Thunderbird1
Air India 747 AOG At LAX
Tue Jul 19, 2005 3:14 pm
Does anyone know why VT-EVJ is on the ground at LAX?
This seems to be happening more and more often.
Nimish
RE: Air India 747 AOG At LAX
Tue Jul 19, 2005 6:15 pm
No idea - but I hope it's nothing serious. As it is, one of the aircraft must be busy with taking the Indian PM on his visit to the US. This will definitely mean cancellations and delays for AI - which is becoming a recurring theme this summer.
Incredible India!
aseem
Tue Jul 19, 2005 7:46 pm
if it happening so frequently, then they should register the aircraft as VT-AOG!! Big grin
rgds
VT-ASJ
ala re ala, VT-ALA ala
Tue Jul 19, 2005 8:43 pm
Anyone in LAX with Details.
regds
MEL
vivek0072
Wed Jul 20, 2005 12:28 am
I had been to LAX yesterday, but did not see AI plane, where is it parked ? Meantime why is the AI 747 (Khajuraho/VT-ESO)ferrying the PM called Air India one ?
http://in.rediff.com/news/2005/jul/18singh.htm
http://in.rediff.com/news/2005/jul/18pm.htm
That life's most failures were people who did not realise how close they were to success when they gave up. - Edison.
N1120A
Wed Jul 20, 2005 12:34 am
Quoting Vivek0072 (Reply 4):
If it is AOG, it is likely at the United hangar, which you can see from the end of the departures loop, as United Services handles all of AI's line MX at LAX.
flyinTLow
Wed Jul 20, 2005 12:44 am
Great! This means a lot more late night work at FRA again. But that's ok. Just means the night shift wont get too boring after all! Or is the a/c still AOG and will depart with an entire 24h delay?
Thilo
- When dreams take flight, follow them -
Thunderbird1
Wed Jul 20, 2005 1:25 am
Correct, it's parked at the United maintenance area. It's where VT-ESO was parked for a couple of weeks after that FRA tailstrike incident.
Jetfixr
Wed Jul 20, 2005 2:21 am
Your correct. The aircraft is AOG due to a hydraulic shuttle valve problem. Also some maintenance phopa's by United Mgment.
Thunderbird1
Wed Jul 20, 2005 2:46 am
That doesn't sound like it'd be too hard to fix in a hurry. Quite unlike the -ESO tailstrike circumstances.
What are "phopa's" by the way?
DH106
Wed Jul 20, 2005 3:57 am
I'm guessing but 'phopa' = 'Faux Pas' ?
French for embarrassing blunder.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
MakeMinesLAX
Wed Jul 20, 2005 7:22 am
Quoting DH106 (Reply 10):
Just to clarify, the literal meaning is "false step". When you say "(insert language here) for...", the implication is that you're giving a direct translation.
To stay on topic, it's interesting that UA provides mechanical support. If/when the 777s return to LAX and need service, it will be like a homecoming of sorts, since they are former UA A/C.
Thunderbird1
Wed Jul 20, 2005 1:42 pm
Well, it's not AOG anymore. I saw "Fatehpur Sikri" rumble down the runway at around 8 pm.
I wonder if today's incoming flight from FRA was cancelled...
Wed Jul 20, 2005 2:39 pm
Quoting Jetfixr (Reply 8):
Should not take time.
Quoting Thunderbird1 (Reply 12):
 bigthumbsup
regds
MEL
DH106
Thu Jul 21, 2005 2:30 am
Quoting MakeMinesLAX (Reply 11):
I don't agree with your assertion of implication. I assert that the context was one of general meaning not direct translation.
Thunderbird1
Thu Jul 21, 2005 3:13 am
Awesome. One of the funniest things I've read on this site  Wink
AirIndiaOne
Thu Jul 21, 2005 3:31 am
Manmohan Singh is on a 3 day visit to the US!
He should be coming back soon and so would be the aircraft.
The presence of PM on any aircraft makes its callsign followed by "one"
"You don't have to be crazy to be in aviation, but it helps", JRD Tata
aseem
Thu Jul 21, 2005 3:45 am
Quoting Thunderbird1 (Reply 15):
you won't believe that there are real time registrations such as
G-BUSH and
G-BOAC (btw BOAC is old name of BA)
cheers!!
VT-ASJ (my initials)
Thu Jul 21, 2005 5:50 pm
Quoting Aseem (Reply 17):
G-BUSH and
cheers!!
There was a Thread on that some place out here.
On the topic.What was the reason for the Hyd Shuttle valve u/s....Leak.
regds
MEL
AirIndiaOne
Thu Jul 21, 2005 10:40 pm
Quoting Aseem (Reply 2):
What;s AOG?
pls enlighten me
aseem
Thu Jul 21, 2005 10:46 pm
Quoting AirIndiaOne (Reply 19):
What;s AOG?
AOG = Aircraft On Ground Big grin read the thread title.
rgds
VT-ASJ
Thu Jul 21, 2005 10:49 pm
What;s AOG
Aircraft On Ground.
[Aircraft Grounded Awaiting Spares].
regds
MEL
MakeMinesLAX
Fri Jul 22, 2005 2:11 am
Quoting DH106 (Reply 14):
When it comes to euphemisms like this (as opposed to singular words, e.g. "'Chien' is French for 'dog'"), the equivalent phrase is typically not a literal translation. As an example, the French phrase for "hungry as a bear" employs "wolf" instead.
My point was to provide a direct translation for clarity's sake, just so no one gets the notion that the phrase literally means "embarassing blunder" (which is not really a common euphemism anyway, somewhat enforcing the notion of a exact rendering). In any case, a closer match would be "misstep", which my Webster's Dictionary defines as "A false or wrong step; error"
Airlinerfreak
Fri Jul 22, 2005 2:44 am
Last Tuesday when I was coming back home to LAX I believe I saw that exact plane at the Tom Bradley International Terminal. So I do not know as to why the aircraft was there.
Fri Jul 22, 2005 1:54 pm
Photo © Helmut Bierbaum
Photo © Zhangzongli
Nice Livery  bigthumbsup
regds
MEL
