PILOTALLEN
Falcon Biz Jet Question
Sun Jul 03, 2005 7:48 am
Hi,
I work the line at a large FBO in MA, I have been meaning to ask pilots these questions bu so far I haven't remembered. Anyway I notice that there are two different models of the Falcon 10/20 the 100/200....is there a difference? Also if anyone knows....whats the purpose of opening the captains window once they shut the engines down? (I am assuming to assure the pressurization is off...but I also know you set it to sea level below 12,500) IF anyone has an idea as to why that would be great. Thanks -Josh
Thats not flying, thats falling with style -Woody
CosmicCruiser
RE: Falcon Biz Jet Question
Sun Jul 03, 2005 8:07 am
It's been a number of yrs. since I flew the DA-20 but all I would say is that it's to be sure the PSID is 0. In the small cabins it's easy for a little residual press. to be present and opening the door could be exciting if that very little press. threw you forward as the door opened. I don't remember the Falcon being a prob. but on the NA-265 Sabre we always opened the DV window after exiting the rnwy and there was a definite WHOOSH!
Quoting PILOTALLEN (Thread starter):
The outflow valve is full open
I don't remember the max. diff on the Falcon but I'm sure it's just that the pressurization can maintain a sea lvl cabin at 12,500' so why climb the cabin except for adjusting it for the landing arpt elevation.
FCKC
Sun Jul 03, 2005 1:18 pm
Difference between Falcon10 and 100 is the avionic.
Differences between Falcon20 and Falcon200 are the engines and a larger fuel tank , thus more range.
The first Falcon20 made its first flight on May 4th 1963 with Pratt & Whitney JT12A , later remplaced by General Electric CF700 , mounted on all Falcon20s
This engine has been upgraded , thus some new versions of the Falcon20 , such as Falcon20 D , E , F.
The final step was the Falcon200 , powered by Garrett ATF3.It was first called the Falcon20 H , but changed its name to Falcon200 , before first delivery.
The Falcon20G is those of the US Coast Guard
Hope it helps.
PILOTALLEN
Sun Jul 03, 2005 7:54 pm
hey,
thanks for the info...we can set the pressurization to Sea Level on our way down....we usually keep it 500ft above SL. It might just be an operating procedure more than a standard setup...I dunno....I just do radios and navigation for this guy in his PC-12 not sur eof the logistics to it but now Im going to read up on it. thanks again for the info really interesting. -Josh
