B742
Why Do Airlines Operate The 333 & 772?
Sun May 22, 2005 11:19 pm
Why do airlines such as Asiana, TG, MH, KE... operate both the A330-300 and 777-200?
They both have almost the same stats, both carry around the same PAX!
Thanks in advance
Also why do carriers like AF choose the 343 and 772?
Rob!
[Edited 2005-05-22 16:20:15]
As smooth as silk
Rj111
RE: Why Do Airlines Operate The 333 & 772?
Sun May 22, 2005 11:37 pm
To cut a long one short...
The A333 is about 10t lighter than the 772ER/772A and burns less on short haul routes. The 772ER has a longer range and higher max payload so is more profitbale on longer routes and obviously can reach more city pairs.
CX only have the 772A because they can't sell them on at a reasonable price due to their a small cargo door which restrics the 777's cargo handling vesatility. The only other airline to operate 772A's and A333's is TG, but they have high density 10 abreast seating so the max pax difference of the two planes is quite different.
AF bought the 777 because they had a lot of deposits for Boeing aircraft (originally 747's but they were allowed to convert them) which they were set to lose if they didn't buy anything. They already had the A343 in the fleet but the 777 came with a better payload/range so instead of buying more 747's - which they had too many of and were inflexiable - they bought the 777 instead. The two planes now have slightly different roles in the fleet.
trex8
Sun May 22, 2005 11:38 pm
AF chose the A343 years before they ordered the 772ER.IIRC they are replacing their A343s with the 772ER and A332.
If its a comparison between the A333 and the 772 (not the 772ER), there is little difference in their specs, but when it comes to the 772ER, it more comparable range wise with the A343.
su184
Mon May 23, 2005 1:03 am
Quoting RJ111 (Reply 1):
Don't forget to add Malaysian, Korean, and soon Garuda.
tsentsan
Mon May 23, 2005 1:07 am
Quoting SU184 (Reply 3):
Quoting RJ111 (Reply 1):The only other airline to operate 772A's and A333's is TG
Neither MAS nor Korean operates 772As. They're all -ERs.
NO URLS in signature
