LHB727230Adv
LH Cargo: More Realistic 772LRF Or 747AdvF?
Mon May 30, 2005 10:48 am
As most of us know, LH Cargo is currently looking at the 777-200LRF and the 747AdvF as possible replacements of and additions to their freighter fleet. I've been thinking about this for a while now and was wondering which aircraft suited LH better.
Now the 772LRF has the advantage of being a similar size to the MD-11F which LH currently operates, however, would be an oddball in the fleet (still, LH cargo is known for operating on non-commonality with LH mainline).
LH has been looking at the 747Adv as a gap filler to the A380 and a combined order with 747AdvF would settle commonality issues. Also, the 747AdvF would feature a nose loading door which seems to be an important issue to LH.
As much as I'd love to see a 777 in LH livery, I think they will go for the 747AdvF (assuming it gets launched). Write your thoughts.
Alex  bigthumbsup
FriendlySkies
RE: LH Cargo: More Realistic 772LRF Or 747AdvF?
Mon May 30, 2005 1:37 pm
They already ordered 5 777Fs.
gigneil
Mon May 30, 2005 2:00 pm
Lufthansa? I haven't seen or heard anything about an LH commitment to the 777F.
Perhaps you're thinking of Air France Cargo.
N
FriendlySkies
Mon May 30, 2005 2:11 pm
Oh crap...you're right lol. I can't read!
Leskova
Mon May 30, 2005 3:50 pm
Quoting LHB727230Adv (Thread starter):
Why do you think the B777 will suffer from being an "oddball", while the MD11 does not?
I'm assuming that you think the B777 would have an oddball status because LH pax does not operate B777s, right? True as it is, it still doesn't hide the fact that neither does LH pax operate MD11s - and as you say yourself, LH Cargo "is known for operating on non-commonality with LH mainline", so I really don't see the problem.
They don't seem to be needing the nose-loading capabilities of the B747, otherwise the current standardization on the MD11 wouldn't make sense.
Personally, I see the chances of the B777LRF as quite a bit higher than those of then B747Adv: it's roughly the size of what they have now (a bit bigger, I think), it's not as big as the planes they just got rid of, and, in all probability, it'll be better on the economical side of things.
Frank
Smile - it confuses people!
PhilSquares
Mon May 30, 2005 3:57 pm
Quoting Leskova (Reply 4):
I disagree. LH has wetleased several of their former 747Fs from Air Atlanta Icelandic. These aircraft do provide nose loading where necessary. The lease was specifically to allow LH time to rationalize their fleet.
Fly fast, live slow
PanHAM
Mon May 30, 2005 4:46 pm
They might end up with both. The 777LRF is a good successor for the MD11 and will eventually replace a good number of the 19 MD11 in the LH fleet.
LH does need the nose loading capacity of the 747 as well and the remaining time on the 742's chartered though Air Atlanta is limited. That gap could be filled by 744SF conversions initially but the extra range and extra ca. 20 tons uplift is a clear advantage for the 747ADVF.
The decision for the 777 will not be influenced by what the passenger airline does, the potential fleet size is large enough for a stand-alone. However any 747 replacement will be in line with what LH does.If LH goes for the 747ADV an owned freighter fleet is likely, if not, 744SF leased through Air Atlanta or whomever will be the choice.
powered by Eierlikör
N1120A
Mon May 30, 2005 4:54 pm
Quoting PanHAM (Reply 6):
Those are not nose loaded. They only come SCD. You have to get a fresh 747F to get the nose door
LHB727230Adv
Mon May 30, 2005 5:24 pm
That's what I was trying to say, commonality isn't such a big issue with LH Cargo.
The main reason for LH getting rid of their 742F was to reduce noise levels at FRA. The only reason they aren't buying 744F is that they are too expensive. LH has stated several times that they require a nose door on their freighters.
This is also a possibility, I should have thought of this.
Alex  bigthumbsup
PanHAM
Mon May 30, 2005 5:28 pm
Quoting N1120A (Reply 7):
You are right indeed, I meant the conversions as a stop gap anyhow only.
What they need in first place is a solid profit margin and a better average yield before they make a decison on fleet replacement. I actually don't see that happen this year and I base that on a presentation made by the CFO a couple of weeks ago at the ACD in Frankfurt.
columba
Mon May 30, 2005 6:40 pm
Indeed LH is looking at the 747Adv closely. I always thought that LH would go for the 787 as the next Boeing plane being ordered but now when Airbus improved the A350 I am not so sure about that.
So maybe LH will go for the 747Adv (if it is launched) in both versions as a passenger plane (the gap filler like you mentioned) and the cargo version.
Maybe LH will also buy some 777LRF in addition to that, their biggest competitioner on the cargo market KLM/AF flies already 747-400F and has ordered 777LRF, too.
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
LHB727230Adv
Mon May 30, 2005 7:03 pm
Quoting Columba (Reply 10):
I still think that LH will go for the 787 mainly because Airbus doesn't offer a short-haul version of the A350 and that's exactly what LH needs: an A300 replacement. The 787-3 is perfect for this and the long range versions could be used to replace LH's old A340-311s. So maybe we'll see a large LH order soon: 747Adv, 747AdvF, 777-200LRF, 787-3 and a couple 787-8.
Alex  bigthumbsup
columba
Mon May 30, 2005 7:56 pm
LH said that regarding the 787 that they are mainly interested in the larger version. That is whay I think that the A350 has higher chances. But who knows maybe we see a joint A350/787 order (787-300/-800 and A350-900).
Besides I really like your idea of a large LH order !!!
[Edited 2005-05-30 12:59:23]
LHB727230Adv
Mon May 30, 2005 8:45 pm
Quoting Columba (Reply 12):
Thanks, I just hope that LH will finally decide to buy Boeing again (even though I like Airbus just as much), the 787 is in my opinion a far superior airplane to the A350. Only time will tell.
Alex  bigthumbsup
columba
Mon May 30, 2005 9:35 pm
Quoting LHB727230Adv (Reply 13):
Alex
@Alex
Bruder im Geiste  Wink
Finally someone who has exactly my opinion. BTW nice user name !!
PanHAM
Mon May 30, 2005 9:44 pm
I don't want to be obstrusive, but I do share that opinion and would like to see the 787, 777 and 747ADV become part of the futiure LH fleet.
Glom
Mon May 30, 2005 9:48 pm
LH buy a Boeing? What a breach of cliches! I would like to see the 747ADV go ahead. It would make the Boeing line complete and extensive. Even if Airbus have a bigger VLA, they still have that ominous gap between the A388 and the A346. In this, I hope that LH could help the 747ADV go ahead. On the other hand, I like the 777.
LHB727230Adv
Mon May 30, 2005 11:10 pm
Quoting Columba (Reply 14):
I've always been living in the past, the 727 is still the only real jet for me.
Photo © Joe Pries - A.T. Team
Photo © Michael Mantoudis
Quoting PanHAM (Reply 15):
Quoting Glom (Reply 16):
It's good to know that I'm not the only one hoping for this order.
Cheers to all,
Alex  bigthumbsup
columba
Tue May 31, 2005 1:45 am
Quoting LHB727230Adv (Reply 17):
It is definitely one of the most beautiful airliners ever build, if not the most beautiful ever.
We should open a Club !!!
columba
Tue May 31, 2005 6:05 am
Lufthansa Cargo´s biggest competitors are supposingly Air France/KLM Cargo and Cargolux.
Together Air France and KLM are operating 15 freighters (not counting combis or passenger planes that carry cargo in the lowerdecks). Air France has 8 Boeing 747-200F, 4 Boeing 747-400ERF + 5 777LRF on order. KLM Cargo operates three Boeing 747-400 Extended Range Freighters.
Cargolux has a fleet of 13 B747-400F pure freighter aircraft
Lufthansa Cargo seems to be the only one not operating the 747-400. Their fleet consists of 19 MD 11F which are smaller then the 747s of LH´s competitiors and lack the nose cargo door.
Lufthansa has said quite often that the 747F is too big for them but it seems not too big for its competitiors so I think that we will see the 747 again with LH Cargo either the 747Adv or ex mainline 747-430 Special Freighters (lacking the nose door).
Will be interesting to see how LH is dealing with its competiors fleet wise.
It sure will be an interesting question what new airplane will come next.
I doubt that it will be the A380F, though
[Edited 2005-05-30 23:12:00]
mauriceb
Tue May 31, 2005 6:13 am
those 19/20 747Combi's in KLM are counted together more than 9 full freighters (or more) so why not coun't that to?
besides when KLM thinks its time to replace the 747 fleet (not soon, since they have some of the youngest, but also oldest) they need an aircraft with a rather good Cargo load... and since combi's aren't build anymore its more likely they will order planes like the size of a 787-900/A350-900 and more Pure Freighters....
Glom
Tue May 31, 2005 6:19 am
Incidentally, when is the Paris Airshow? If LH do go for the 747ADVF, could we see an order made then?
A350
Tue May 31, 2005 8:49 am
Another option is to convert some of their 744s to freighters, maybe buy some native 744F for the nose loading. Or look for some more MD11 on the 2nd hand market.
I don't see the need for 777F. It'll be more efficient than the MD11, no doubt, but that will be compensated by the acquisition price.
A350
LHB727230Adv
Tue May 31, 2005 9:58 am
Quoting Columba (Reply 18):
The "LH Should Buy Boeing Club"  Wink
Quoting Columba (Reply 19):
I don't really think that the 747-400SF is a realistic option for LH because as we all know, it still lacks the nose door, so I still think the 747AdvF is a better option.
Agreed. The A380 may be just a little to large for LH cargo and, again, the lack of a nose door would make loading and unloading a rather difficult and time consuming process.
Quoting Glom (Reply 21):
This is what I'm waiting for, a potential LH order at the Paris Air Show, maybe the launch of the 747Adv and AdvF. The show begins (I think) on the 13th of June and ends on the 19th.
Quoting A350 (Reply 22):
As has been said before, LH wants nose doors on their freighters and converted 747-400SFs don't have them. As to the pure 747-400F, LH has stated that they are too expensive to acquire.
LH has just acquired an additional 5 converted MD-11F. The main problem is that there aren't that many second hand MD-11s left and they are difficult to acquire. Adding to that, converted freighters can't carry as much payload as newly built freighters.
This is a general problem between LH and Boeing. LH is put off by the high prices for aircraft at Boeing and thus end up buying Airbus instead.
Alex  bigthumbsup
A350
Thu Jun 02, 2005 1:09 am
Quoting LHB727230Adv (Reply 23):
That's why I suggested to mix 744SFs and 744Fs. I suppose they don't need the nose door every flight. So, they can just send the 744F where the nose door is required. I wonder why no airline to my knowledge did this.
A bit OT: is the main deck of the A300/A330/A340 fuse to small to efficiently haul cargo? Can they haul two pallets parallel? If yes, LH cargo could look for used A340s and convert them to freighters.
A350
zvezda
Thu Jun 02, 2005 1:14 am
Quoting A350 (Reply 24):
No, maindeck of the A340 is not too small to haul cargo. The reason why the A340 is not so used is that it doesn't have the payload capacity (by weight). Perhaps it could be used for packages (e.g. FedEx or DHL) but not for general cargo.
MD 11
Thu Jun 02, 2005 1:31 am
Ehm, perhaps I am not updated lately (sorry),
but I never heard, that LHCargo want to buy new planes other than the MD 11!?
Didn`t they buy some more (used) MD11 just a few months before and didn`t they say that they are completely satisfied with this (great) plane?
I don`t think there is a need for a new plane-type in the LHCargo-fleet. (Although I would love to see the 747Adv in the LH-fleet (Cargo and pax)).
Bye
MD 11
columba
Thu Jun 02, 2005 1:40 am
Quoting MD 11 (Reply 26):
Bye
MD 11
LH Cargo is very interested in the 777LRF but they said they won´t place an order before 2007. They also evaluate the A380F.
clipperno1
Thu Jun 02, 2005 1:43 am
I don't see how current yields would justify a rise of capacity. I've got word from a pretty reliable LCAG that they are not looking for new freighters right now...but it's LH, so you never know.
The way I see it, CX is getting 744SFs to replace 742Fs and AF/KL are getting 772Fs to replace 742Fs as well.
LH Cargo replaced their 742s a year ago when the MD-11 Rollover was completed. Currently they are only using 2 (?) 74Fs on ACMI from AAI for scheduled service and even those are on the way out.
744 will not leave the pax fleet for another 10 years.
But I wouldn't be too surprised to see a order form the joint-venture airline Jade Cargo very soon for new cargo aircraft.
"I really don't know one plane from the other. To me they are just marginal costs with wings."� Alfred Kahn, 1977
bmacleod
Thu Jun 02, 2005 1:45 am
When did LH retire the 742F?
"What good are wings without the courage to fly?" - Atticus
columba
Thu Jun 02, 2005 2:40 am
Quoting Bmacleod (Reply 29):
The last one left the fleet January 2005.
