Udo
Emirates Switching To B773ER On Sydney-Auckland
Tue May 10, 2005 12:31 am
Emirates switched equipment on the Sydney-Auckland route from Airbus A340-500 to Boeing 777-300ER.
EK418 DXB-BKK-SYD was upgraded to a daily service on May 3rd and extended to Auckland. EK412 DXB-SYD now terminates at Sydney. Except for Friday (B772ER), EK 418 is operated by new B777-300ER.
http://www.emirates.com/AboutEmirate...esNews/Headlines/bkksydnewrute.asp
Looks like EK was short of capacity once more again...
Udo
Me & You & a Plane Named Blue...
OldAeroGuy
RE: Emirates Switching To B773ER On Sydney-Auckland
Tue May 10, 2005 12:51 am
An interesting point on the EK schedule is that the airplane is on the ground for 1:35 hr. to 1:40 hr. at all stations.
Decent turn times for a 360+ seat aircraft with significant fueling required.
NAV20
Tue May 10, 2005 1:16 am
Thanks, Udo, interesting.
Don't understand your point about being short of capacity, though. I thought the two aeroplanes both carried about the same number of passengers (350-odd)?
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
N60659
Tue May 10, 2005 1:26 am
Quoting NAV20 (Reply 2):
I think you are thinking A340-600 vs 777-300ER. The original post calls for the replacement of the A340-500 with the 7773ER. There is approx. a 100 seat difference between the two.
-N60659
Nec Dextrorsum Nec Sinistrorsum
NAV20
Tue May 10, 2005 1:30 am
Thanks, N60659 - you're quite right, I was misreading the A/C Data stuff.
N60659
Tue May 10, 2005 1:54 am
OldAeroGuy:
On this thread we had the following conversation:
Quoting N60659 (Reply 124):
Quoting OldAeroGuy (Reply 119):
Emirates will be a key indicator. Since they operate the A345/6 and the 773ER, expansion of the orders for either type should say a lot about whether Airbus or Boeing has a winner.
Historically (and by that, I mean the last 6-7 years), EK has always split their orders between Boeing and Airbus and operate aircraft of competing designs from both manufacturers. As a result, using EK as a bellwether to gauge the success of the 772LR may not be completely accurate. Having said that, I fully expect EK to order 772LRs in the near future (possibly at Le Bourget 2005).
-N60659
Quoting OldAeroGuy (Reply 125):
It might be if they don't re-order the A345.
While I do agree with you that not re-ordering the A345 could speak to the success of the 772LR, to me, replacing the A345 with the 773ER speaks even louder to the success of the 773ER/772LR. Would you agree?
-N60659
Rj111
Tue May 10, 2005 1:59 am
Quoting N60659 (Reply 5):
If the A346 was already in the fleet it would probably be flying the route, but for now sound like they need the capacity increase.
They had originally envisioned the 773ER flying the medium haul routes and the A346/A345 taking the long ones. Whether that will differ due to performance changes is not clear yet. The cabins of the two aircraft are currently fitted for these demends at the minute anyway.
Udo
Tue May 10, 2005 2:05 am
They only replaced the A345 on the SYD-AKL leg, not on the nonstop DXB-SYD service.
Udo
OldAeroGuy
Tue May 10, 2005 2:15 am
-N60659
Yes, I do in part as Emirates is able to use the 773ER on routes they did not envision when initially taking the airplane.
The rest of the story would be to have EK buy the 772LR for non-stop flights between DXB and SFO, a route beyond the capabilites of their current A345s.
Udo
Tue May 10, 2005 2:21 am
Quoting OldAeroGuy (Reply 8):
Emirates don't use the B773ER on routes which weren't earmarked for the aircraft - as I said before: the A345 remains on the nonstop DXB-SYD. The B773ER is used on DXB-BKK-SYD and simply got the extension to AKL.
Do you have any numbers on that?
Udo
karan69
Tue May 10, 2005 2:46 am
They do have around 20 odd A346 HGW versions on order, and have stated that they plan to launch DXB-LAX and other destinitions like IAH,BOS.
If the A346 HGW can perform DXB-LAX i am sure it can perform DXB-SFO
OldAeroGuy
Tue May 10, 2005 2:52 am
Quoting Udo (Reply 9):
My independent evaluation, unsanctioned by A, B, or EK, indicates that the 365 tonne MTOW A345 (inservice at EK) carries less than full pass from DXB-SFO. This allows for inservice performance and airline type OEW's. The 772LR under the same circumstances would carry near structural limit payload.
The 380 tonne MTOW A345 will have full pass plus cargo, but EK would need to order this higher MTOW version. This is the basis of my comments about EK's choice on the airplane (A345 vs 772LR) they order to service the USA west coast being an important market indication.
N1120A
Tue May 10, 2005 2:59 am
Not only is this a switch from the A345 to the 773ER, but also the reason EK's 773ERs hold so many is because they are 10 abreast in Y, as opposed to the typical 9 abreast. The A346 cannot take a configuration other than 8 abreast and its 3-class capacity with them will be something more like 280-300
OldAeroGuy
Tue May 10, 2005 3:07 am
Quoting OldAeroGuy (Reply 11):
Self correction:
While Singapore and Air Canada are operating at 365 tonne MTOW, I over looked the fact that Emirates has the A345 at 372 tonne according to Airclaims. With this MTOW, Emirates A345 are DXB-SFO, full pass. plus some cargo. However, the 772LR still carries more pass (larger cabin) and more cargo.
Pesky facts!!
Rj111
Tue May 10, 2005 3:09 am
SQ have the 372t one too.
OldAeroGuy
Tue May 10, 2005 3:10 am
Quoting Karan69 (Reply 10):
The A346 HGW is not a DXB-LAX airplane. The A345 HGW is around full pass. on this route.
N1120A
Tue May 10, 2005 3:11 am
Quoting RJ111 (Reply 14):
Yet it takes major restrictions both routes it flies
Rj111
Tue May 10, 2005 3:14 am
Quoting N1120A (Reply 16):
What's your point?
OldAeroGuy
Tue May 10, 2005 3:17 am
Not according to Airclaims, which shows all A345's except Emirates at 365 tonne MTOW.
N1120A
Tue May 10, 2005 3:19 am
Quoting RJ111 (Reply 17):
What's your point?
My point is, if SQ did have the 372t A345 (which they don't), that aircraft would underperform as compared to the 772LR
Rj111
Tue May 10, 2005 3:30 am
Quoting OldAeroGuy (Reply 18):
Fair enough, FWIW, every time i've heard people mention it on his site they've stressed it's the 372t version.
Quoting N1120A (Reply 19):
Well, that's the first time somebody's ever told me that.  Yeah sure
6thfreedom
Tue May 10, 2005 8:37 am
Quoting N60659 (Reply 3):
I think the main reason for the switch is for additional freight uplift rather than pax uplift.
Also, I would assume it would be cheaper to operate the twin on a 3.5 hr sector rather than the A345.
Finally, the market has significant demand for Y class (both leisure and business travellers, as it's only a 3 hr hop), and the B773ER provides additional Y.
Quoting N1120A (Reply 12):
I knew that the old B773 were 10 abreat, but I didn't realise that EK went for 10 abreast on the B773ER as well. Can anyone confirm?
Richard28
Tue May 10, 2005 8:46 am
sorry mis-post
filll
fill
[Edited 2005-05-10 01:47:22]
777boi
Tue May 10, 2005 8:55 am
Yes, that is correct, they are still 10 abreast in economy. Just flew DXB/BKK/SYD the other day on EBB and EBC. Very nice aircraft. The new first class looks great!
6thfreedom
Tue May 10, 2005 8:59 am
Quoting 777boi (Reply 23):
Is it a comfortable 10 abreast? and what's the seat pitch like?
did you fly Y or J??
I should also point out that the differnt in seats B773ER v A345 is 106.
B773ER = 364 seats
A345 = 258 seats
stirling
Tue May 10, 2005 9:08 am
Quoting RJ111 (Reply 6):
I don't understand.
If they are using it on medium haul, why not use a standard 777-300...Why the "ER"? It's probably a simple answer, but I don't get it
Delete this User
6thfreedom
Tue May 10, 2005 9:17 am
Quoting Stirling (Reply 25):
I suppose it is the sort of aircraft that provides maximum flexibility.
Reasonable aircraft to run on 8-10 hr sectors such as DXB-BKK-SYD, but also provides the legs for longer haul when necessary, as well as opening up new routes. Makes sense to me.
