nsfguy
Mega Jets... Just More Condensed Misery?
Tue May 17, 2005 7:33 am
Please don't think I'm bashing the 380, personally I hope it makes it. However like the bigger 747 said to be coming out, how will the comfort factor and ease of customer use turn out to be? Used to be quick and simple to board a DC-8 or 707, then got a little more jammed with the wide body tri jets on runs like the "Laker Skytrain" and the crush became really unbearible on the 747 economy with the other 390 people all being checked in by the same number as with the 707's.... about 6-7 agents! Imagine 600 suffering souls trying to mount a mega jet! Mix in all the hassels of TSA, oversized carry on arguments, and the like.... What a pain in the asp this could turn out to be! and wating for your one piece of checked so you can get to the front of the line and clear customs to dodge the crush, while 1500 bags have to go around first? Please for the love of God tell an old man how this is going to be smooth.
dl021
RE: Mega Jets... Just More Condensed Misery?
Tue May 17, 2005 8:35 am
I wonder what preparations the airlines have made for the simultaneous checking in, baggage inspection and boarding of 3 or 4 A-380s at JFK or CDG at once?
Or for them coming in.
It makes no sense to have these aircraft running if they cannot handle the influx and the airlines know it, so does anyone here know what measures have been taken to prevent bottlenecks from arising?
I am wondering about the gates right now. That'll be a madhouse.
Is my Pan Am ticket to the moon still good?
Sabena332
Tue May 17, 2005 8:41 am
Quoting Nsfguy (Thread starter):
Again, Corsair is operating 747's with 380 seats since many years to/from several airports! Has anyone ever asked a similar question about the dispatch of such a flight?
These "The A 380 is too big and carries too many passengers" threads are becoming really boring!
Patrick
Edit: Of course I mean 580 seats in a 747-300!!!
[Edited 2005-05-17 01:44:54]
tackleberry970
Tue May 17, 2005 8:56 am
You make some good points, but I have read where the airports and airlines are having to seriously adjust to the A380. It can only be served by select airports, occupy select gates at those airports and I am certain the airlines will work to get the fastest turn around time they can.
I know that most airports will be serving the A380 with 2 airbridges. One for the lower deck, one for the upper deck. That will basically speed the loading/unloading process greatly.
As for check in and baggage claim, I have not really heard too much about those issues. But I have to assume that they will alter those processes to accommodate the 80.
However, something to remember is that the airport authority, itself, is the ultimate entity responsible for the logistical handling of the A380. The airlines are only the airport authority's lessee.
FriendlySkies
Tue May 17, 2005 9:00 am
Quoting Sabena332 (Reply 2):
Leave it to charter airlines to cram as many seats as possible into a plane...and then some!
AADC10
Tue May 17, 2005 9:31 am
At least initially, the A380 will be quite comfortable, except for Emerates low yield flights between the Middle East and South Asia. Do you think Singapore is going to have crappy economy class?
Since 747-400s are available cheap, lower cost airlines would use them and pack them with tiny seats, while the A380s will be flagship products for the high margin airlines that are ordering them. As more airlines acquire them, they will become hardly different than a 747 now.
nsfguy
Tue May 17, 2005 2:47 pm
580 seats on a 743? you must be on acid!
lnglive1011yyz
Tue May 17, 2005 9:38 pm
Can I ask a question?
Why is it such a hard thing to believe that in the very near future, we can't see that this will be a necessity?
There was no need for a HUGE plane when the 747 came around.. Boeing's research and market teams determined that the best way to move many passengers would be to build a very large plane, bigger than was currently available...
Airbus isn't doing anything new here -- they're just expanding on an already factual set of circumstances. They haven't re-invented the wheel here folks.
1011yyz
Pack your bags, we're going on a sympathy trip!
Glom
Wed May 18, 2005 12:52 am
Quoting Nsfguy (Reply 6):
A 773 can get 550 in high density configuration, but these are for domestic. It's the congestion in immigration/customs etc that is causing the extra concern.
The argument is similar to "What's use in a CATIIIc landing system without a CATIIIc taxi system?" However, I believe that this is a much more manageable issue.
Sabena332
Wed May 18, 2005 1:00 am
Below is a quote from the Corsair Fleet Information Page:
  • 5 x Boeing 747-300
  • 580 seats of which 25 on the upper deck in Grand Large Class
  • Autonomy: 12 ½ hours / 10,000 km
  • Patrick
    CM767
    Wed May 18, 2005 1:08 am
    Quoting Glom (Reply 8):
    Would be good if any one with experience on this flights can tell us, how is the time to embark / disembark on one of the 777 doing the domestic flights in Japan. I am curious also, if they use one or two jet bridges for them.
    The above will gave us an idea of what to expect with the A380, personally I believe that if facilities are well organized there should not be a problem.
    CM767
    But The Best Thing God Has Created Is A New Day
    davejondi
    Wed May 18, 2005 1:19 am
    I think the biggest problem the airports face in accommodating the 380 is the needed changes to current infrastructure (i.e. widening and reinforcing taxiways and ramp areas). Once those problems are solved the other ones will be fixed as well.
    norcal
    Wed May 18, 2005 1:21 am
    There will be growing pains of course, but it won't be the end of the world. Airports will adjust and so will people.
    GDB
    Wed May 18, 2005 2:05 am
    Look at Japan, who have had domestic 747's on internal routes for over 30 years, what are they? 550 seaters at least?
    How do they cope, even allowing that many pax won't have luggage in the hold.
    But they do, and have done for decades.
    Glom
    Wed May 18, 2005 2:11 am
    Quoting GDB (Reply 13):
    The luggage burden is less and their is no immigration to worry about. Not a totally valid comparison. I think it is these things that are causing the concern, not so much the problems with boarding etc.
    tackleberry970
    Wed May 18, 2005 8:43 am
    Quoting Lnglive1011yyz (Reply 7):
    1011yyz
    BRAVO BRAVO...VERY WELL SAID! Thank you.
    exFATboy
    Wed May 18, 2005 8:54 am
    My main worry is baggage claim...the check-in and customs/immigration problems can be handled by simply adding more lanes.
    But unless they develop some method of dispersing the bags across multiple carousels, trying to find your bags is going to be a real PITA.
    How does Corsair do it now with those sardine-can 747s?
    Or do passengers just suffer through?
    I'm guessing the latter, as I'm presuming that Corsair is some sort of discount carrier. (Maybe an unfair presumption on my part...I'm basing that on the the incredibly bad English version of their website - they couldn't pay a college student a few hundred Euros to clean up some of the borderline "Engrish" a little there? And I sure hope that "Grand Large Class" sounds better in French...)
