c172
5 Engine 747!
Wed Jun 29, 2005 6:25 pm
While at LHR I witnessed a classic 747 with 5 engines. The extra engine was located near the port wing root. Can anyone clue me in?
glidepath73
RE: 5 Engine 747!
Wed Jun 29, 2005 6:28 pm
This was a spare part engine for an other a/c. The 747 has a fifth pylon hardpoint to hang a fifth engine on the wing. (Just for transport reasons)
Patrick
Aviation! That rocks...
flybeq400
RE: 5 Engine 747!
Wed Jun 29, 2005 6:29 pm
That is the method for shuttling extra (spare) engines for planes which need a replacement for maintenance reasons in a location without spares on site, as far as I know.
c172
RE: 5 Engine 747!
Wed Jun 29, 2005 6:30 pm
This one was running, though. Exhaust and heat and everything.
OHLHD
RE: 5 Engine 747!
Wed Jun 29, 2005 6:31 pm
747 can transport a spare engine under its wing. If you search you will find some pictures.
Here is one.
http://www.airliners.net/open.file/635769/M/
Like this it is much cheaper to transport it instead of sending via a cargoplane.
EGTESkyGod
RE: 5 Engine 747!
Wed Jun 29, 2005 6:32 pm
They were at one point testing the A380 using a 747, as its the closest thing around to the A380. Also sometimes they whack a 5th engine on the wing to ferry it around.
I came, I saw, I Concorde! www.gofundme.com/lineupandwait
CV747
RE: 5 Engine 747!
It's a poded spare engine.
Boeing and Douglas have offered this option to transport spare engines for long time. I have pictures of 707, DC-8 and 747 with a poded spare engine.
It's rarely used but looks really cool.
EGTESkyGod
RE: 5 Engine 747!
Wed Jun 29, 2005 6:36 pm
FrancoBlanco
RE: 5 Engine 747!
Wed Jun 29, 2005 6:38 pm
Sorry I have to say that, but the spare engine definitely cannot be running in this position.
Maybe you just confused the exhaust heat from the other engines or the APU.
Sebastian
'Pointless!' - NY Times
jeb94
RE: 5 Engine 747!
Wed Jun 29, 2005 7:04 pm
Um...hate to say it but no way could it be running. There aren't any fuel hookups for the podded engine afterall.
777ER
Head Moderator
RE: 5 Engine 747!
Wed Jun 29, 2005 7:13 pm
Correct me if I'm wrong, but the pod is only on classic B747s, no B744s have it
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/75/90,A319/20/21,A332/3,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC,FJ
UAL747
RE: 5 Engine 747!
Wed Jun 29, 2005 7:18 pm
You're wrong....
Photo © Steve Ruttley
UAL
UpperDeck79
RE: 5 Engine 747!
Wed Jun 29, 2005 7:26 pm
Pardon my ignorance, but why couldn't you just put the 5th engine in the cargo hold...? Doesn't it produce a lot of extra drag while hanging from the wing?
AY and ANA rock!
David L
RE: 5 Engine 747!
Quoting UAL747 (Reply 11):
You're wrong....
Are you sure it's not a Classic ferrying an engine and a winglet for a 400?  Smile
RichardPrice
RE: 5 Engine 747!
Wed Jun 29, 2005 7:36 pm
Quoting UpperDeck79 (Reply 12):
THe engine is essentially a straight through thing, the air jsut goes straight through it so the drag isnt as high as you might think.
Putting it into the cargo bay means you loose that cargo space for paying customers.
jeb94
RE: 5 Engine 747!
Wed Jun 29, 2005 7:39 pm
That and the passenger carrying 747 doesn't have a door big enough to fit an engine of that size into it. They do suffer a drag penalty (the core and fan do create drag) but its cheaper than chartering a cargo aircraft that has a large enough door to fit the engine in.
HT
RE: 5 Engine 747!
Wed Jun 29, 2005 7:50 pm
Sure it does produce a lot of drag, but this procedure was established a long time ago taking the following points into consideration:
  • Usually the spare engine needed a some airport was attached to an a/c flying this route anyhow (i.e. carrying pax or similar) - so it was not sent onto an almost empty ferrying flight.
  • By the time the big engines for the likes of B747 / DC10 / L-1011 were introduced, reliability of these engines was considerably lower than nowadays. So it was much more likely that an a/c got stranded at some remote spot (w/o proper m/x) and that a spare engine had to be flown in.
  • Back then, dedicated cargo-a/c usually were not able to accomodate a spare engine for a B747 w/o some kind of dismanteling due to size restrictions. Therefore it was easier (and faster & cheaper) to put that engine to be transported under the wing.
Today, this procedure is used much less. Engines have become much more reliable; engine shops have been set up at more airports - and not every airline stops flying its B744 once one engines quits in flight, but continues its transatlantic crossing to LHR  Smile
-HT
UpperDeck79
RE: 5 Engine 747!
Wed Jun 29, 2005 7:51 pm
Quoting Jeb94 (Reply 15):
Ah, there's the answer! Thank you.  Smile
AY and ANA rock!
777ER
Head Moderator
RE: 5 Engine 747!
Wed Jun 29, 2005 7:53 pm
Thank you
atco2b
RE: 5 Engine 747!
Wed Jun 29, 2005 7:55 pm
Can they be used on flights with pax?
Hey, you want to go out for pizza and some sex? What, you don't like pizza?
NZ1
Head Moderator
RE: 5 Engine 747!
Wed Jun 29, 2005 7:58 pm
Quoting 777ER (Reply 10):
Fifth pod is available on all 747 series, but only RR engines can be fifth podded, as far as I know.
It won't fit through the door opening.
NZ1
NZ1
SA7700
RE: 5 Engine 747!
Wed Jun 29, 2005 8:12 pm
SA ferrying a 5th engine from MIA on the 744.
Photo © Don Boyd
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
RE: 5 Engine 747!
Wed Jun 29, 2005 10:02 pm
Photo © Anthony Jackson
Photo © Micheil Keegan
Photo © Michael Hojbjerg
Photo © Paul Spijkers
Photo © Bill Sheridan
Engine Ferry.  bigthumbsup  Ideal way unless you have a B747F.
regds
MEL
B747-437B
RE: 5 Engine 747!
Wed Jun 29, 2005 10:07 pm
Quoting NZ1 (Reply 20):
Not true. Air India has ferried JT9Ds as 5th pods multiple times that I am aware of, including on the ill-fated AI 182 in 1985.
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
akelley728
RE: 5 Engine 747!
Wed Jun 29, 2005 10:51 pm
Quoting Atco2b (Reply 19):
Yes
lhrstu
RE: 5 Engine 747!
Wed Jun 29, 2005 11:07 pm
Does anyone konow if the A380 will have the same capability?
whitehatter
RE: 5 Engine 747!
Wed Jun 29, 2005 11:20 pm
Quoting Lhrstu (Reply 25):
I wouldn't think so, fifth podding is a practice which was developed in the 1960s and 70s when there was not as much civilian heavy lift capability around.
The Vickers VC-10 can also do podding but the spare Conway engine is enclosed in an aerodynamic case and mounted underneath.
Nowadays the Antonovs, 747F and even civilian Hercules aircraft do engine ferrying. There is also a considerable increase in interline spares swapping so a stricken aircraft can often be fitted with a motor supplied by another airline if available locally and faster. This is complicated by the more recent factor of engine leasing being separated from airframe in many cases.
Lead me not into temptation, I can find my own way there...
AR1300
RE: 5 Engine 747!
Wed Jun 29, 2005 11:48 pm
You're wrong....
Why??Could be only windmilling.Sure the fans will spin with all that air going thru them....
Mike
You are now free to move about the cabin
ebj1248650
RE: 5 Engine 747!
Wed Jun 29, 2005 11:49 pm
I suspect that the heat you saw was exhaust from the nearest running engine or set of engines. Wind can blow that around under and airplane where you can be misled as to what's really going on.
Dare to dream; dream big!
citationjet
RE: 5 Engine 747!
Wed Jun 29, 2005 11:50 pm
The 5 engine 747, not to be confused with the 3 engine 747.  Wink
Photo © Norman Gage
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
speedbirdegjj
RE: 5 Engine 747!
Thu Jun 30, 2005 12:13 am
Quoting AR1300 (Reply 27):
You're wrong....
Mike
UAL747 was referring to Reply 10 questioning whether this applied to -400's or only classics!!.
F14D4ever
RE: 5 Engine 747!
Take a close look at the SA and Qantas engine ferry pix; they both have a toric insert to block flow into the core. Now look at the Aer Lingus ferry; it has a hemispheric insert, completely covering the spinner, to block flow into the core. These devices greatly reduce drag. They not only reduce friction drag due to flow through the core, but they effectively reduce capture area, causing more air to 'spill' out around the nacelle rather than entering the inlet.
"He is risen, as He said."
drinkstrolley
RE: 5 Engine 747!
Thu Jun 30, 2005 4:25 am
Quoting UpperDeck79 (Reply 17):
What about the 747 where the nose lifts up to give access?
joshdean
RE: 5 Engine 747!
Thu Jun 30, 2005 4:56 am
Quoting Drinkstrolley (Reply 32):
Well that's a freighter, but the discussion here is about fixing it to the wing so you don't have to pay a load of money to put it in a freighter...
jeb94
RE: 5 Engine 747!
Thu Jun 30, 2005 5:43 am
I never noticed the inserts before. That's cool! Keeps the air from flowing through and prevents windmilling. Windmilling an engine isn't the best thing for its longevity afterall.
aak777
RE: 5 Engine 747!
Thu Jun 30, 2005 7:48 am
Not only B747s, heres the good old Tristar with 4 engines.
Photo © Christos Psarras
N766UA
RE: 5 Engine 747!
Thu Jun 30, 2005 8:27 am
Yeah that 5th engine definately wasn't running. You probably just saw it windmilling and noticed exhaust from the #2 engine.
airxliban
RE: 5 Engine 747!
Thu Jun 30, 2005 9:15 am
Quoting B747-437B (Reply 23):
On 744s can the CF6 and PW4000 engines be podded as well as the RB211s?
blue787
RE: 5 Engine 747!
Thu Jun 30, 2005 12:44 pm
Regretably an engine(PW4000,GECF6 or RB211) would not fit in the lower cargo hold as in a 744. unless it was a 74F in which case it will travel main deck, or a combi.Once again main deck.Regards
KAL_LM
RE: 5 Engine 747!
Thu Jun 30, 2005 12:49 pm
Drinktrolley wrote: "What about the 747 where the nose lifts up to give access?"
Even though we're not talking about freighters, just as an aside, the engine won't fit through the nose, it's too tall and wide. Will only fit through the side door. It is pretty interesting to do that though as they (the engines) have their own mounting rack and you just slap it on a pallet (albeit a 20ft. ULD) and tie it down and swing it inside. But as noted previously, the reason to pod the engine is to not have to either a.) charter a freighter if you don't have one, or b.) don't want/can't divert one of your own freighters to get it done.
is that a light at the end of the tunnel or just a train?
vh-mdk
RE: 5 Engine 747!
Thu Jun 30, 2005 1:41 pm
From a QF Lame:
"A Boeing 747 can have a 5th pod attatched if there are fittings on the wing. The only Engines that can be 5th podded are RB-211 all varients, and P&W JT9's
Any Engine can be put into the cargo hold, as long as the engine is split, ie a GE is split into 2 with the fan case being dissasebled and the core engine. It will then fit into the cargo hold"
Those two photos show VH-EBY carring an extra engine to Auckland on the normal QF43 run.
LPLAspotter
RE: 5 Engine 747!
Thu Jun 30, 2005 3:14 pm
I flew a TP L1011-500 which was ferrying an engine as Aak777 pointed out. The flying time to BOS from TER was the typical 5 hours or so, so I don't think drag was significant issue.
LPLAspotter
Nuke the Gay Wales for Christ
RE: 5 Engine 747!
Thu Jun 30, 2005 4:07 pm
How much drag would the Ferried Engine cause.
regds
MEL
BWIA 772
RE: 5 Engine 747!
Thu Jun 30, 2005 4:12 pm
Can the 340 carry an extra engine.
Eagles Soar!
jumpjet
RE: 5 Engine 747!
Thu Jun 30, 2005 5:37 pm
I once saw a Saudi Arabian L1011 Tristar land at LHR with an extra engine slung by the port wing root. It looked really odd from directly in front as it was on final approach and certainly made my day!
airforum
RE: 5 Engine 747!
Thu Jun 30, 2005 6:01 pm
hmmm AFAIK they usually fly at lower speed when carrying an extra engine (compared to a regular flight)
What goes up, must come down. Let's hope the sky never went up.
Lucifer
RE: 5 Engine 747!
Thu Jun 30, 2005 6:59 pm
You probably saw additional heat exhaust from the air conditioning packs, which are in the belly of the aircraft.
sincil
RE: 5 Engine 747!
Thu Jun 30, 2005 10:20 pm
Quoting Aak777 (Reply 35):
And the 707 also! Though it's placed in an aerodynamic pod:
Photo © John Kelly
UpperDeck79
RE: 5 Engine 747!
Thu Jun 30, 2005 10:45 pm
Quoting Sincil (Reply 49):
Looks like a missile or something!
AY and ANA rock!
aak777
RE: 5 Engine 747!
Thu Jun 30, 2005 11:40 pm
Quoting BWIA 772 (Reply 45):
I bet it can carry a dosen of them in the cargo bays.  Big grin
No offince airbus lovers. I love airbusses too.
