snn2003
What Will Happen To The Origonal A380
Fri May 06, 2005 4:55 am
After they are done running tests and they have all the data they need what will happen to it? Think i can get her cheep on ebay?
Gage
One way, IAH-RTB please! No return ticket required.
NYC777
RE: What Will Happen To The Origonal A380
Fri May 06, 2005 4:57 am
I believe it will be refurbished and delivered to either SQ or EK.
That which does not kill me makes me stronger.
AGGoetzfried
Fri May 06, 2005 5:03 am
Noway, this plane will be a part of Airbus' testing center for all days in his life!
snn2003
Fri May 06, 2005 5:07 am
So no ebay, huh? Thats not fair. I prolly only be outbid in the last 30 sec anyway...
columba
Fri May 06, 2005 6:31 am
I read that it will go to SQ.
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
ua777222
Fri May 06, 2005 6:43 am
I thought it was always Airbus' thing to keep the aircraft for their own testing needs. The A340-311, A340-642, all 5 super transporters, Their A318-121, and their loved and very "broken in" A320-111. The A320 is the oldest of the airbus fleet almost pushing 20 years old. I think with the start of a whole new aircraft they will keep it...
Matt
"It wasn't raining when Noah built the ark."
egnr
Fri May 06, 2005 6:56 am
A380 msn 001 will be retained by Airbus as a test airframe. The other 3 test airframes are due to go to Etihad along with a fourth A380 fresh off the line.
7late7, A3latey, Sukhoi Superlate... what's going on?
Nomad
Fri May 06, 2005 6:59 am
AGGoetzfried is correct, it will serve out the rest of its flying days as a test aircraft for airbus ! It will never be sold to any airline !
Nomad  Angry
AeroVodochody
Fri May 06, 2005 7:00 am
Once they're done testing it why keep it? sell it and get all that money back for it(how much do they cost anyway?)
Quoting UA777222 (Reply 5):
A340-642
I'm pretty sure they only kept it because it wasn't suitable for airline use.
Try not to be jealous, we can't all be Czech.
brons2
Fri May 06, 2005 7:01 am
Which frame will participate in the destructive testing?
Firings, if well done, are good for employee morale.
egnr
Fri May 06, 2005 7:57 am
Quoting Brons2 (Reply 9):
Two static frames were/are being used for the ground/destructive testing - msn 5000 and msn 5001.
Quoting AeroVodochody (Reply 8):
That's correct - the first A346 has a cabin door configuration that means it cannot be used for passenger operations with a typical cabin setup - it lacks the overwing emergency exits that are installed on all production A346s.
PM
Fri May 06, 2005 10:00 pm
When are they ever finished testing? Anyway, this kind of thing isn't unusual. I can't check right now but I'm pretty sure Boeing are still flying the first 757 off the line and they certainly didn't ever sell the first 747-100. Conversely, it can cost a company a small fortune to convert a pre-production airframe for sale. After they had finishied testing (I guess there are times when they do) Boeing sold 777 #001 to Cathay but, I believe, it was a struggle (and an expensive one) to make the necessary changes (not least the replacement of PW4000s with Trent 800s).
kc135topboom
Fri May 06, 2005 10:12 pm
Boeing kept the B-367-80, the KC-135/B-707 prototype. They also kept the 1st B-747-100. Both these airplanes had long lives as test airplanes for engines, avonics, etc. They did not keep the first B-727/737/757/767/777. The first B-757 I know was delivered to Eastern after the flight test program. This airplane is now owned by NASA.
I seem to have read somewhere the first A-380 will be used for about 3 years by Airbus before being delivered to it's customer.
PM
Sat May 07, 2005 12:58 am
Quoting KC135TopBoom (Reply 12):
Boeing ... did not keep the first B-727/737/757/767/777. The first B-757 I know was delivered to Eastern after the flight test program.
I think you'll find that 757 #1 is N757A, belongs to Boeing and always has done. 757 #2 went to Eastern and now flies for NASA.
Similarly, 767 #1 (N767BA) is also owned by Boeing and always has been.
N60659
Sat May 07, 2005 1:15 am
Quoting PM (Reply 13):
Based on what Randy Baseler said recently on his blog:
"When we gave birth to the first 757 back in 1981, it set the standard for aviation technology and efficiency. Here's the interesting thing: that very first one didn't go to a customer. It's a Boeing-owned test airplane, still in use today. "
The aircraft (I think) is still parked on the south end of BFI.
Nec Dextrorsum Nec Sinistrorsum
