airknight
EWR Runway 11-29
Sun Jul 31, 2005 9:33 pm
Before everyone jumps on me, i am an aviation enthusiast and frequent flyer (but work for an insurance company)...that being said i was wondering if anyone on the technical side can answer me the following question.
I was flying back to EWR on friday morning and the normal 22L approach and 22R takeoff pattern was in effect. However, I noticed that there were a bunch of RJ's and what looked like a NW320 taking off on RWY 29 as well. Who makes the decisions if they want some planes to take off on 11-29, is it ATC or airline request? I might understand under heavier departure times that they might use the extra runway, but from all the times i have flown in and out of EWR there is no consistency with that thought.
Looking forward to your insight - airknight
Cory6188
RE: EWR Runway 11-29
Sun Jul 31, 2005 10:31 pm
While I don't know the answer to your question, I have departed and landed multiple times on COEx ERJs from EWR's 11-29, and I would think that COEx would probably be the one airline at EWR that requests to use the runway more than anyone else.
Many of the CO mainline flights need the extra runway length, so the 6800' limits that, but 11-29 works fine for the ERJs and is very convenient to Terminal C, so taxi times are lower.
CMHSRQ
Sun Jul 31, 2005 10:33 pm
I will contact a buddy of mine, he is a controller at EWR. He should be able to provide a good answer.
The voice of moderation
N1120A
Sun Jul 31, 2005 11:02 pm
Quoting Cory6188 (Reply 1):
That is absolutely right. Given the takeoff run and stage length, the ERJs and NW's A320 (in this case) should have no issue using 11-29, while CO's many heavy departures would need one of the longer runways. This allows them to split many of the ops between runways.
CMHSRQ
Mon Aug 01, 2005 5:14 am
During the 9-1030am hour its the heavy push for departures and very light on arrivals. So if you are taking off and your destination is over an EAST departure gate or NORTH departure gate and your fuel and weight are ok than you can depart runway 29. Its only on that configuration if we are departing the 22's. Its just a way like you said to maximize the use of runways available. Now on the flip side on around 1-2pm we use runway 11 as an "overflow" runway for the arrivals. They use it for any configuration 22's or 4's. Commonly called as "shooting the gap" Landing 22 and 11.
This is the response from Scott, he is a controller in the EWR tower.
airknight
Mon Aug 01, 2005 5:50 am
that was great and makes total sense, i arrived around 1015am, thank you and please send my thanks to scott, as well!!!
apodino
Mon Aug 01, 2005 11:48 am
I was on a CO 737 one time from DAB (Back when mainline still operated the route before 9-11). Coming into EWR we flew an approach parallel to the NJ turnpike from the NE. But I could see out the right side of my window the NJ turnpike, and I wondered why we were off the approach course to the 22's. Then we banked to the right and landed on 29. Never did figure out why we weren't on 22L but I am thankful since the taxi time is much shorter to Terminal C.
deltairlines
Mon Aug 01, 2005 11:59 am
I have relatives in the Summit area right under the approach for Runway 11...mostly it's ERJs and 737s...I think I might have seen a 757 once in a blue moon coming in between 2500 and 3000 at this point in the approach (it's about 10 miles out)...it's not a bad place for doing some spotting.
Jeff
airplane
Mon Aug 01, 2005 12:39 pm
I landed on RWY 29 on a CO 757 a couple of times when I worked for CO in the 90's.
Its a visual approach Port Elizabeth and then a turn into final.
Very cool !
JP
The sky´s the limit
coa764
Mon Aug 01, 2005 12:59 pm
When on the 22's you have 22L depts/22R arrivals and on the 04's arriving 04R and departing 04L. 11/29 is the overflow runway for arrivals to give the airport a duel arrival runway configuration that can support RJ's to 777 ops. The trick is that the winds have to be favoring the runway and you have to have 3000/4 to shoot the visuals. This is a circling maneuver so if the winds are not right and the visibility drops below 3000 crews start to refuse the runway and when this happens you get an arrival rate drop (usually from 50-45 per hour to 38-40 per hour) and depending on what configuration TEB is landing can also trigger the availability of the overflow usage. The demand for EWR is up at 40 aircraft per hour starting at 1700Z and continues through 2359Z so when either the winds or ceiling (sometimes it is not a hard ceiling but a haze layer) prevents the usage of 11/29 that is how you get the typical afternoon Ground Delay Program for EWR.
Please oh please Mr Moderator Nazi, dont delete my thread.
tjwgrr
Mon Aug 01, 2005 9:32 pm
I've landed on 11 in a CoEx ERJ once, which is even more uncommon than the 22L approach and a circle to land on 29. If I remember correctly, the winds were practically nil. I knew something was up- all the usual sites on the ground during our approach were not the same.......
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
timz
Tue Aug 02, 2005 2:21 am
It's not uncommon for heavies to land on 29, and for non-heavies to depart on 29, and for RJs (at least) to land on 11-- but do they ever use 11 for takeoffs? And did they ever take off from 11 when the WTC was 6.6 nm from the departure end?
b727fan
Tue Aug 02, 2005 8:31 am
Well, I have always wondered what it must be like landing on short runways with heavies! I have seen Co 777s many times approaching 29 and the passing right over the NJTPK is spectacular! Seems like the gears are about to clip the fence! I have also witnessed LH 340 and SR 330 landing on that runway! One hell of reverse thrust and breaking I suppose!! I am flying 3x out EWR in Aug. (EWR-YYZ, EWR-YUL, and EWR-SDF) all flights are with CO and they will be on 737 & ERJs! I hope to get lucky and maybe land on 29/11!!!
