Chiflyer82
MDW Gate Questions
Wed May 25, 2005 3:45 pm
I just have a question, why were gates A4A/B built? With C8 closed now, that just relocates two gates. Gates A6/A8 had jetways at one point and now these gates aren't being used. ATA started using A10 again but what about A6,A8? When A6,A8 were being used what kind of a/c was able to use them?
WMUPilot
RE: MDW Gate Questions
Wed May 25, 2005 11:05 pm
A6 and A8 can accommodate the 738 and lower. I don't believe that I've ever seen a 757 parked down there as it is a tight fit and the tugs have a hard time backing the aircraft out.
JetBlue - Bringing humanity back to air travel
ScottB
Thu May 26, 2005 4:57 am
To respond to your question about gates A4A and A4B, they were originally planned and built when ATA had much bigger plans for Midway. As the bankruptcy has let to a drastic reduction in their operations, the additional gate space really isn't as necessary as it once was; Southwest now leases six of the fourteen gates originally leased by ATA.
midway7
Thu May 26, 2005 8:18 am
Gates A4A and A4B were also useful when the A Concourse from A8 and up was being built. The way the new Midway was built over the old Midway, the end of the A concourse was the last area built. Gates A4A and A4B were put up some time before this.
Midway 7
