Paint Peeling - Reason
Tue May 10, 2005 9:29 pm
Photo © Peter Unmuth - VAP
Whats the reason of Pain Peeling off from this Aircraft in this manner,Also the Zinc Chromate primer is not Visable.
Could it be faulty Paint application.
regds
MEL
teva
RE: Paint Peeling - Reason
Tue May 10, 2005 10:39 pm
In fact, they tried to wash this plane....  bigthumbsup
Teva
Ecoute les orgues, Elles jouent pour toi...C'est le requiem pour un con
EMBQA
Tue May 10, 2005 10:45 pm
Several things will cause that.....
Contaminants on the surface when the paint was applied...
The primer was too dry or not scuffed before the paint was applied...
The paint was not mixed correctly and was too 'hot'...
wunala
Tue May 10, 2005 11:09 pm
The garage door wasn't fully open when the pilot was parking it.
All the big planes where rubbing its head.
Airplane acne?
Going bald?
Does Becks have a new haircut?
Cost cutting?
I am sure that there are a lot more logical explanations out there.
MD11Engineer
Tue May 10, 2005 11:11 pm
Bad paint job, done on the cheap. I´ve seen planes that were not even primed before applying the top coats. Looks fine for a few months (until the bill is paid) and then the paint will start to peel off.
Jan
Thu May 12, 2005 8:03 pm
They better get it fixed fast.Corrosion would be a problem.
regds
MEL
micstatic
Thu May 12, 2005 8:48 pm
While I'm not an expert at aircraft painting, all I can say is look at the airline. Air France is not known for having cosmetically friendly looking exteriors.
dg
S340,DH8,AT7,CR2/7,E135/45/170/190,319,320,717,732,733,734,735,737,738,744,752,762,763,764,772,M80,M90
Thu May 12, 2005 8:56 pm
Quoting Micstatic (Reply 6):
Exactly.Whats with the Air France Cleaning section.Are they on Strike.Looking at most of their Aircraft,Sure looks like they are.
regds
MEL
broke
Fri May 13, 2005 4:56 am
Zinc chromate contains heavy metals and has not been used in aviation in many years. What is used now is called FR Primer; FR meaning fluid resistant. Another possible cause of the paint peeling, especially at the nose of an airplane is the use of too much accelerator, which is used to get the paint to dry quicker.
Also, if you try to paint an airplane in a chilly environment (roughly below 15 C or 59 F), the paint will not cure, but I don't think that that is the problem with this airplane.
Fri May 13, 2005 1:31 pm
Quoting Broke (Reply 8):
Why only on that location.
Any Link.
regds
MEL
