r3500vdp
Why Is The UK So Popular For Aircraft Maintenance
Fri May 13, 2005 9:46 pm
Perhaps it's just my perception but for a country where buying a coffee requires you to take out a second mortgage, the UK seems to be very popular for overhaul and maintenance stations for large jet aircraft. There's Southend, Bristol, Manston, Lasham, Kemble and others all providing extensive maintenance, painting and scrapping services for aircraft from all over the world.
BMIFlyer
RE: Why Is The UK So Popular For Aircraft Maintenance
Fri May 13, 2005 9:49 pm
Quoting R3500vdp (Thread starter):
Maybe because we are good at it?  Wink
Lee
paulcaz
Fri May 13, 2005 9:51 pm
Or Because our labour laws let us start and close down easier!!!
Paul Newman Ascot UK
Gman94
Fri May 13, 2005 9:52 pm
The UK has a high amount of expertise in engineering, much like if you want a race car built you come to the UK to build it and if you dont build your race car in the UK the people building them abroad are Brits.
British Airways - The Way To Fly
INTENSS
Fri May 13, 2005 10:37 pm
TPE is one of the best MX centers in the world....if not the best.
-Rich
AvionicMech
Fri May 13, 2005 11:27 pm
As has been mentioned it is just because we are so damn good at it.  Big grin
r3500vdp
Sat May 14, 2005 12:07 am
Thanks and hope you guys stay the best since it makes for good spotting! Mind you I drove a 1983 rover 3500 vandenplas for a while and it kept loosing a lot of those well engineered parts  Silly
AvionicMech
Sat May 14, 2005 12:34 am
Perhaps that is why rover has finally been shut down because they built c**p cars.  duck
leigh pilgrim
Sat May 14, 2005 2:28 am
I have to disagree Im afraid, not the part about being good at Engineering, we are, the problem is, soon the work will be put out to the middle east where the cost of an overhaul is far cheaper than it is here........
I belive the factors are:
1. We (UK) do a fine check over the whole aircraft, every new part gets checked etc, and tested, this does however mean that sometimes things get delayed, and possibly the aircraft on the ground for longer, much to the annoyance of the airline who want the plane in the air. With the middle east, they tend to do the job and no more, and that normaly means the aircraft is out on time, no delays etc.
2. From the above you might think that from the middle east side of things, that the procedure could be dangerous, when you look at aircraft today, they are more 'intelligent' than previous types of aircraft, so if there is a problem, the chances are, things will be OK and the plane can get to the ground. However the risk is, is that if its not OK, that is when you relise safety must come second to money.......................
Just my point of view anyway..........
