JOYA380B747
The Closest To A Triple Decker Aircraft!
Mon Jul 04, 2005 3:40 am
Here's what I sketched today, Didnt know whether to name it Airbus or Boeing, so added a new Jet Airways livery to it as its my fav Airline. I dont think it is good enough to deserve appreciation but I did what I could in 10 mins or so. The Windscreen above the Pilots', is for Viewing...
http://i12.photobucket.com/albums/a240/BMWJoy/DSCN1056.jpg
REgds
JOY
[Edited 2005-07-03 20:46:27]
[Edited 2005-07-03 20:57:02]
If it wasn't for AI and those money mongers sitting in the parliament, 9W would have been as big as SQ...:(
zvezda
RE: The Closest To A Triple Decker Aircraft!
Mon Jul 04, 2005 4:01 am
That would require a minimum fuselage height (top to bottom) of 430 inches. Given the extreme ovoid cross section of the WhaleJet, that would make for a fuselage width of at least 367 inches. Using the composite technology of the B787, OEW would be at least 600,000 lbs. With four engines, each would need more thrust than a GE-90-115B for it to have remotely reasonable payload/range.
Also, you show the lowest passenger deck being longer than the middle deck. That's very backwards. The smallest reasonably shaped triple-decker (same ovoid shape as the WhaleJet) would seat 3-4-4-3 on the lower deck, 3-5-5-3 on the middle deck, and 3-4-3 on the upper deck. An 80 meter length would be very stubby. No chance of an 80 meter wingspan unless it's a biplane.
If more capacity were ever needed than provided by the WhaleJet, much larger double deck designs are possible. Keeping the fuselage height of the WhaleJet and widening it until the fuselage is circular at 331 inches would provide 2-4-4-2 seating downstairs and 3-3-3 (or 2-5-2) seating upstairs.
N766UA
Mon Jul 04, 2005 4:06 am
Quoting JoyA380B747 (Thread starter):
Clearly it has Airbus-style wingtip fences  silly
This Website Censors Me
captaingomes
Mon Jul 04, 2005 4:11 am
instead of a viewing area on top, you should have two flightdecks. You know, for redundancy. Isn't redundancy one of the things that has made aviation so safe? I think two flightdecks would make flying even safer!  Wink
"it's kind of like an Airbus, it's an engineering marvel, but there's no sense of passion" -- J. Clarkson re: Coxster
ikramerica
Mon Jul 04, 2005 4:25 am
Yeah, one crew fly while the other crew can just sleep in their seats, then when it's time to take over, you just flip a switch and the other cabin takes over. That's the beauty of fly by wire, no?
As for a viewing deck/piano bar up front, that's what the A380 needs for that massive forehead it has. I've been saying that ever since I saw it.
Ever see the movie "The Big Bus" and you know what I'm talking about.  Wink
zvezda
Mon Jul 04, 2005 4:37 am
Quoting Ikramerica (Reply 4):
I saw that movie and strongly recommend _against_ seeing it. Anyway, a triple decker nuclear-powered tour bus is perhaps slightly more realistic than a triple decker airliner.
hmmmm...
Mon Jul 04, 2005 5:02 am
I like it. A bit stubby and ugly, but so is the A380. I don't think there is a need to tear it apart from an engineering standpoint, it's just a kid's drawing.
Regardless of the ovoid shape dictating a wider middle deck, the length of the first deck is usually longer than the one above it. The cockpit intrusion eats more length than the tapering of the tail assembly.
An optimist robs himself of the joy of being pleasantly surprised
m404
Mon Jul 04, 2005 1:19 pm
Photo © Eugene Uhl
Photo © Paul Goddard
Photo © AirNikon
Less sarcasm and more thought equal better understanding
JDD1
Mon Jul 04, 2005 9:19 pm
The lower deck of the A380 is capable of having passenger facilities there, instead of cargo, as is already in service in the A330/A340.
Stealthz
Mon Jul 04, 2005 9:49 pm
Or you could just call it "10 Forward"... Oh OK you may need to be a StarTrek fan!
Chris
Braybuddy
Mon Jul 04, 2005 9:53 pm
Nice sketch JoyA380B747, but I don't think a triple-decker is a runner, unless it's for airlines which don't carry cargo, like Ryanair. I'm a big fan of the A380, but it's cargo/passenger ratio isn't as good as other aircraft such as the A340-600 or B777-300. It would be even smaller with a triple-decker, so I think the next step-up in aircraft size will be a stretched A380, and there is possibly room for another stretch after that if it were required. Don't forget that if you add another passenger deck, that also increases the space allocation for baggage, which reduces the cargo capacity again.
After that you may see ultra-widebodies making their debut.
skywatch
Mon Jul 04, 2005 11:34 pm
I like stretch versions, so the A380 and that "thing" do not float my boat Joy. No hard feelings!  Wink Let's just say, if I saw that flying past my house, I might be tempted to shoot it down with my "grenade launcher telescope"! My 1st Spotting Encounter With The Police (by Skywatch Jul 1 2005 in Civil Aviation)
The other thing I don't like about the advancements toward bigger airliners is this: Can you imagine the devastation that would ensue if a plane with 800-1000 passengers went down? Oh well, maybe they will make bigger airliners invincible.  sarcastic  Note that I am not degrading the effects of a 747 crash, r any crash for that matter. I just think the aircraft designers need to think in terms of speed, not size, in the days to come. Nice sketch though Joy! Have a nice day!
P.S. My father is in India right now. He's a little closer to you than usual!
----Skywatch
------Forever Watchin' The Sky------
ikramerica
Mon Jul 04, 2005 11:46 pm
Quoting StealthZ (Reply 9):
Yes, that's exactly what i called it in another thread. It was ten forward, or a piano bar like in the Big Bus. Either way, I thought the forehead of a 777 was big until I saw an A380.
Pacific
Mon Jul 04, 2005 11:49 pm
lmao, I remember making a sketch of a "Tupolev 554", triple decker, 16 engines!
Morvious
Tue Jul 05, 2005 1:11 am
Quoting Skywatch (Reply 11):
I think with the A380 they did both. It can fly hard compared to its size and weight.
offcourse..
But the A380 these days will be filled with 555 passengers max (atm)
Not that many more then some of JAL 747's flying around.
The effects of any plane comming down are horrible, nomather how many passengers are in that cabin!
Lets just hope technoligy is safer these days..
have a good day, Stefan van Hierden
Spike
Tue Jul 05, 2005 1:23 am
I love your drawing, and it seems in scale to me. A viewing deck would be superb. Can you put a camera on the top of the tail for inflight cloud breaking scenes. We have glass bottom boats, why not planes?
skywatch
Tue Jul 05, 2005 1:29 am
Quoting Morvious (Reply 14):
Please note that I did mention that. I am not trying to make even small crashes that result in loss of life insignificant. Just making things clearer!  Wink
---Skywatch
rossbaku
Tue Jul 05, 2005 1:33 am
Surely you'd need at least 6 power plants to get that giant off the ground? Anyway hopefully Airbus/Boeing will take heed of your great drawing and you never know...you might just be designing the new A390 or B797!!  spin
RossBaku
Tue Jul 05, 2005 1:34 am
I know KingFisher would Def Order them  Smile
And it would be based abroad.
Nice Sketch Joy.But dont think it would practicable.
Although Major Mx on a Triple decker would be something.
regds
MEL
Mexicana757
Tue Jul 05, 2005 2:45 am
Looks like a blimp with wings and engines.  silly
Vasu
Tue Jul 05, 2005 4:33 am
I'm sure I can recall something that either WAS or LOOKED LIKE a triple decker somewhere a while ago... i think it was a very old French designed aircraft...
longhauler
Tue Jul 05, 2005 9:22 am
I recall flying on an American B747-100 in the early 70s from ORD to PHX. Not only did it have the upper deck lounge, it also had a lower deck galley .... triple decker!
JOYA380B747
Tue Jul 05, 2005 11:38 pm
Quoting HAWK21M (Reply 18):
Look pals, Even I know that making a Triple decker is useless and too impractical and Risky as well. But my sketch just makes an Outline of what it 'might' look like should it be ever made.
Quoting Braybuddy (Reply 10):
Dont forget that a 3ple decker will be much wider at the belly as well, which I could not show in this Side View.
Quoting N766UA (Reply 2):
 Smile Smile
Regds
JOY
skywatch
Wed Jul 06, 2005 12:04 am
Hey Joy, I have a great idea! With so many decks, why don't they put in windows on the nose equivelant to the windscreen! That would be the greatest thing ever! Wait...is that what that second windscreen on your pic is? If so, Great Idea! Nice sketch.
----Skywatch
flyAUA
Wed Jul 06, 2005 12:44 am
Funny idea, but with 3 decks, you wouldn't have enough payload capacity to carry around the luggage in the lowest deck anymore!
Not drinking, also isn't a solution!
sllevin
Wed Jul 06, 2005 6:03 am
Cooler sketch than I could I have done!
If Southwest's business model could be started on a napkin, an airliner can be started with a pencil!
Steve
Tornado82
Wed Jul 06, 2005 6:14 am
If that's the case... FL has Elton John on their planes... whoever bought the triple decker with a Piano Bar would DEFINITELY need Billy Joel.  Smile
1MillionFlyer
Wed Jul 06, 2005 6:25 am
Very nicely done ! In 15 years from now, who knows, we might need a plane that size.  Smile
Golf Foxtrot you are cleared for departure
bushpilot
Wed Jul 06, 2005 6:46 am
I like it, how about a 5 engine set up, MD-11 style, or a 6 engine deal. How about blended wing tips? I am just making suggestions. A much better drawing than I am capable of. Could you do another view from the top or front? I am glad to see the flight decks on the upper deck(s) rather than the bottom avoiding the huge disgusting forehead the A380 presents. Dont get me wrong, I think the A380 looks just fine from the side, but the front on view the 747 is much more majestic.
Users browsing this forum: a320fan, AirbusMDCFAN, AT72, Baidu [Spider], Bing [Bot], dohnut, fi622, geardown, hinckley, hispanola, Jetty, mozart, RyanairGuru, TheGeordielad, travelhound, VolvoBus, vv701, ZK-NBT and 15 guests
