mozart
Corsair 747-400 - Which Routes?
Sat Jul 02, 2005 4:15 pm
Is there any route in the Corsair network that sees the 747-400 on a regular basis, or is it used on routes which see a mix of 747-400 and 747-300s?
Thanks for info
corsairf/a
RE: Corsair 747-400 - Which Routes?
Sat Jul 02, 2005 10:16 pm
For the summer the B747-400 fly to FDF and PTP only.
INNflight
Sat Jul 02, 2005 10:20 pm
Quoting CorsairF/a (Reply 1):
Thanks, FDF is Fort de France I guess? The mouse-over doesn't work.
Jet Visuals
B742
Sun Jul 03, 2005 12:08 am
Quoting INNflight (Reply 2):
correct!
I'm surprised Corsair only use their 744's to FDF and PTP!
When is F-GTUI going to be painted into the Corsairfly.com livery like on F-HSUN?
When are the next 744's arriving, isnt one currently in JNB?
Also when are the 330's due to be painted?
Rob!
[Edited 2005-07-02 17:09:04]
As smooth as silk
corsairf/a
Sun Jul 03, 2005 2:33 am
F-HSUn should arrived mid July. FDF and PTP cause flights are pack with local going back for holiday.
FCKC
Sun Jul 03, 2005 2:58 am
F-HSEA , this which is at JNB actually , will follow F-HSUN , probably at the end of this month , or in August.
The two last ones (F-GRUN and F-GPTP) will certainly be outfitted at JNB too.
744 are also employed on Marrakech route for the summer time.
N1120A
Sun Jul 03, 2005 3:45 am
Quoting B742 (Reply 3):
Why shouldn't they? They are long haul and have heavy loads. Perfect use for their limited fleet (2 right now). Marrakech is a good rotation to keep the plane in the air
Hopefully never. This whole _fly concept is just plain lame
quebecair727
Sun Jul 03, 2005 7:21 pm
She did PTP-YUL-ORY the other day.
mauriceb
Sun Jul 03, 2005 7:34 pm
is it correct that Corsair only took 4 ex-UAL 747's? so than it will only be for replacement and not for growth?
FCKC
Tue Jul 05, 2005 3:27 am
FRESH NEWS
F-HSEA will arrive at Orly between Jul 8th and Jul 11th.
This will be the third 400.
F-HSEX (and not F-HSUN which is already in service) will arrive very soon too.
JMO-777
Tue Jul 05, 2005 3:51 am
Isn't Corsair also flying their 744s to RUN?
Or was it only until July?
Jan
~~~ Fly with a Triple Seven and you feel like in heaven ~~~
FCKC
Tue Jul 05, 2005 6:08 am
Not yet to RUN.No doubt they will fly there with these 400s.
For the moment , they fly to PTP , FDF , SXM ,RAK.
