B742
First Air Canada Jazz CRJ-705 Pic!
Fri May 13, 2005 5:44 am
Here's Air Canada Jazz's first CRJ-705 on the ramp at YUL!
Photo © Eric Fortin - AirImages
Why is an Emirates 777 there?
Rob!
As smooth as silk
ACDC8
RE: First Air Canada Jazz CRJ-705 Pic!
Fri May 13, 2005 6:05 am
Quoting B742 (Thread starter):
Emirates 777-300/ER In Montreal! (by MEL May 12 2005 in Civil Aviation)
Hope it helps!
A Grumpy German Is A Sauerkraut
Blackhawk144
Fri May 13, 2005 6:25 am
So what exactly is a CRJ-705? Is it a CRJ-700 with weird winglets and 2 overwing exits, or what? Hybrid of a CRJ-700 and CRJ-900?
Anthony
Time is the best of all teachers. Unfortunately, it kills all of its students!
ACYWG
Fri May 13, 2005 6:29 am
a CRJ-705, is essentially a -900 that seats 75 instead of 90-100 passengers.
sebring
Fri May 13, 2005 7:42 am
The CRJ-705 has some unique properties that distinguish it from a 900. Not major, mind you, but some winglet differences that are going to be added to the 900. This is almost certainly the first 705 off the line (Fin 701 as seen on the fuselage), which would make it the first 705 going into commercial service anywhere. AC will be flying it between Calgary and Houston.
[Edited 2005-05-13 00:48:57]
[Edited 2005-05-13 00:51:06]
Noise
Fri May 13, 2005 8:49 am
Looks like a toothpick, or a pencil.
Any way, what is the range of the CRJ-705 compared to other CRJ's such as the 700 or 900? How does the range compare to the new EMBs as well?
yow
Fri May 13, 2005 8:22 pm
Given that it's the closest thing, appearance wise, AC will ever come to operating DC-9s again, it's quite fitting to see they chose 700 series fin numbers.
777ER
Crew
Fri May 13, 2005 8:26 pm
Im surprised JAZZ doesn't have ACs new corporate colours
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
jorge1812
Sat May 14, 2005 6:54 am
Why has this one 2 emergency exits when it's for 75 pax only. The normal CRJ-700 has only one and can seat up to 78 pax.
Photo © Georg Noack
Georg.
ac7e7
Sat May 14, 2005 7:41 am
Quoting Jorge1812 (Reply 8):
Jazz's new CRJ-705s are esentially CRJ-900s. They have new winglets and a couple other system upgrades that make the aircraft more efficient I believe. The 705s are just 900s in 78 passenger seating.
RedDragon
Sat May 14, 2005 10:02 pm
Presumably Bombardier was covering themselves to allow CRJ705 operators to fill the plane up with standard CRJ900 seating if they wanted, thereby (amongst other things) I'd guess protecting residual values of the aircraft.
A340Spotter
Sun May 15, 2005 4:41 am
Anyone know if they are planning to run some proving flights from YYC-IAH prior to the start of service, I believe June 1st?
Jeffrey
"Irregardless, it's a Cat III airplane, we don't need an alternate!"
jorge1812
Sun May 15, 2005 5:57 am
Quoting RedDragon (Reply 10):
Thanks for clearing up, this one sounds logical.
Georg.
