rj777
OMA-MDW On WN 2628- Which Type?
Thu Jul 21, 2005 11:47 pm
Anybody know what type of aircraft usually flies this route? I will be travelling it on August 11th.
JRadier
RE: OMA-MDW On WN 2628- Which Type?
Thu Jul 21, 2005 11:50 pm
most likely a 737  Wink
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
FlyingTexan
Thu Jul 21, 2005 11:52 pm
Quoting JRadier (Reply 1):
most likely a 737
Beat me to it...
"Wouldn't your boss like to fly home nonstop at 4:30 on a Friday afternoon?" -Airline Exec to Congressional Staffer
Corsair2
Fri Jul 22, 2005 3:35 am
Probably a 737-700. Most of Southwest's aircraft now are the 737-700 with winglets.
"We have clearance Clarence. Roger, Roger. What's our vector Victor?"
OPNLguy
Fri Jul 22, 2005 4:14 am
Quoting Corsair2 (Reply 3):
About 50% are -700s, 45% -300s, and 5% -500s....
2628 is normally a -700 (all of which have winglets) although that could change at the last minute...
iowaman
Fri Jul 22, 2005 4:29 am
Quoting OPNLguy (Reply 4):
And today was no exception. I'm surprised it's a -700 with OMA-MDW being a fairly short route. Are loads really good out of OMA? I noticed LAS flights seem to be going out pretty full, and the other cities, PHX,STL, and MDW look to be doing decent.
atrude777
Fri Jul 22, 2005 7:38 am
when it comes to loads, the -300 and -700 make no difference. its simply the range and where the plane is flying to next. for example OMA-MDW may continue to MCO. therefore the -700 needed on the MDW-MCO route, but flew the OMA-MDW anyway. Loads for STL are pretty good actually. All of my WN flights out of STL has been very high, id say in the 90's
Alex
iowaman
Fri Jul 22, 2005 8:06 am
Quoting Atrude777 (Reply 6):
Yeah, same amount of seats, and I see it continues on to HOU from MDW.
Just recently a 3rd flight was added on OMA-STL, I would imagine that is also high yield for WN. I'm surprised AA doesn't have Trans States or someone fly this like they do out of CID and DSM.
MAH4546
Fri Jul 22, 2005 8:14 am
Quoting Iowaman (Reply 7):
The first markets AA pulled out of were Southwest markets. STL-CLE, STL-DTW, STL-OMA, STL-OKC, etc.
OKC and TUL came back thanks to some small revenue guarantees, and STL-TUL acts as a repositioning flight for maintence purposes.
a.
MKEdude
Fri Jul 22, 2005 8:16 am
WN what type? I'll go out on a limb and say a 737.
"You can't be a real country unless you have a beer and an airline." Frank Zappa
TWA902fly
Fri Jul 22, 2005 8:28 am
Since when can a 737-300 not fly MDW-MCO?... i flew ORD-OAK and thats 800 miles longer than ORD-MCO, i think the only WN routes that the 300 cant make are the trans cons
'902
life wasn't worth the balance, or the crumpled paper it was written on
jeffry747
Fri Jul 22, 2005 8:30 am
Quoting MAH4546 (Reply 8):
Seemas like everytime WN moves in, another airline moves out.
C'mon Big B, FLY!
atrude777
Fri Jul 22, 2005 8:40 am
Quoting TWA902fly (Reply 10):
Oh I did not say a -300 cannot make it. It is because of the winglets, Southwest tries to put the -700 on long routes where fuel savings is better, they would rather fly a -700 on routes like MDW-PHX, STL-MCO, MCO-PHX etc etc, even tho a -300 can do it just fine. Its about fuel savings.
Hence the reason for the -700 flying OMA-MDW, it is continuing onto a longer flight segments where they want the -700 to fly as I said above because it has better fuel savings, long route.
I heard the reason for such was connecting purposes at STL, therefore adding two daily STL-MCO for a total of 5. All for connecting purposes. Yield may be good, and generally is...Loads are another thing of course.
Alex
rj777
Fri Jul 22, 2005 1:34 pm
Actually, if you look at the eppley airfield website, the flight goes from Omaha to Midway to Houston. I'm sorry for the confusion, I probably should have said SERIES instead of TYPE.
RJ
wilax
Fri Jul 22, 2005 2:42 pm
On August 11, 2005, it will be a 737-7H4 per Airwise.com. If you are lucky, maybe you will get "Maryland One". There is about a 1 in 300 chance...
