miafll
SAA Flight Loads
Sat May 07, 2005 11:26 am
Wanted to check the availability of the following South African flights for nn-rev travel.
SA 210-ATL-JNB on March 11 & 12
SA 209-JNB-ATL on March 15 & 16
SA7700
RE: SAA Flight Loads
Sat May 07, 2005 8:28 pm
Miafll
Are these dates correct? Do you actually want to check availability for March 2006? If so, it's a bit too far in the future and the current info will not be of any real value.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
B742
Sat May 07, 2005 8:43 pm
What are the loads like annually LHR-CPT and LHR-JNB?
Rob!
As smooth as silk
SA7700
Sat May 07, 2005 10:08 pm
Taking a wild guess here, but it must be good. Both BA and SA have 2 daily 744 flights to and from JNB.
VS operates 1x daily with an A343, although they switch the aircraft to an A346 or 744 during peak-season or whenever a greater demand for seats exist. That amounts to 5 flights a day between JNB-LHR.
Also don't forget about Nationwide's 3 weekly flights, albeit to LGW, and from what I have heard, they have applied for additional slots.
Between CPT and LHR, both BA and SA operate daily 744 services. During peak seasons, VS also drops in for visits, while BA and SA also operate extra flights. The busiest season is especially from Nov onwards to January when people flock to the coast for lots of sunshine and pleasure.
SA7700
miafll
Sun May 08, 2005 12:44 pm
Sorry the dates are for May not March.
SA 210 ATL-JNB May 11 and 12
SA 209 JNB-ATL May 15 and 16.
dairbus
Sun May 08, 2005 1:05 pm
I can't give you exact numbers because I can only look at codeshare seats but all the flights you asked about are showing good availability. I think you should be able to get on without too much trouble.
"I love mankind. It's people I can't stand." - Charles Shultz
SA7700
Sun May 08, 2005 10:27 pm
SA210 ATL-JNB; 11 May J-class 22 open, Y-class 25 open
SA210 ATL-JNB; 12 May J-class 10 open, Y-class 23 open
SA209 JNB-ATL; 15 May J-class 15 open, Y-class 112 open
SA209 JNB-ATL; 16 May J-class 13 open, Y-class 87 open
SA7700
miafll
Mon May 09, 2005 10:02 am
Thank you vey much for the info!
miafll
Tue May 17, 2005 9:33 am
Ok..we were unable to make the flights due to work schdule..Now trying to see if we have any chance on the following flights:
SA 204 JFK-JNB May 27
SA 203 JNB-JFK June 1
miafll
Wed May 18, 2005 10:07 am
Hey guys
Any update on this?
SA7700
Thu May 19, 2005 5:32 pm
SA204 JFK-JNB; 27 May. J-class Full, Y-class 18 open
SA203 JNB-JFK; 01 June. J-class 19 open, Y-class 168 open
SA7700
