aeropiggot
Rolls To Power New Boeing 737
Thu Jun 16, 2005 9:21 am
It seem that Rolls-Royce is in the running to join the engine offerings on the new Boeing 737 replacement aircraft currently in PD. See the link below:
http://www.thisislondon.co.uk/news/b...mid401266?source=This%20is%20Money
A scientist discovers that which exists, an engineer creates that which never was.
Boeing7E7
RE: Rolls To Power New Boeing 737
Thu Jun 16, 2005 9:24 am
That'll just about cover the 737 replacement rumors.
My hunch is Rolls and GE will have an engine and it will be interchangeable.
LHB727230Adv
Thu Jun 16, 2005 9:26 am
Good news for RR, finally they can catch up in the short-haul market. Also, it gives airlines more options with their engine choice. Very good news indeed.
Alex  bigthumbsup
aa61hvy
Thu Jun 16, 2005 9:28 am
I wonder what will it sound like. I'm guessing somewhere between a 757 and F100. (I'm an engine freak, sorry)
And yes All engines have different sounds  Wink
Go big or go home
DLKAPA
Thu Jun 16, 2005 9:29 am
Quoting Boeing7E7 (Reply 1):
It's already been said somewhere that Boeing will make a Pylon that is compatable to both types, so that an engine conversion can take place in one business day.
Boeing7E7
Thu Jun 16, 2005 9:34 am
I'm thinking it's going to look more like a T-Tail 717/727/MD-80/90 and less like a 737.
Unless they find a way to make a smaller engine and still keep the plane low to the ground for handling.
ACdreamliner
Thu Jun 16, 2005 9:44 am
just wish PW would get back into the market....
Where are you going?
aeropiggot
Thu Jun 16, 2005 9:50 am
You may be on to something there "7E7", remember the 7J7, I believe we may come back to that type of configuration. I could even envision a dual isle version, but very "stubby" looking??  eyebrow
optionscle
Thu Jun 16, 2005 9:52 am
I'd be very surprised to see a T-tail. Look at the A320 family, longer landing gear than the 737 yet I'm sure they still handle fine on the ground.
-Andrew
Boeing7E7
Thu Jun 16, 2005 9:58 am
Quoting OptionsCLE (Reply 8):
They supposedly won't fit under a 320 wing either so we'd be talking 757 height so I wouldn't be surprised at all to see a T-Tail.
ikramerica
Thu Jun 16, 2005 10:01 am
no doubt.
not handling like a car, handling for baggage, etc. The DC9/727/737 etc. design is such that you can load baggage standing on the ground, for more rural areas (very important in the 60s/70s). The A320 is designed higher off the ground for more "improved" airports and terminals.
But I would also be surprised by a T-Tail. B will find a solution that keeps the plane low (though it will be taller than now) but doesn't require a squat engine. A new wing will help.
srbmod
Thu Jun 16, 2005 10:16 am
I wonder if an engine based on the BR-700 family could potentially be that engine. I would love to see them develop a more powerful version of the BR-715, perhaps a BR-720? Or could it be a new version of the Tay?
HermansCVR580
Thu Jun 16, 2005 7:28 pm
Hey its sounding like this could be the super super 727 with a two person flight deck  Wink Any concept drawings of what this plane might look like?? I'm courious about this one Smile
The right decision at the wrong time, is still a wrong decision. "Hal Carr"
Jet-lagged
Thu Jun 16, 2005 7:56 pm
Quoting AA61Hvy (Reply 3):
Like rrrrrrrrrrrrr or zzzhhhhhhhhh or something? Can you describe with letters??
PM
Thu Jun 16, 2005 7:57 pm
If you read the article it's nothing new. Boeing are going to replace the 737 one day. (Hardly news.) When they do, they'll probably offer two engine types. (Not unexpected.) Those types are likely to be from CFM and IAE. (No surprises there.) RR have a stake in IAE.
I don't see it suggesting that Rolls-Royce will have an engine on the next 737 so let's not get too carried away. It just says that both CFM and IAE will be offered. Good news for RR (and PW) but not quite what the title of this thread implies.
What is more interesting is that the source (though not one noted for its insight into the world of aerospace) repeats the rumour that RR may yet end up on the 747ADV.
Revelation
Fri Jun 17, 2005 12:49 am
I haven't thought about it much, but why is mounting the wing on top of the fuselage out of favor for commercial aircraft? I imagine it makes supporting the landing gear more difficult and so may lead to a heavier aircraft, but I'm just guessing.
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
FlyBoy84
Fri Jun 17, 2005 1:44 am
From what I've heard, the 737 replacement will be built in three versions (120, 150, and 190 pax). Therefore, larger and more powerful engines might be fitted to match the planes characteristics since it appears that the engine will be used on a plane with a high degree of variation in lowest to highest capacity (even though composites will probably be extensively used). The 190 pax narrowbody would be about the size of the 757. Wouldn't a larger, more powerful engine and a slightly longer wingspan give the largest narrowbody greater "hot-and-high" performance?
I would think the new plane would stand taller for better engine clearance. I'd like to see this as the 757 is my favorite Boeing. Leave the low riders to the RJs.
srbmod
Fri Jun 17, 2005 2:03 am
Quoting Revelation (Reply 15):
It really only makes sense when the operational profile for the a/c requires good short field performance, which is why the C-130, C-141, C-5, C-17, Do-228/328/328Jet, ATR-42/72, DHC Dash 7/8, Shorts 330/360, Fokker F-27, and Bae-146/Avro RJ for example have high mounted wings. In most of these a/c the landing gear are located in the fuselage like on any other a/c, with the exceptions being the DHC Dash 7 and Dash 8 (Which have main gear mounted in the engine nacelles) and the F-27 (Nacelle mounted engines).
DAYflyer
Fri Jun 17, 2005 2:14 am
Quoting ACdreamliner (Reply 6):
PW is going nowhere on the commercial side anytime soon. They are going to slowly become a strictly millitary provider eventually since they lost out on A-350/787 and A-380/747 Adv. The only thing they have left is narrowbody and millitary applications. What would be interesting is if they can get the engine contract for the new USAF tanker.....
One Nation Under God
F14D4ever
Fri Jun 17, 2005 2:35 am
Quoting PM (Reply 14):
... the source (though not one noted for its insight into the world of aerospace) repeats the rumour that RR may yet end up on the 747ADV.
By repeating this silly rumor, they pretty well solidify their reputation for lack of insight, eh?
But we digress ...
"He is risen, as He said."
PM
Fri Jun 17, 2005 2:39 pm
Quoting DAYflyer (Reply 18):
They did. Boeing selected them for the now defunct 100 767 deal. Might that give them an edge in the next version of this deal?
Quoting F14D4ever (Reply 19):
Indeed.
AirframeAS
Fri Jun 17, 2005 3:15 pm
What happens to CFM in all of this? I think CFM should pitch into the deal with GE and RR to give even more of an option...
PM
Fri Jun 17, 2005 3:39 pm
Quoting AirframeAS (Reply 21):
Er, you know of course that CFM is 50% owned by GE? Just as there is very little chance of an "RR" engine on the next 737 because RR's involvement will be through IAE, there won't a "GE" engine there either because it'll be CFM.
GQfluffy
Fri Jun 17, 2005 3:58 pm
Quoting Jet-lagged (Reply 13):
Nah...I'm sure one will sound like an overgrown lawn mower, and the other like a vacuum cleaner on steroids...
fluffy
This isn't where I parked my car...
AirframeAS
Fri Jun 17, 2005 4:18 pm
Quoting PM (Reply 22):
I learn something new on a daily basis, I didnt know that... thanks for that!
lightsaber
Crew
Fri Jun 17, 2005 11:49 pm
Quoting PM (Reply 20):
Yes. Pratt didn't get "slapped" like Boeing did. But then again, its politics.
By contract, neither RR nor Pratt can build an engine in the 27k to 35k range nor offer an de-rage/enhanced version of an existing engine *without* IAE first declining to build/offer an engine for an airframe. So RR on its own is very unlikely. All reports are IAE. GE wouldn't want to piss of AF, so they'll probably do a CFM engine; but I'm not sure on the details there.
Lightsaber
