ENCRJ
Twin Runways - MUC Vs. LHR
Tue Jul 05, 2005 9:23 pm
Consider two airports with twin runways, namely MUC and LHR.
I would like to understand why they use the runways differently.
Indeed, while in MUC both runways are used for takeoffs
and landings at the same time, in LHR they are not.
Is it just due to LHR having more traffic than MUC?
By the way, it appears to me that which runway a certain
flight use (for takeoff/landing) in MUC depends on the flight direction.
In other words, "south traffic" goes to 8R/26L and "north traffic"
goes to 8L/26R. Am I right?
N1120A
RE: Twin Runways - MUC Vs. LHR
Tue Jul 05, 2005 9:39 pm
Quoting ENCRJ (Thread starter):
Yes, it is. LHR has to operate in the most efficient way possible and also has to deal with very large populations on its borders. That means doing things that both negate noise and maximize runway use.
ENCRJ
Tue Jul 05, 2005 9:43 pm
Thank you for your prompt reply, 1120A!
HT
Tue Jul 05, 2005 9:47 pm
LHR uses a segregated mode of its two rwys, switching between rwy use in the afternoon. This is a old-fashioned way to reduce noiselevels beneath the take-off paths. However LHR is said to switch to a mixed mode-use of its rwys in the future as this would increase the number of a/c movements per hour by a tiny amount ...
Departures @ MUC: Can´t say, but would be logical. Another point might be gate assignment ...
-HT
cornish
Tue Jul 05, 2005 9:48 pm
Quoting N1120A (Reply 1):
LHR still has the Cranford agreement (a decades old piece of legislature) that means that easterly takeoffs from the northern runway are avoided where possible. this explains why you will often see westbound takeoffs from either north or south runways, but eastbound takeoffs tend to go from the south runway only.
the agreement was to avoid too much noise over the housing area of cranford close to the east end of the north runway I understand.
Just when I thought I could see light at the end of the tunnel, it was some B*****d with a torch bringing me more work
cornish
Tue Jul 05, 2005 9:50 pm
Quoting HT (Reply 3):
expected by 2010/11 - the number of movements is actually projectd to increase by more than you might think....
gkirk
Tue Jul 05, 2005 10:00 pm
MUC has a load of fairly quiet CRJs, LHR has a load of noisy 747s and 340s
Feroze
Tue Jul 05, 2005 10:10 pm
I quote for BA's Investor magazine:
"Next year there will be public consultations on mixed
mode operations and on the terminal infrastructure that would be
built with a third runway at Heathrow [by BAA]."
Full link at http://media.corporate-ir.net/media_...nualReportandAccounts2004-2005.pdf
Feroze
geoffm
Wed Jul 06, 2005 2:09 am
Dunno about MUC, but aren't Heathrow's runways too close together for parallel moves? I understand they can have staggered alternate approaches on both runways but not simultaneous. In other words, in one instant of time 27L can have planes 1 mile out, 3 miles out, 5 miles out, while 27R would have planes 2 miles out, 4 miles out, 6 miles out, etc. (Those figures are just an example, not accurate).
Geoff M.
flyinTLow
Wed Jul 06, 2005 2:18 am
Quoting Geoffm (Reply 8):
That goes for FRA. But I am pretty sure LHR's runways are far away apart. Otherwise it would be pretty impossible to build a terminal in between them.
- When dreams take flight, follow them -
HT
Wed Jul 06, 2005 2:39 am
Distance between runways:
LHR: 1450 meter
MUC 2350 meter
-HT
Boeing7E7
Wed Jul 06, 2005 3:33 am
Quoting HT (Reply 10):
LHR: 1450 meter
MUC 2350 meter
-HT
LHR's distance is not optimum, but do-able for parrallel ILS per ICAO/FAA agreed to standard. MLS should help as well (Anyone know if this is up and running yet?) The prefered distance is 5,000 feet (1,524 meter), 4,300' feet (1,310 meter) is the minimum.
ENCRJ
Wed Jul 06, 2005 6:41 am
I do not think distance between parallel runway is a real issue. At
least it is not in SFO, where parallel runways are very close!
Boeing7E7
Wed Jul 06, 2005 9:51 am
Quoting ENCRJ (Reply 12):
They use simultanious offset approaches:
http://www.awp.faa.gov/affairs/news_releases/awp5-0404.htm
geoffm
Wed Jul 06, 2005 5:09 pm
It is a real issue, as others have kindly provided the figures. Although Heathrow appears to be legal minimum, it would appear that even mild weather can prevent simultaneous approaches (5kt winds or more). And as we have such crap weather in Britain, maybe the weather prevents it more often than not! I'd be grateful if somebody can come up with hard facts rather than what I've researched on a.net...
Geoff M.
HT
Thu Jul 07, 2005 2:35 am
I´ve received an e-mail from a poor ladd w/o an A.net account  Smile
He has asked me to post the following to this thread:
This discussion we had in a MUC-based forum and there was a link to an article explaining exactly that: why MUC uses runways in mixed mode.
This is simply due to the fact that airports like FRA or LHR have more or less constant traffic all day but MUC has several arrival and departure peaks.
Testing the two alternatives one found out that by using the runways in mixed mode will give less congestion during the peaks.
As arrival and departure peaks have some hour time gap between them it is handled as follows:
Arrival peak = few departures, that means both runways are used to bring all the aircraft down as fast as possible. The few departures are put somewhere between it.
With the departure peak it's the other way round.
It is thought, however, that with growing traffic and a more constant traffic rate over the day, both runways will be used as seen in LHR as then it will possibly be more feasible.
Axel F
I found this information helpful & interesting, so I do post it here.
@Axel F.: An account @ A.net is only 25 USD once ...  Smile
-HT
