PADSpot
Raked Vs. Blended Wingtips
Mon Jun 27, 2005 7:37 pm
I just asked myself if the recent switch that Boeing apparently made from promoting blended winglets to raked wingtips (see 777LR, P-8A concept etc) is purely caused be new aerodynamical insight or if it has more an economic reason. Namely that Boeing tries to circumvent the licenses Aviation Partners has got with its blended wingtips technology. Having its own technology should save Boeing some dollars with each airplane they sell.
I am looking forwards to your comments!
Jan
FutureFO
RE: Raked Vs. Blended Wingtips
Mon Jun 27, 2005 8:13 pm
The wingtips on the 767-400 and the new 777's are called straked not raked. I actually like the design of the straked wingtips vs. the blended winglets.
Sean from MCO and MKE
I Don't know where I am anymore
typhaerion
Mon Jun 27, 2005 11:29 pm
I have not yet been through enough aerodynamics to say for certain, but if I had to guess, the aerodynamic difference would be profound. The Blended Winglets do very well to reduce drag induced by wing-tip vorticies by changing the shape of the pressure transition around the wing tips. The "raked" wing-tips that Boeing is promoting with the 777-200LR and 777-300ER are designed to increase the lift the wing produces so as to require less power on takeoff and landing and reduce fuel consumption.
The difference is between lift increasing objects and drag reducing objects. A subtle difference, but that is my take on it. Most of the info I am using to support this came off the Boeing website. I did a search for "raked wingtips" The link is at the bottom. The rest came from my knowledge of blended winglets and their effects from my aerodynamic classes at Embry-Riddle.
So I dont think it was an economic issue, I just think that the winglets that would be required on the 777 would be so big as to have to massively increase the weight of the aircraft due to the materials required to support the wingtip. I would love to see the research behind this technology however. It would be fascinating.
Let me know if this helped any.
Boeing Website Search Results
Edited for content  Wink
[Edited 2005-06-27 16:33:13]
For some, the sky is the limit. For us, it is only the beginning... -- Jack Hunt
gigneil
Mon Jun 27, 2005 11:59 pm
This is the once weekly topic about this.
Lots of very good information exists in tech/ops and this forum about these devices.
N
redflyer
Tue Jun 28, 2005 12:12 am
Quoting Typhaerion (Reply 2):
Why doesn't someone look into adding raked wingtips to other a/c post-production instead of the winglets? I would think if the raked wingtips are more efficient by increasing lift they would be more desirable on the 737NG than the winglets.
Quoting Gigneil (Reply 3):
Why are there some individuals who are so quick to point out that the topic has been discussed previously, rather than contribute something useful to the thread or, even better yet, just ignore it entirely and skip over it so the rest of us can enjoy it? What is the harm done that motivates some to spout off about how the topic has been discussed before?
My other home is in the sky inside my Piper Cherokee 180.
DAYflyer
Tue Jun 28, 2005 12:34 am
I myself wonder if the 737 will ever see these wingtips as opposed to the blended winglets. Are they capable of being retrofitted to older airframes to improve efficiency as well?
One Nation Under God
PADSpot
Tue Jun 28, 2005 7:06 am
Thanks very much for your comment so far !
Quoting FutureFO (Reply 1):
Well ... on its website and there in the 767-400ER article Boeing spells it "raked" wingtips. But I don't want to get into hairsplitting anyway ...
But especially with a long-hauler like a 777LR or 773ER take off and landing accounts for a extremely small portion of the whole flight. Following your argumentation blended wingtips should be better for such a plane then as they reduce drag for the entire flight ??!!
As my question was more about the managerial background of the introduction of the raked wingtip technology I thought it was better placed here.
So has nobody any suggestion as regards this? For my two cents the whole story is more about getting rid of Aviation Partners ... savings in license costs might only be a few ten thousand dollars or even a little more than 100.000 $, but a penny saved is a penny got ...
[Edited 2005-06-28 00:28:05]
DfwRevolution
Tue Jun 28, 2005 8:22 am
Nope, the advantages of raked wingtips are aerodynamic and structural, nothing to do with Aviation Partners.
You should heed Gigneil's advice, but here's the tip versus winglet nutshell:
They create virtually the same result, but wingtips do not require wing reinforcement as winglets do. When aircraft like the 744 and 737NG have winglets installed, wing reinforcements must be installed as well. This makes the airplane heavier for the same fuel savings effect. In a longhaul airplane, eliminating a few hundred pounds of additional weight is big savings.
Aircraft like the commercial 737NG are unlikely to ever have raked wingtips because they take up more gate space than blended winglets. This isn't so much a problem for large longhaul airplanes, but for small aircraft trying to fit into constrained gates, it is a major consideration.
