United787
Boeing New Tech. For Moving Airplanes On Ground
Tue Aug 02, 2005 8:52 am
Please forgive me if this has been discussed, I have not been able to find a thread on this subject but...
I just read that Boeing is testing an electric motor on the nose wheel of an AC 767 that will allow airplanes to operate on the ground without the use of engines or ground tow tugs. See link:
http://www.boeing.com/news/releases/2005/q3/nr_050801a.html
My first thought is DUHHHHHH. Why didn't anyone think of this before. I am sure it is more complicated than that, but such a simple concept would seem to have such huge benefits you would think Airbus or Boeing would have figured this out like 30 years ago. Please help me to understand why airplanes don't already have this feature.  confused
DC10GUY
RE: Boeing New Tech. For Moving Airplanes On Ground
Tue Aug 02, 2005 9:27 am
Wow, great idea. Are they planning to add this to newly built airplanes ??? or old ones too ???
Next time try the old "dirty Sanchez" She'll love it !!!
CanadianNorth
Tue Aug 02, 2005 9:49 am
Well I'd say that sounds like a brilliant idea, shoulda been tried years ago...
CanadianNorth
What could possibly go wrong?
Ruscoe
Tue Aug 02, 2005 9:55 am
Weight might be a problem.
Ruscoe
DLKAPA
Tue Aug 02, 2005 10:03 am
Quoting Ruscoe (Reply 3):
Ruscoe
For an electric motor to be able to produce enough energy on the nosewheel to allow the plane to move forward, yeah that thing is gonna be pretty big. I'd like to see it even retract into the wheel well.
sean1234
Tue Aug 02, 2005 12:15 pm
How about some ducted air design running off of the APU? BTW I'm not an engineer.  Big grin
captaingomes
Tue Aug 02, 2005 12:28 pm
Oh no, they're making a Boeing FWD instead of RWD. That's no fun!
The concept is fine, but I too wonder about weight and size issues. This electric motor has to be mighty strong. Think about the size of the tugs and the power they generate to efficiently move a 767, now imagine what sort of built-in device would be required to do the same job? Perhaps this will go the way of the folded wings from the 777, it may be made an option at some point, nobody will take it, and it will go down in history as a good idea in theory but not in practice. Just my humble opinion though.
"it's kind of like an Airbus, it's an engineering marvel, but there's no sense of passion" -- J. Clarkson re: Coxster
GEnx
Tue Aug 02, 2005 12:55 pm
Actually, electric motors can produce tremendous torque, which would work for an aircraft application, where you are just trying to get the plane moving slowly on the ground from a stop. The big question is power source. The assumption seems to be the APU, but will their be alot of intermediary hardware/software necessary to control the system? That's the complexity/cost/weight issue. How much gas saved on the ground to offset the other penalties?
Because getting there IS part of the fun!
GEnx
Tue Aug 02, 2005 1:07 pm
And I wonder what the 'Flight related' technical issues are if this a ground based system?
ual747den
Tue Aug 02, 2005 2:04 pm
Attaching a motor to something that slams into the ground and goes from stop to couple hundred miles an hour would be mighty complicated, the less moving parts on the plane the better, I don't think we will see this for quite a while
/// UNITED AIRLINES
Euclid
Tue Aug 02, 2005 5:19 pm
I can't see how this could ever work. Never mind the things like extra weight, etc. What bothers me is the fact that they put the motor in the nose gear. Most of the plane's weight rests on the main gear, as we all know, so how on earth would the nose wheel have sufficient traction to pull a fully laden plane forward? I would think, especially on a wet tarmac, that the nosewheel would just start spinning and the plane wouldn't move an inch. Imagine pilots bragging about the burnouts they did!
Using electric motors is a good idea, as they are immensely powerful, but I think this would work a lot better fitting two smaller motors in the main gears than to fit one big motor in the nose gear.
YYZAeroEng
Tue Aug 02, 2005 6:35 pm
Quoting Euclid (Reply 10):
Why would something like that bother you? From the article it seems that Boeing/chorus engineers have proven your doubts wrong. The test was performed under a variety of condition, and it has shown its potential.
Since electric motors are known to produce exceptionally high torque, I don't imagine burnouts would be a problem. The spinning of the wheel would be caused by trying to accelerate too quickly, with the proper application that shouldn't be a problem.
I think exploratory technology like this will go a long way in making air travel more efficient
Rohan
Mind that Bus! What bus? *Splat!*
Revelation
Tue Aug 02, 2005 10:09 pm
Maybe they could use the load of the electric motor to help in braking, and use the energy generated to help recharge the battery, just like hybrid automobiles do. I better go call the patent office now!
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
N867BX
Wed Aug 03, 2005 2:13 am
I wonder how the cost of this idea compares to the cost of a pushback tractor.
Boeing Nut
Wed Aug 03, 2005 2:30 am
Seems to me that this is a bit redundant with electric powered tugs anyway. A good idea non the less.
wingman
Wed Aug 03, 2005 2:34 am
How about a bolt-on model and just use it on departures? Fuel savings are probably more imperative on the long queues waiting for take-off clearance. Just before final line-up it gets removed and hauled back to the terminals for the next plane. Even if you need different models for each plane type you'd still save millions on the number of reduced units required.
Brilliant idea , that's me done for the week.
StarGoldLHR
Wed Aug 03, 2005 3:16 am
Heres a radical idea.
We all know that vacuum cleaners can be set to automatically follow a line on the ground.
Why not develop an "auto-tug" which recieved via radio it's command / route to push back a plane and guide it to the runway for takeoff following lines on the ground, then detach, and await to pick up the next landing plane and automatically take that plane back to the gate.
This saves many things:
1. Engine Fuel on the ground
2. Need for people to push back
3. Safer control for getting aircraft / distances etc around the airport
4. If this was electric/rechargable.. it's ultra energy efficient
5. Saves need for excess weight on the plane
remember.. you saw it first here  Smile
So far in 2008 45 flights and Gold already. JFK, IAD, LGA, SIN, HKG, NRT, AKL, PPT, LAX still to book ! Home Airport LCY
Airportgal
Wed Aug 03, 2005 3:18 am
not only would it eliminate the volume (and weight) of fuel needed to taxi from gate to runway, the amount of engine exhaust and noise would be reduced as well.
Dimsum
Wed Aug 03, 2005 3:23 am
Quoting Wingman (Reply 15):
How would this be any different and MORE practical than the existing tow-tug system?
checkraiser
Wed Aug 03, 2005 3:39 am
Quoting Boeing Nut (Reply 14):
You cut out the person driving the tug and having to attach and release the towbar. Less time involved - and we all know time is money.
I don't know any better than the next guy but I imagine the motor would be located inside the A/C and connected via some sort of gearbox and linkage system.
I like this idea too but two motors + two drivetrain assemblies = more weight and money.
Quoting Revelation (Reply 12):
A good idea as well but I don't think there's any benefit from this. The APU is already going to be running so there's no need to further charge the batteries.
Quoting StarGoldLHR (Reply 16):
How about this?
Brake wear should also be reduced because the crew is often times riding the brakes when the A/C is being moved by thrust. The brakes should be used a lot less on taxi now with this system.
N1120A is a camel-fucking terrorist.
FriendlySkies
Wed Aug 03, 2005 4:00 am
Because if the thing went hay-wire, you'd have quite an expensive mess to clean up.  Wink
ALB2ATL
Wed Aug 03, 2005 4:35 am
Good one!
 rotfl
Francoflier
Wed Aug 03, 2005 5:29 am
I don't know much, but if the fuel consumed during taxi was such a crippling problem that aircraft manufacturers would have to put heavy electric motors on their planes to taxi them around, wouldn't more airlines have their jets taxi around with only one engine on, say, as an interim mean of saving that fuel?
But I see them all lighting up all 2,3 or 4 burners right at the pushback...
oakmad
Wed Aug 03, 2005 6:14 am
Perhaps they'll put the motor in the wheel like they do for solar cars?
http://www.tip.csiro.au/Machines/papers/iwscem
I think its a great idea: no more "we're just waiting for a tug" announcements
Euclid
Wed Aug 03, 2005 6:18 am
Quoting Checkraiser (Reply 19):
All electric drives that I have ever seen locate the motor in a housing right on the wheel where it drives the wheel directly, although in some applications there may be gearing involved as well.
Up to 1999 I used to work as an earthmoving mechanic and did a lot of work on the huge mining dump trucks that uses diesel-electric propulsion. The diesel motor (V16 Cummins) would drive a generator that would in turn supply the power to the electric motors, one motor on each rear wheel, driving the wheel directly.
The only reason I have my doubts about using this type of arrangement in the nose gear is that I cannot think how the nose wheels can maintain enough traction on the tarmac to start pulling a plane weighing a couple of hundred tons without spinning, but I'm sure the clever people developing the system would have thought of that and know something that I don't.
Cheers all!
Euclid
oakmad
Wed Aug 03, 2005 6:30 am
As for traction control; well they've been doing it for years in with diesel/electric trains. Now obviously the scenario's are a little different but I'd estimate the technology is not. Even my car has 'traction control' these days. ABS was originally developed for aircraft so I'm sure they could adapt that somewhat.
 twocents
md80fanatic
Wed Aug 03, 2005 8:44 am
Where will a aircraft get the tremendous wattage necessary to run this taxi motor? I don't think batteries will do so well, as the current (charge rate of flow) requirements are STEEP. Like a railroad locomotive that uses it's diesel engines to run the mega generators used to drive the electric motors on the wheels. The aircraft that performs this function will need at least one (or possibly both) main engines running to produce the current needed.
I doubt any APU could produce the needed flow under most circumtances, they are designed for starting engines and running aux. systems...not tugging 400,000 lbs. around an airport.
