bkkair
Finally! Johannesburg-Bangkok Nonstop On TG A346
Fri Jul 01, 2005 10:30 am
About 3 years after SA stopped service JNB-BKK on their 747SP's, TG is resuming the service 3 Dec on their new 3 class A340-600. This will probably be a code-share flight with SA as SA is going into the Star Alliance.
Schedule:
BKK-JNB 0015 - 0620 Monday, Wednesday, Saturday
JNB-BKK 1345 - 0545 Monday, Wednesday, Saturday
HB-IWC
RE: Finally! Johannesburg-Bangkok Nonstop On TG A346
Fri Jul 01, 2005 11:15 am
TG had first announced that this service would run with MD11 equipment. I guess they've come to their senses and realized that the MD11 in the configuaration it is right now is not really the appropriate equipment to market this new service with. Still, I will only believe this when I see it, as TG has previously several times announced this service - last time around they talked about daily B744 service. Nevertheless, the schedule's being published seems to be an indicator that they're really planning to start this time.
6thfreedom
Fri Jul 01, 2005 11:16 am
I thought that this was going to be an MD11 service.
With JNB, MEL and AKL listed as getting the A346, does anyone know on which routes the MD11 will be redeployed??
ZK-NBT
Fri Jul 01, 2005 12:46 pm
Hi from Sunny Fiji!  Smile
I hope AKL is still getting the A346? They are only getting 6 and I had heard that AKL would go daily at the end of this year.
6thfreedom
Fri Jul 01, 2005 12:58 pm
M*W*F** 6:30p BKK 1 10:30a+1 AKL I TG 989 Non-stop M11 11:00 Effective Jul 18
By the looks of things, I'm guessing BKK-AKL will probably go daily with the refurbished MD11.
Not a bad move IMO.
It looks like AKL will be delinked from both SYD and BNE by Feb 2006.
At around 285 seats, I think TG will do well on non-stop services.
karan69
Fri Jul 01, 2005 5:38 pm
What i dont understand is why is there a nearly 7 hour layover at JNB airport??
ZSOFN
Fri Jul 01, 2005 6:31 pm
Quoting Karan69 (Reply 5):
Probably to suit business needs. Look at the schedules from JNB to Europe - you will generally see 2 BA 744s, a VS bird plus many other european carriers sitting on the stands ALL day. That's a lot of down time!
artbkk
Fri Jul 01, 2005 6:51 pm
To facilitate connection to/from other part of Asia.From other part of Asia, pax can connect easily to the BKK-JNB midnight flight. On the return flight, pax can connect with TG morning flight in BKK to almost all Asian destinations. This schedule also makes it possible for codesharing an onward flight with SAA.
Most of TG's european flights are also scheduled this way.
[Edited 2005-07-01 11:53:06]
AF022
Fri Jul 01, 2005 7:52 pm
this may put a damper on EK's service from JNB. EK needs more competition from JNB!
SA7700
Fri Jul 01, 2005 7:57 pm
Quoting ZSOFN (Reply 6):
Correct.
Should TG have a 2-hour layover and depart JNB at 08h20, I predict (IMMHO) that they will have quite poor loads. JNB is SAA's hub and TG needs connecting pax from regional and domestic flights in order to fill their flights to capacity.
The first domestic flights of each day (CPT, DUR, PLZ, etc) only arrive in JNB at about 08h00. Therefore a 08h20 TG departure wouldn't make sense at all. TG needs to synchronise the entire operation very carefully as they also have to keep connecting pax, onwards from BKK in mind. Would it make sense to leave JNB at 08h20 and arrive in BKK just after 00h00?? For instance, how many TG flights leave BKK at that time of the morning - we have to take in consideration that BKK may not be some passengers' final destination?
Have a look at the rest of the Asian carriers operating to and from JNB. Despite early morning arrivals in JNB at about 06h00; CX, SQ and MH all leave JNB after 12h00.
Hope this explains your query.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
Udo
Fri Jul 01, 2005 8:10 pm
Quoting AF022 (Reply 8):
How would that affect EK? They come from completely different directions.
Udo
Me & You & a Plane Named Blue...
SA7700
Sat Jul 02, 2005 1:11 am
Quoting Udo (Reply 10):
EK currently is the cheapest option between JNB-BKK-JNB, which may be what AF022 is referring to. However, TG will not necessarily be the cheapest option between JNB-BKK-JNB once their services commence.
That said, even though SA and QF fly directly to PER and SYD respectively, EK still whip their buts with excellent fares most of the time.
SA7700
B742
Sat Jul 02, 2005 1:15 am
Quoting 6thfreedom (Reply 2):
TG is planning to serve DME with the MD11!
Good to see the 346 in JNB!
So AMS, JNB, ZRH and MEL will get the 346, where else?
I heard LAX will also receive the 346, or will it be the orginal plan for the 345?
Rob!
As smooth as silk
SA006
Sat Jul 02, 2005 2:35 am
Great news! Good to see someone taking the great emand for the BKK-JNB-BKK route.
-SA006  wave
Proudly South African
dutchjet
Sat Jul 02, 2005 2:41 am
Its good to see that TG will use its new A340-600s on this route, I found the original choice of the MD11s a bit odd for a route such as JNB-BKK. AMS, AKL, MEL, ZRH, CDG and even LAX were once mentioned as A346 cities - the new JNB flight operating with the A346 may impact these plans as, I believe, that TG has ordered only 6 of the type and the European routes require 2 aircraft to maintain a daily service.
Any further information on how TG plans to utilize its A346s and the M11s? Will AKL remain with the M11 once it gets its dedicated flight from BKK?
airkas1
Crew
Sat Jul 02, 2005 7:58 am
Quoting B742 (Reply 12):
TG is gonna fly to AMS with the 346!?
Airliners.net Crew - Head Photo Screener
dutchjet
Sat Jul 02, 2005 8:06 am
Quoting AirKas1 (Reply 15):
There have been several reports/rumors that TG wants to reopen the AMS route, this time with a daily dedicated nonstop service to BKK (unlike TG's past services which had been via ZRH or as a stopover on a LHR-AMS-BKK flight)......I have heard that TG is/was planning to reopen the AMS route WHEN the A346s were delivered (meaning that the AMS-BKK flight could be flown with any longhaul type and TG was simply waiting for more longhaul equipment to be delivered), and I have also heard that TG is/was planning to reopen the AMS route WITH the A346 once they were delivered. I have no idea which is true, and, to date, TG has not announced the AMS route but instead has said it would begin service on the BKK-JNB route and the BKK-Moscow route.
Something is up - TG does want to get back to AMS - when, and with what equipment are still up in the air.
6thfreedom
Sat Jul 02, 2005 8:21 am
Quoting Dutchjet (Reply 16):
I think that the only thing that IS CERTAIN is that it is currently a movimng feast, and likely to change.
Given that the A346 has a big F/J section (68 seats), you can probably bet that the A346 will go to markets which has higher J class prospects. Therefore MEL would rank up there, and I would guess would get the A346 at AKL's expense. With only 6 A346's, not every proposed A346 market will get one.
FYI - MEL can be operated on a daily basis with one aircraft.
BKK 0015
MEL 1205
MEL 1620
BKK 2240
malaysia
Sat Jul 02, 2005 8:39 am
Nothing beats a South African 747-SP to BKK from JNB lol
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
SA7700
Sat Jul 02, 2005 5:59 pm
Quoting Malaysia (Reply 18):
I couldn't agree with you more! It seems as if SA now wants to revive the JNB-BKK-JNB route themselves, according to newspaper reports. There is a 747-SP in SA colours parked on the Eastern side of JNB at some of the maintenance hangers.....................
SA7700
