JrMafia90
Seat Pitch On Alitalia B777
Wed Jun 22, 2005 10:51 pm
Does anybody know the seat pitch on Alitalia's B777, is it 34"?
TR
RE: Seat Pitch On Alitalia B777
Wed Jun 22, 2005 11:57 pm
Should be 60" in business and 31-32" in economy.
Photo © Daniele Saracco
Photo © Sam Chui
Alitalia744
Thu Jun 23, 2005 12:00 am
In economy there are conflicting reports - some say 31" others 32.
The seats are recaro and drop slightly and slide forward when reclining. Additionally, all economy class seats have footrests under the seat in front of you.
-G
Some see lines, others see between the lines.
JrMafia90
Thu Jun 23, 2005 7:03 am
Thank you guys so much. I didn't think anybody would respond to me. I was on the 777 in August, I just wanted to compare it to US Airways A330. Thank you guys again.
baw716
Thu Jun 23, 2005 5:25 pm
For the record:
I have flown on the AZ 777 to/from Italy a couple of times (MXP and FCO).
Pitch: Magnifica: 55"-60" There is one row at the bulkhead in the rear cabin that has the greater pitch. However, 55 is just fine and the seat, while not the Capri seat, allows for decent sleep and lots of space.
Economy: Seat width: 17.9" Pitch: 32", with foot rests out of the seat legs in front of you. Note: There are some bad seats near the third and rear door exits; the seats are 16.5" v. 17.9" and are VERY uncomfortable. They are there for lav and door access, avoid these seats at ALL COST.
The reason the seat appears to be less than 32" is the width of the seat in Economy. The seat depth (because of the IFE) is almost five inches wide at the top and about three at the lumbar. Also, the seat in its upright position is slightly pitched back about 10 degress. There are a number of other airlines that use this seat (SQ included) designed by Recaro (first time AZ did not use an Italian seat manufacturer for its aircraft).
The illusion, therefore, is that you have less seat pitch at the face, especially when the seat back is reclined in front of you. However, the screens do tilt, so when you recline your seat, you should be able to sufficiently tilt the screen to not interfere with your viewing.
The idea with the Recaro seat is that you are to put the seat back all the way back and be in a semi reclined position for the bulk of the flight. Many people claim that this seat is quite comfortable. Since I have flown only Magnifica, I can speak only to the Magnifica seat.
From an ergonomic standpoint, if you have an aisle seat and the center is empty, then you should have a great flight, no matter what the pitch is on the aircraft. Alitalia did a very good job with the IFE and the seats on the 777; they spared no expense in making the seating and the entertainment system the best there is in the industry, bar none....especially in Magnifica. On demand everything with touchscreen? It doesn't get any better. I'll take AZ to Europe on the 777 any day, in either class.
baw716
fmr SFOUVAZ
fmr Area Manager Northern California
Alitalia (1998-2002)
David L. Lamb, fmr Area Mgr Alitalia SFO 1998-2002, fmr Regional Analyst SFO-UAL 1992-1998
