soylentgreen
Any 747 Commercial Flights Within The US?
Thu Jul 07, 2005 11:51 pm
Does anyone know of any regularly scheduled flights traveling within the continental US only, on Boeing 747s? Thanks!
[Edited 2005-07-07 16:58:28]
Wayfarer
RE: Any 747 Commercial Flights Within The US?
Thu Jul 07, 2005 11:56 pm
Does United still fly 747s nonstop from HNL to mainland USA?
EASTERN AIRLINES: We Are Still Here Today
drerx7
Thu Jul 07, 2005 11:58 pm
Quoting Wayfarer (Reply 1):
No--maybe some aircraft substitutions. As it stands now I know United has a dily 744 DEN-SFO-DEN routing. The occasional SFO-LAX repositioning flights--beyond that not sure.
HOUSTON, TEXAS
MAH4546
Fri Jul 08, 2005 12:00 am
United still flies 744s on a select number of domestic runs between ORD-DEN, DEN-SFO, and ORD-LAX. They are repositioning flights, so the scheudles and routes change often. They even operate LAX-SFO with 744s once in a while. Those are the only bookable flights.
Unbookable, Eva flies Newark-Seattle, El Al flies Miami-Newark, PAL flies Los Angeles-Manila, Asiana flies New York City/JFK-Anchorage, and Qantas flies New York City/JFK-Los Angeles.
a.
LUV4JFK
Fri Jul 08, 2005 12:06 am
Quoting MAH4546 (Reply 3):
I think you mean Los Angeles-Honolulu. Don't forget El Al flies Newark-Chicago (O'Hare) once a week, also unbookable.
LUV4JFK
 yes
John F. Kennedy International Airport: Where America Greets The World.
drerx7
Fri Jul 08, 2005 12:09 am
Not to mention the unbookable China Airlines SEA-IAH. Every so often they sub the 744 for the 343. Do you know what dates the UA 744 is on those routes--the only one currently scheduled is the DEN-SFO-DEN run--but they show up on those other routes mentioned frequently.
HOUSTON, TEXAS
IADLHR
UA also does a IAD-LAX using a 747. In fact I am flying it tonigt.
BigGSFO
Fri Jul 08, 2005 12:15 am
I flew UA 595 DEN-SFO on a 744 last night. Sat on the upper deck. Very nice ride. Too bad the flight was so short!
bartond
Fri Jul 08, 2005 12:22 am
I knew that UA puts a 744 on the SFO-DEN run but I've yet to see a 744 routed on DEN-ORD or DEN-IAD. The largest aircraft on those routes is usually a 772, which is very common.
ikramerica
Fri Jul 08, 2005 12:28 am
Quoting IADLHR (Reply 6):
Was gonna point that out, but since you are flying on it, good on you for beating me to it!
As for other non-bookable flights, QF of course flies a 744 LAX-JFK a few days a week.
khenleydia
Fri Jul 08, 2005 2:03 am
Maybe an odd question, but wouldn't an unbookable flight just be a reposition? Or are there actually pax onboard?
KhenleyDIA
Why sit at home and do nothing when you can travel the world.
N1120A
Fri Jul 08, 2005 2:09 am
No
And you can book that. You just can't book the LAX-HNL segment. Actually, that segment does not run all the time, as if the winds are favorable, PAL just overflies HNL and refiles to MNL
Quoting KhenleyDIA (Reply 10):
They are repositioning flights that they put PAX from another flight on to. Given the number of people who fly LAX-SFO, it is understandable when UA sometimes needs to use the 744
N62NA
Those unbookable flights are for the international pax continuing on, so in the case of LAX-JFK on QF, the segment LAX-JFK is only for the pax who origininated on the flight in Australia. Same goes for the reverse. Only pax that can get on at JFK are those whose destination is Australia.
How come I can't upload an avatar photo to my profile?
highflyer9790
Fri Jul 08, 2005 2:11 am
I think to my knowledge United flies some 744s occasionally on re-positioning flights, and even sometimes operating a SFO-IAD.
121
United1
Fri Jul 08, 2005 2:33 am
From this weeks Schedule......
United Domestic 747-400 Flights.....
LAX-IAD Daily Flight 946
IAD- LAX Daily Flight 947
SFO-DEN Daily Flight 770
DEN-SFO Daily Flight 595
Other times of the year you will see them scheduled on ORD-LAX, ORD-SFO, ORD-IAD and as has been mentioned repositioning/substitutions throughout the system. LAX-SFO-LAX happens once in a while if SFO is fogged in 2-3 737 flights are canceled and they will operate a 747, if one is available, to clear the passenger backlog.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
RDUDDJI
Sun Jul 10, 2005 11:39 am
I heard last month that UA is opening a 744 pilot base at IAD with approximately 32 pilots to be based there. They are flying 744's to LAX, FRA and LHR that I know of out of IAD. I heard there may be some expansion of 744 flying there.
Sometimes we don't realize the good times when we're in them
N867BX
Sun Jul 10, 2005 1:36 pm
Doesn't Columbia Airlines still fly a 741 IAD-LAX?
crownvic
Sun Jul 10, 2005 1:53 pm
JAL flies LAs-LAX w/ a 744
ikramerica
Sun Jul 10, 2005 1:59 pm
Quoting N62NA (Reply 12):
I believe you can also book this between LAX-JFK as long as you are going to continue on back to Australia.
For instance. On the same ticket, you can do SYD-LAX, LAX-JFK, JFK-LAX-SYD, but spend time in both LA and NY, no?
tymnbalewne
Sun Jul 10, 2005 2:00 pm
Quoting N867BX (Reply 16):
No...Columbia Airlines went out of business after a protracted flight attendants and pilots strike. THe f/a's were insisting on a pay rise since the scope of their roles were increased to include flying the aircraft.
The pilots struck because they viewed the f/a's flying the aircraft as a back-door way of introducing A-scale pilots and B-scale pilots.
C.
Dewmanair...begins with Dew
N867BX
Sun Jul 10, 2005 2:32 pm
Quoting TymnBalewne (Reply 19):
Well I suppose, I haven't flown them on that route since 1975 so its possible they no longer fly it.
aussie747
Sun Jul 10, 2005 3:36 pm
Quoting Ikramerica (Reply 18):
You can only be on the LAX-JFK or JFK-LAX if you have come off or going to a QF numbered flight operating to/from Australia / New Zealand as a connecting flight (ie as a transit stop only in LAX, and your flights must connect within 24 hours or arriving or departing).
A loop hole with this also is that you can also arrive in Auckland at 10.45 am on QF25 one morning and depart the next day on QF107 to JFK as it is still under 24 hours.
PanAm747
Sun Jul 10, 2005 3:43 pm
And that Columbia Airlines flight 409 IAD-LAX is one VERY long flight...you take off about 11 PM and arrive over Utah about 7 in the morning. That's about a ten-hour flight.
On the other hand, Joe Patroni is still in charge of maintenance, and he's quite good.
Seriously, United is the only airline still flying 747's domestically, and the routes have been quite well discussed. Get on one before they're gone completely!!
Happy flying!!  airplane
Pan Am:The World's Most Experienced Airline - P(oor) S(ailor's) A(irline): San Diego's Hometown Airline-Catch Our Smile!
san747
Mon Jul 11, 2005 2:58 am
Why are all these flights non-bookable? Whatever happened to 5th Freedoms??? Or are the A345 and 772LR going to end the era of making stops on intercontinental flights?
Scotty doesn't know...
