cant have your cake and eat it... What the hells the point in having it then!!!
aeroweanie
Fri May 06, 2005 5:32 am
Its not really a boom - its a piece of tubing with a cone on the end. On the ground, they hang downwards. It will be removed after flight testing is complete.
andz
Fri May 06, 2005 5:46 am
I wonder why it wasn't there for the first flight....
Photo © Sam Chui
khushdesi
Fri May 06, 2005 5:57 am
i think it's a price tag.
citationjet
Fri May 06, 2005 5:59 am
Quoting AeroWeanie (Reply 8):
AeroWeanie has the correct answer above...
Quoting Andz (Reply 15):
They weren't taking flight test data on the first flight that would require accurate static pressures. Also, the chase plane would provide a cross check of airspeed data.
At Cessna, we never use a trailing cones on prototype first flights.
[Edited 2005-05-05 23:00:06]
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
petazulu
Fri May 06, 2005 6:03 am
I think it is a price tag too! LOL.
OldAeroGuy
Fri May 06, 2005 10:05 am
It's a trailing cone for measuring static pressure remotely from the influence of the airplane. This is necessary to calibrate the airspeed system and the altimeters.
This is more involved than it looks. The cone is to stabilize 150' to 200' of cable and hose that is reeled out when the airplane is on test condition. A length of pipe with flush pressure ports in its sides is spliced into the hose ahead of the cone. Static pressure as detected at the ports is measured by instrumentation within the airplane.
Trailing cones are one of the real pains of flight testing as they frequently break off especially if the airplane is doing stalls or windup turns. When they depart the airplane, you go home because your test day is done.
B737200300
Fri May 06, 2005 2:59 pm
tow drone for aircraft gunners
