cgnnrw
Status Of Terminal E At CDG?
Sat Aug 06, 2005 6:01 am
I may be going through CDG in September and usually fly with AF to the US. Just curious what the current situation is with Terminal E?
A330 man.
Pihero
RE: Status Of Terminal E At CDG?
Sat Aug 06, 2005 7:09 am
The boarding building is -obviously- still closed but the checking hall is now half open.
You will use a bus, or an aerobus to join your plane.
The work on terminal E should start late this year or early 2006 :They will rebuild the rooftop with a steel structure, leaving the terminal shape the same as it was designed.
Expect end of construction late in 2007.
If you are interested, I have a PPpresentation to show how CDG 2 will wvolve until 2010.
Contrail designer
icarus75
Sat Aug 06, 2005 7:00 pm
Quoting Pihero (Reply 1):
I'm if you do not mind!!  Wink
Flying is amazing!
jouy31
Sat Aug 06, 2005 10:05 pm
I would be interested, too.  Smile
cgnnrw
Sun Aug 07, 2005 12:28 am
Thanks for the offer but I'm not in your area unfortunately. Will check out Terminal E when I go through in Sept.
A330 man.
yul332LX
Sun Aug 07, 2005 12:53 am
Quoting Jouy31 (Reply 3):
Same here.
Pihero, check your emails please  Wink
E volavo, volavo felice più in alto del sole, e ancora più su mentre il mondo pian piano spariva lontano laggiù ...
