ChiGB1973
Why No 738 Winglets?
Sun Jun 05, 2005 8:42 am
If there is such a cost saving, why are 738s being built without them. I know the airline has to order the winglets, but why not? The savings is supposed to be tremendous, so much so that WN and CO are adding them aftermarket.
Can the airlines not change an order to add the winglets, are they not concerned with fuel costs, can they not afford the initial cost versus the added fuel costs over the life of the aircraft?
Photo © James Rowson
Just one example, but there are many.
M
S12PPL
RE: Why No 738 Winglets?
Sun Jun 05, 2005 8:44 am
because each airline has to make that choice based on LOTS of facts...like gate space at airports... Sometimes gate space is limited wingtip to wingtip. There are lots of factors to consider.
Next Flights: 12/31 AS804 PDX-MCO 2/3 AS19 MCO-SEA QX2545 SEA-PDX
trex8
Sun Jun 05, 2005 8:45 am
I would think the winglets are more useful on longer flights where there is a prolonged cruise, if you are doing a lot of very short trips, there may be less advantage.
ikramerica
Sun Jun 05, 2005 8:51 am
No according to the manufacturer, as they claim they are great no matter what length of flight...
But also the winglets are supposed to cut down on engine power required for takeoff (and thus noise), so this might be a favorable factor for some airlines with greater noise restrictions.
CPH-R
Sun Jun 05, 2005 8:54 am
Keep in mind that the winglets itself adds weight to the aircraft - so before they can really be seen as effective, the cruise have to be long enough, so the fuel saved is greater that the fuel used to carry the winglets around. Also, I do believe that they do cost a bit to (retro-)fit.
LipeGIG
Sun Jun 05, 2005 9:11 am
Quoting Ikramerica (Reply 3):
Strange Ikramerica. There is a recommended altitude where winglets are more effective and for short trips, it's probably a minor factor as you take a time to get to the cruise altitude and also to land. Gol (G3) LCC received some 738 without winglets and they operated short trips like CGH-GIG, CGH-CWB, CGH-CNF, BSB-SSA, BSB-CNF, BSB-CGH, POA-CWB. Nowadays with longer flights (EZE-GRU for example), G3 added winglets to its most recent 738 fleet.
Any idea of how much adds in terms of cost the winglets ?
Felipe
New York + Rio de Janeiro = One of the best combinations !
Cactus739
Sun Jun 05, 2005 9:18 am
Quoting ChiGB1973 (Thread starter):
I believe they are actually coming installed on all new 737-700 deliveries for Southwest..
You can't fix stupid.... - Ron White
optionscle
Sun Jun 05, 2005 10:52 am
All of Southwests 73G's currently have winglets and all of the factory new planes should be coming installed with them.
The reason that FL didn't get winglets is, indeed, gate space issues at ATL. Like someone said, winglets are only economical on trips above a certain distance in which the fuel savings at cruise are greater than the added fuel consumption due to the increased weight.
-Andrew
ikramerica
Sun Jun 05, 2005 10:56 am
Both CO and WN are getting them new on the 73G for WN and 738 for CO and retrofitting as well. The 736 has just become available with them from B, but not the 739.
http://www.aviationpartnersboeing.com/main.htm
You can either increase TOW from many airports, or decrease engine thrust instead, due to better climb out performance. This can cut down on noise, and fuel use, even for short trips.
Also, approach speed can be slower, again reducing thrust required/noise.
Olympus69
Sun Jun 05, 2005 11:59 am
Westjet is also receiving their -800s with winglets already installed.
CALMSP
Sun Jun 05, 2005 12:07 pm
it makes me wonder if its worth it for WN. With many short hop flights is the fuel savings exceeding the cost of construction and added weight on the aircraft?
je89_w
Crew
Sun Jun 05, 2005 12:18 pm
Funny how Shanghai Airlines only has one B738 with winglets (one of their first delivered), all their other newer B738s don't have any.
Photo © Xiao xiao
N1120A
Sun Jun 05, 2005 2:12 pm
Quoting CPH-R (Reply 4):
Except that after sitting on the sidelines for years, short-haul specialist and ultra-tight fisted Ryanair decided to equip all 738s with winglets
900,000-1 million USD
Quoting Cactus739 (Reply 6):
They are
Quoting OptionsCLE (Reply 7):
Actually, WN has seen savings even on short hauls. This is one of the main reasons FR has decided to add them
Quoting Ikramerica (Reply 8):
but not the 739.
They are available, just not certified yet. The 739X will come standard with them
Quoting CALMSP (Reply 10):
Um, they decided to equip, when all is said and done, close to 400 aircraft with them, so yes, it is worth it. Apparently they are saving on the line of $500,000 per year, per aircraft with that mod. Can't say so much for fuelmizer
Bluewave 707
Sun Jun 05, 2005 6:38 pm
-800s with winglets? I have got these shots over the last year of -800s, now coded as 73H. 738 is reserved for non-winglet -800s.
China Eastern has winglets on their -800s ...
http://www.myaviation.net/search/photo_search.php?id=00301325
and ...
http://www.myaviation.net/search/photo_search.php?id=00359211
Qantas does as well ...
http://www.myaviation.net/search/photo_search.php?id=00362691
As does Air Pacific ...
http://www.myaviation.net/search/photo_search.php?id=00156192
As does ChangAn Airlines ...
http://www.myaviation.net/search/photo_search.php?id=00303831
"The best use of your life will be to so live your life, that the use of your life will outlive your life" -- D Severn
Sun Jun 05, 2005 6:40 pm
If the Cruising time is not long.Why would you want to add to the Weight.
regds
MEL
MEA-707
Sun Jun 05, 2005 8:51 pm
The winglets also became more attractive now with higher fuel costs. So airlines like Ryanair and Continental who earlier decided to ignore the winglet options are now retrofitting their aircrafts because the costs outweighed the fuel benefits back in say 2000 but not now.
nobody has ever died from hard work, but why take the risk?
fly_yhm
Mon Jun 06, 2005 8:49 am
westjet also has winglets
Photo © Andy Vanderheyden
Where will you spend eternity? He,s more real then you think!!!!!
GZIP: Off
