cxsjr
Mad Cross Winds!
Wed Jul 27, 2005 5:06 am
How about sharing some shots of aircraft suffering bad crosswinds?
Captured this an MAN earlier in the year - how bad does it have to be before the pilot aborts?
The world is a book, those who do not travel read only one page ....
legacy135
RE: Mad Cross Winds!
Wed Jul 27, 2005 5:13 am
Quoting Cxsjr (Thread starter):
I would rather call this "aircraft suffering from bad crosswind handling" as the pilot is supposed to align the plane with the centerline. The landing gear is not build for an acceleration that comes sidewards...
ACDC8
Wed Jul 27, 2005 5:21 am
I'm thinking that this is a good example of severe x-wind:
http://www.flightlevel350.com/viewer.php?id=116&rating=yes
A Grumpy German Is A Sauerkraut
cxsjr
Wed Jul 27, 2005 5:36 am
Quoting Legacy135 (Reply 1):
... perhaps I'll give flying PIA a miss then? No wonder the undercarriage bays emit so much clouds of crap if that's the way they land their aircraft!
typhaerion
Wed Jul 27, 2005 5:40 am
Quoting ACDC8 (Reply 2):
I would also say that attributing to that missed approach is the fact that the pilot came in awful high and hot. I am not a pilot, but I would have to assume that attempting to land after about 2500-3500 feet of runway does not allow for enough landing distance. Though that plane was sure bucking in the wind. No doubt about that.
For some, the sky is the limit. For us, it is only the beginning... -- Jack Hunt
ACDC8
Wed Jul 27, 2005 5:48 am
I've never flown anything larger then a Seneca myself, but as you can see he's really crabbing into the wind. Due to the plane being all over the place, that would leave me to believe he's crabbing and not side-slipping to loose altitude. I also couldn't imagine him coming in hot and high on the approach on a day like that. Keep in mind, I'm sure he's being bounced all over the ILS though, and really playing with the throttles (unless the auto throttles are armed). Oh what fun!  Smile Hope you enjoyed anyway!
legacy135
Wed Jul 27, 2005 6:16 am
Quoting Typhaerion (Reply 4):
As ACDC8 says, he wasn't really wrong in the beginning. The clue is, if you are dealing with wind, you need to add an extra to your approach speed. This normally is 1/2 of the headwind component and an extra for the gusts. There might be an upper limit to make sure nobody is going to add like 50 knots or whatever.
We handle it as follows:
Vapp = Vref + wind correction
Wind correction = 1/2 headwind + full gust (but maximum 20 kts)
Let's do an example to make it look easier for the non-pilots being with us:
Vref = 118kts
Wind: 16 kts, gusting 25 kts
So, the wind correction will be 1/2 headwind (in this case 8 kts) and the full gusts of 9 kts (25-16)
So: Vapp = Vref 118 Kts + 8 kts windfactor + 9 kts gusts = 133 kts
If the pilot goes with numbers in this or similar manner, nothing should go wrong. Use of autothrottle could result in a uncontrolled situation as they might not handle the crosswind and being always to late what could result in an overoscillation of the aircraft.
What can be seen very often, is pilots getting afraid once in the gusts and flying far to fast. One fact is, that the wind 1000ft above ground is approximately the double it is on ground. In severe condition the wind will have additional drag trough buildings, trees etc. what results in much less just over the runway. This can lead to situations as we can see the TAP A321 in, being over the runway but with just "any" speed. Unfortunately a plane does not land at "any" speed.
Airplanes are not really certified for crosswind. The limits we find in the manuals are demonstrated values. This does not mean that you can't handle more if you are able to... but sure, it could also be the opposite. On the other hand companies need to put their limits in their operations manuals and I have the feeling, the TAP flight was over that limit.
For a nice smooth landing the little bit of luck is always with as well. If it results in a smooth landing after such an approach as here in the video, this little bit is a little lot of luck. The landing is just as good as the approach was and this needs to be stabilized. So if the approach is a fight, the crew should consider the only safe action..... go around, do it again or divert to the alternate.
Cheers  Wink
Glossary:
Vapp= Approach speed
Vref= Reference speed for approach (Stall speed x 1,3 incl. 30 degrees of bank)
Wed Jul 27, 2005 6:26 am
Here are some really windy approaches:
http://www.rosboch.net/various/landing_at_wellington.wmv
typhaerion
Wed Jul 27, 2005 6:57 am
Quoting Legacy135 (Reply 6):
Thank you very much for that informative post!
cbphoto
Wed Jul 27, 2005 7:46 am
This is not entirely true. Yes it is not good for an aircraft to ever sideload, but it is built to withstand sideloads and considerable ones at that. I am sure someone with a more technical backround then me can give you details, but I can tell you landing gears will not snap off or break due to a crosswind landing!
Good observation, he is crabbing and not slide slipping, although large aircraft never really slideslip, they always crab!!
This topic has been discussed in length, but the picture you see at the top of the post is a usual crosswind landing, althought it might be a little harder then most, but surely nothing out of the usual!
ETOPS: Engines Turning or Passengers Swimming
ACDC8
Wed Jul 27, 2005 9:14 am
Quoting Starlionblue (Reply 7):
Holy cow! Now that was fantastic! Thanx Starlion!
Is it just me or did that one Ansett BAe146 come down on his nose gear? And that last Dash 8 .....  eyepopping  ! WOW!
Just goes to show you how much fun being a pilot is.
roseflyer
Wed Jul 27, 2005 9:25 am
Quoting ACDC8 (Reply 5):
Definitely a crab since a big jet is not certified to perform a slip. Slips cause an incredible amount of force on the airplane and with the long moment on a bigger plane, the stresses are too much. Also a jetliner pilot should never need to slip.
I only have experience flying Cessnas, but if that were a small plane, that picture is a clear indicator of why you leave the bank in all the way until touchdown when dealing with a crosswind. You bank into the wind, and always have to use the rudder to keep yourself in line with the runway. Although landing gear can handle side loads, you are supposed to land on only one main gear in a bank rather than side load both main landing gear. Is it the same on a big jet?
PhilSquares
Wed Jul 27, 2005 9:27 am
Not quite true. On Boeings (and I can't remember about Airbus) landing in a crab is an acceptable technique. However, it is not the best for passenger comfort. So, the preferred technique is cross controlling (aileron into the wind and rudder to align the nose).
The landing gear are in fact stressed for landing in a crab.
Fly fast, live slow
legacy135
Thu Jul 28, 2005 12:58 am
Quoting PhilSquares (Reply 12):
Would you call it "acceptable" or "good"? And what would you say about your tires?
I guess you agree with me that we are just a little closer to brake it if we are not going to align the plane with the centerline.
If we are talking about severe conditions the goal is to bring everybody on ground without bringing somebody in danger, I do agree with you that it could be acceptable to "crab the brid in the runway" under this circumstances. But I guess if we end up in this situation, probably somewhat went wrong in an earlier stage of this flight.
If we do talk about normal operations I can't see any reasonable issue that justifies a crabbing landing. We stress the airframe much more, we use the tires times more than in a normal landing and directional control, once the nosewheel is touching isn't initially going where we want. Furthermore we are closer to brake something than if we do the technique as you describe it as well, hanging the aileron into the wind and aligning the nose with the pedal.
Can you agree  Wink ? I am quite sure, regarding your expierience you are going to show us all quite nice crosswind landings in a real Irish wind with ease.
jayspilot
Thu Jul 28, 2005 4:46 am
A 777's landing gear actually pivots to make the jet fly sideways and land more into the wind while the wheels go straight. I know on other jets like the 747 where you can't lower a wing b/c you will drag either the 1 or 4 engine you are able to land with up to a 30 ish degree crab and the plane is stressed for it. Slightly different then a 172 Smile
CosmicCruiser
Thu Jul 28, 2005 6:03 am
Quoting Cbphoto (Reply 9):
ahem, remember the fedex MD-10 had the main strut fail because they hit in a crab.
see the above post. I'm not talking 747(I know it's capable) but every other large plane I've flown is never landed in a crab and you will bust a sim ride if you can't land it in a slip. end of story. This has been beat to death but I can say at fedex we sometimes use the FPA which shows drift to ensure 0 deg. crab during a x-wind ldg and any deviation from centerline is a critiqued item.
legacy135
Thu Jul 28, 2005 6:30 am
Quoting CosmicCruiser (Reply 15):
Thank you CosmicCruiser, I am glad to see somebody showing up who also feels a pain if they go to land this poor plane in a crab and try to tell us that it needs to be like that.
tribird1011
Thu Jul 28, 2005 12:48 pm
LIS's RWY 21 has a long displaced threshold - not sure how much - but at least 1000 feet displaced - so that being the case, from the beginning of the pavement in, the pilot should be aiming to touch down at a minimum of 2000 feet (1000 feet to make the threshold, plus 1000 feet as touchdown point). As such, the pilot was not high at all - as to hot, it's hard to tell how fast he's going, but he's going at Vref plus all the previous mentioned corrections, so he is definitely faster than he would be on a normal approach.
Wonder waht the pax were thinking as the ground came closer, in what looked like to be an unstabilized approach.
gotta love x-winds though...
