lazyshaun
Japanese Widebodies On Domestic Routes
Tue May 10, 2005 4:49 am
Hi all,
I would like to know why the two main Japanese airlines (JAL/ANA), use so many widebodies for their domestic routes? Why not just use 737s or 320s for these routes? I know using things like a 757 or maybe 767, but 773 and 744 are too large I think to use on these small routes. This goes for eastern routes in general really, as many eastern airlines use large aircraft for small routes (e.g. Japan to China, Korea, Malaysia, Thailand)
Thanks for any help.
-lazyshaun-
I came. I saw. I conquered
ktachiya
RE: Japanese Widebodies On Domestic Routes
Tue May 10, 2005 4:54 am
I think you might have found a lot of information if you had read other posts on similar topics as this. Although there is a shift to frequency nowadays, think about how congested many airports in Japan are.
NRT only has one long rwy 34L/16R
ITM only has one long rwy 32L/14R
KIX has one rwy 06/24
OKA has one rwy 12/30
NGO has one rwy 18/36
So even if you wanted to get A320 and 737 off the ground on this, this is impossible. Think about the nature of Japanese ppl and look at the island nature of the whole country. Then airtransportation should be the easiest ways of taking you to places.
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
FlySSC
Tue May 10, 2005 5:32 am
Quoting Lazyshaun (Thread starter):
BIG demand + Slot restrictions + economical considerations = Better to use 1 B744 rather than 4 A320.
Doona
Tue May 10, 2005 5:49 am
Japan to Korea? Say, NRT to ICN? A small route? I hope you mean that it is short. The Asian markets are huge! The population centres in Japan, and indeed the rest of Asia, are bigger than Europe and the USA. And since Japan is a pretty small place (geographically), demand for flying from Tokyo to Osaka is pretty huge. And as Ktachiya and FlySSC have already pointed out, since the amount of traffic is still pretty great, larger A/C are needed.
Mats
DAL767400ER
Tue May 10, 2005 6:34 am
Because then you'd see ANA and JAL planes depart every 5 minutes after another on one single route, due to the demand  Wink .
Lurch
Tue May 10, 2005 6:49 am
JAL and ANA use 747-400D D = Domestic which should be a give away as in these machines are specially made to handle a lot more cycles than a standard 747-400 1 take off 1 landing = 1 cycle.
JAL operate 8 747-446D machines and 2 747-346SR machine all on domestic and short routes along with a lot of its old 747-346s.
Also JAL Domestic has a massive fleet made up of a300s 767 777 DC-10-40s and loads of different MDs all on domestic routes!
ANA have 13 747-481Ds and 2 older 747-281SR in service and loads of non er 777s as well
Kahala777
Tue May 10, 2005 6:51 am
Quoting Ktachiya (Reply 1):
Funny ANA and JAL do it daily!
 Wink
Regards - Kahala777
MAS777
Tue May 10, 2005 7:34 am
Malaysia Airlines also uses widebodies on domestic routes with the A330/332, 777 and 744 being flown on domestic sectors.
Carpethead
Tue May 10, 2005 7:48 am
If HND had four runways, then the largest aircraft would be a 767/AB6. Unfortunately, it has only three runways and in essense is only a two runway operational airport. HND-CTS, FUK, & ITM are one of the top three airport pairs for pax numbers worldwide (HND-CTS being #1). ITM is smack in a city with slot limitation not due to congestion but limiting the amount of flights. Other than a handful of trunk routes to FUK, HND, CTS, & OKA, ITM is basically an A320/737 airport.
If Tokyo planners had foresight in the 1960s, they should have built four runways, but they didn't. Thus leading to use of 744D, 773, 772, 763 & AB6 on routes no more than two hours. HND is in all purposes slot limited due to congestion because from 0800 to 2100, there is a steady flow of arrivals and departures. NRT isn't that congested operationally but, the operators are very conservative to slot allocation.
N1120A
Tue May 10, 2005 7:57 am
Which both the 773 and 744D can use for short hauls
Which narrowbodies can use
Quoting Carpethead (Reply 8):
Likely the 747/777 Domestics would still fly in because of demand and seat-mile costs
FlySSC
Tue May 10, 2005 9:28 pm
JAL and ANA were not the only airlines to use widebodies on a Domestic network.
Former French domestic Airline "Air Inter" was operating until the mid-90's a strong fleet of 22 A300 configured in a single 314 Y seats.
Air Inter (IT) was the launch company for the A330-300 and operated up to 4 aircraft, configured in a single 412 Y seats on the biggest routes in France, from ORY to MRS, NCE, BOD, TLS mostly.
All this was before the TGV (High speed train) expansion.
In 1988, IT leased a B747-100 from AF and was operating it from ORY to MRS, NCE and BOD weekdays.
IT was close to make a deal with JAL to buy 3 second-hand B747SR but finally, after strong pressure from Airbus, they bought 4 second-hand A300 (from Dan-Air & Hapag-Lloyd).
Photo © Marc Lehmann
Photo © Alastair T. Gardiner
Photo © Remi Dallot
Photo © Remi Dallot
123
Tue May 10, 2005 10:10 pm
Just check www.amadeus.net for any given Monday, HND/ITM (Haneda, Tokyo, to Itami, Osaka) and you will note the high quantity of widebody frequencies on that one given route. The airlines do that because of slot, yes, but also because normally the loads are really very high. Not to forget, the bullet train that runs paralell I think every 10 minutes. You´ve got a huge quantity of travellers between - in this example - these two cities only.
Different is SDD (Santos Dumont, Rio) - CGH (Congonhas, Sao Paulo), where no widebodies are used probably because of airport / runway capacities, but if you want you can fly just about every 15 minutes between those cities. It´s like hopping on a city bus.
LH takes occasionally a 744 between FRA/BER (TXL) due to high loads, but that is not scheduled, it is normally last-minute adjustment due to demand.
RG use their MD-11 / 777 between POA-GRU-GIG both to meet demand and also as ferry flights, which is same as LB using their 763's between CBB-VVI
