mrcomet
Cargo Capacity On The 787
Fri May 06, 2005 3:44 pm
I read the NW announcement. In it, B claims its typical 20% fuel gain vs the A330 but then they claim a 45% increase in "cargo revenue capacity". What does this mean? Is it saying the 787 has 45% more volume in its hold than the A330?
The dude abides
777ER
Crew
RE: Cargo Capacity On The 787
Fri May 06, 2005 3:58 pm
Quoting MrComet (Thread starter):
If thats what it says then yes it does
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/75/90,A319/20/21,A332/3,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC,FJ
zvezda
Fri May 06, 2005 4:07 pm
I believe they are talking about cargo by weight, not by volume, but it's really not clear.
ha763
Fri May 06, 2005 5:56 pm
It seems it is 45% more volume. After pax bags for a full flight, the 787-8 can hold 5 pallets and 5 LD3s, compared to only 5 pallets for the A330-200. Taken from each manufacturers' websites:
After allowing for full passenger baggage in containers, the A330-200 offers space for five underfloor freight pallets, more than in the 767s.
http://www.airbus.com/product/a330_a340_freight.asp
Cargo Capacity After Passenger Bags:
5 pallets + 5 LD3s
http://www.boeing.com/commercial/7e7/facts.html
keesje
Fri May 06, 2005 6:28 pm
Any reasonable person would look for what B or A don´t mention in these kind of statements.. Common sense would tell that a longer aircraft usually fits more LD3´s..
These statements are for the general public to create a general feeling about the superiority of an aircraft.
Airlines don´t hear them, A/B won´t come with these statements talking to airlines to avoid looking unprofessional.
QFA001
Fri May 06, 2005 6:35 pm
Quoting Keesje (Reply 4):
You must have missed the B787 cargo thread. The -8 version will carry 28 LD-3s compared to the 26 on the A330-200 or A350-800. The -9 version will carry 36 LD-3s compared to the 32/33 on the A330-300 or A350-900.
Even without counting bags, the B787 has a definite advantage.
Spacepope
Fri May 06, 2005 10:05 pm
Depending on the upwards slope of the rear fuselage this can be misleading. Just compare the underfloor storage of the 747 and the MD-11...
mrcomet
Sat May 07, 2005 6:07 am
Quoting QFA001 (Reply 5):
Thank you for your patience and forgive my ignorance but this still doesn't add up to 45%. I assume pallets are something larger that holds LD-3s. If you have 28 vs. 26 containers or 36 vs. 32 that is about a 10-15% gain.
The dude abides
N1120A
Sat May 07, 2005 6:09 am
The 787's length is not so much what helps it. It is wider than the traditional Airbus widebody.
QFA001
Sat May 07, 2005 7:54 am
Quoting MrComet (Reply 7):
I'm not sure how Boeing calculates their 45% value. For example, it might be payload by weight after bags + pax have been loaded on a 6,000nm trip. I just don't know. However, I think you can clearly see from your own calculations that Boeing will put it in the best possible light for themselves!
Anyhow, with a pending redesign of the A350 tail, Airbus might be able to make up some volume on the new Boeing. FWIW, the reason why the shorter airplane (B787) in this case has more capacity than the longer airplane (A350) is primarily due to the smaller wing box on the B787.
777ER
Crew
Sat May 07, 2005 8:09 am
Quoting QFA001 (Reply 9):
It will involve some type of complicated maths, most likly algabra
QFA001
Sat May 07, 2005 8:55 am
Quoting 777ER (Reply 10):
I don't think it would be too complicated. Anyhow, I thought of an additional item: Boeing would count both the A330/350 and B787 with "long haul rules". It is Boeing's usual practice to then "put" cargo-hold crew rests in the Airbus but have overhead crew rests for their own airplanes (eg. B777/787). That is another 2-4 LD-3s worth of space that would "disappear".
