sfo
UA DC10 Flying Under Golden Gate Bridge
Tue May 02, 2000 1:04 pm
In the 'Lighter Side' of this forum:
http://www.airliners.net/humor/UADC10GG.gif
there is a photo showing a United DC10 flying under the Golden Gate Bridge.
Can anybody let me know if:
1. This photo is real. Looks real to me shadows and all;
2. If this actually happened, what were the circumstances surrounding it -- like when this happened -- I'd be surprised if they even allowed this stunt using such a large aircraft.
Appreciate any information. Thank you.
VirginA340
RE: UA DC10 Flying Under Golden Gate Bridge
Tue May 02, 2000 1:09 pm
It would be even more amazing if it were a UAL 747-400 instead of a UAL DC-10
"FUIMUS"
Big777jet
Tue May 02, 2000 2:33 pm
This is not true! Fake and computer photo. FAA would not allowed commerical flying under any of bridges or even Archway in St. Louis. You cannot do that for maneuver flying through something like that.
aaron atp
Tue May 02, 2000 3:25 pm
some people are just too naive...
anyway I can assure you that a handful of GA aircraft and brazen pilots have flown under the golden gate bridge in the last two decades...
Cessna 4269D, Bay, altitude squawk lost, please check your transponder...
bay, 69D we'll cycle the xpdr
<2 minutes later...> Cessna 4269D, altitude indicates 2 thousand
69D
Samurai 777
Tue May 02, 2000 4:34 pm
I've seen a larger version of the same photo before! Unfortunately, I can't remember the site where I saw it. It's definitely a photo manipulation using a computer. These days, you can make some some incredible digital manipulations, if you're skilled enough.
The FAA certainly wouldn't allow this to happen! The Golden Gate Bridge is a large suspension bridge, so the air vortices generated by the DC-10 would've rocked the bridge big time like the Big One that Californians hope will never happen in their lives. People and cars would be knocked around and probably even fall nito the Bay. That is even if the DC-10 was going at a speed near the point of stalling, which I don't really know, but it must be at least 375 km/h (233 mph)! The DC-10 is a big and very heavy aircraft, that's why it can't fly as slowly as a smaller a/c like a Beechcraft 1900 or a Dash 8. Not to mention that the tail'd be ripped right off by getting caught on the bridge if the crew flew the plane too high above the water. That would be a serious and fiery accident, as the fuel tanks get torn apart and ignite. It's also a very serious hazard to shipping and smaller recreational boats if the plane was flying that low whether it was under the bridge or not.
Remember the film footage and pictures of the Tacoma Narrows Bridge in Washington State getting really whipped by high winds until it got ripped apart? This is one of the best known footage ever made of a bridge being damaged. And that's a pretty good idea of what''ll happen to the Golden gate, if the DC-10's tail got caught in the bridge, although it may not get really ripped apart by the wake vortices generated by the plane.
http://www.enm.bris.ac.uk/research/nonlinear/tacoma/tac09.gif
b744
Tue May 02, 2000 4:38 pm
You may be aware that when VS began flights to SFO, Richard Branson wanted to stage some sort of publicity stunt (which is normal for Virgin) and one idea that was floated was flying a 747 under the bridge. They ran some numbers and determined that it was actually possible, but they couldn't get approval. Hearsay has it that they were instead given permission to fly over the bridge at low altitude between the sticky - uppy things (pillars?) that support the cables......
turbulence
Tue May 02, 2000 11:35 pm
Cool pic!!
But just notice something:
The person who created this photo didn't know too much about airplanes, or just forgot something, which for me is the definitive proof of fake illusion:
This plane is flying without flaps. Maybe such a flight could be achieved at very low speed, but “clean” wing configuration is necessarily faster than the 375 km/h suggested by Samurai777.
By the way: the vortice generated by a DC10 or even a 747 would never cause any kind of problem to any people on the bridge or the bridge itself (if the airplane was flying with landing configuration). The speed at that moment is much lower than 300 km/h, even around just 250, and the vortices generated are very limited. So much, that I have been myself MANY times right below the belly of D10s, 340s and 747s landing at BCN at the exact point where the asphalt of rwy 25 begins. Even cylclists ride their bicycles there without any problem.
Best turbulences
Tue May 02, 2000 11:46 pm
Vortexes are the most dangerous at approach. They just dissolve before hitting the floor. Once, a 757 trailing vortex blew a small propeller aircraft out of the sky, which is why they now have to leave extra space behind a 757. The reason is that on large airliners, especially the 747, the airflow over the wing can actually reach MACH 1 on approach, while the plane moves at 250km/h. This is perfectly normal, and shows how efective the flaps are in accelerating the airflow above the aerofoil. But it would not harm the bridge.
PS: Last time I was in a big airliner, a 777, the speed at touchdown was 266 km/h, not 375!
chrisnh
Wed May 03, 2000 12:12 am
With Photoshop, you could put GE-90 engines on an elephant and it would appear 'real'.
Wed May 03, 2000 12:49 am
After looking closer I see another error. Turbulence writes that the DC10 flyes without flaps but then look at the shadow below the starboard wing, either it is flaps or the light comes from behind.
From
The Dane
OPNLguy
How About A 737 On An Aircraft Carrier?
Wed May 03, 2000 1:25 am
See:
http://www.southwest.com/about_swa/photos.html
and scroll down to the photo entitled, "You'll never believe...."
I swear this one is real and untouched. Elvis told me so....
turbulence
Wed May 03, 2000 1:31 am
To my above post, I forgot to make clear one simple point: the “flight level” of these airplanes over me (or the cyclists) when landing at BCN is for absolute sure hardly above 20-to-25 metres (60-to-75 ft. or so).
Best turbulences
RE:OPNLguy
Wed May 03, 2000 1:33 am
I think British and Air France should do the same thing and have a Concorde land on an aircraft carrier!
woodsboy
RE: RE:OPNLguy
Wed May 03, 2000 3:17 am
If anybody tried something like this and actually made it through without crashing they would all be in Federal Prison for the rest of their lives!
aaron atp
The Power Of Photoshop...
Wed May 03, 2000 3:46 am
it is unreleated but humorous....
aaron
OPNLguy
Never Mind Elian, Tell Us About The ATL Crane!
Wed May 03, 2000 4:54 am
Great pix, wasn't your white pick-up I hope...!
OPNLguy
RE: RE:OPNLguy
Wed May 03, 2000 4:56 am
Actually, I wouldn't mind having one cruising around so I could find a legal alternate when I needed one...
FDXmech
Wed May 03, 2000 5:13 am
If you get a chance watch the movie "30 Seconds Over
Tokyo" about the WW2 Doolittle raid. They fly a B25
under the Goldengate Bridge. Looked hairy.
The Rock?
Wed May 03, 2000 5:24 am
Hmm, seems a bit unreal, flying a DC10 under the Golden Gate. Check it out! NO traffic on the water.
Okay.. Maybe the DC10 is not real. But how about the 3-5 fighters (F-16??) in the movie "The Rock".
Personally I've read somewere that THEY are very real, and that the moviecompany got a special permit.
Anybody outthere have an opinion about that?? I mean, some of you might know a little more about it than me (no comments from big companys allowed).
Engelhardt
The Rock?
Wed May 03, 2000 8:23 pm
By the way!! Is it even possible to take such a sharp and focused picture of a fast flying object (DC10), when you are standing on the ground?? I mean, this picture can't have been taken by a tourist. Am I right??
Boeing727
Similar Stunt, But Real...
Thu May 04, 2000 1:00 am
Here are a couple of odd flying occasions:
1.)A private pilot in France flew his General Aviation Airplane through the Arc D'Triumph in Paris back in the 80's. I remeber seeing it on the news in Germany.
2,)Also in the 80's (late) a German pilot flew a Cessna through Soviet Defenses onto the Red Square in Moscow.
If anybody has additional information to add to these incidents, please do!!!
Boeing727
aaron atp
A Student
Thu May 04, 2000 2:26 am
If you knew anything about transonic flow or aerodynamics in general, you probably would not have written that.
b744
RE: Cessna In Red Square
Thu May 04, 2000 5:30 am
At the time when the German flew his Cessna into Red Square, the Soviet Government and the media reported that he had acted alone in penetrating Soviet defences. However it wasn't until some years later when the truth finally emerged. When Gorbachev first came to power, he did not believe he did not have the vital support of the top air force brass. So, he came up with a plan to remove them. He got the KGB to hatch this plan and they arranged the flight. They provided the pilot with a route map that bypassed Soviet air defence radar, ensuring that the pilot successfully made it to red square undetected. The fact that a foreign aircraft was able to penetrate USSR air space and land in the middle of the capital severely embarrassed the Air Force top brass, and the Air defence Commander Koldunov was forced to resign. Gorbachev appointed a new Commander (Dmitri Yazov) who was loyal to him, and he was able to govern in the knowledge that he had full support from all divisions of the military.
The German pilot Mathias Rust became something of a hero in West Germany. A popular West German T-shirt depicted a Cessna in Red Square with lettering above the picture that read: "International Airport, Rotor Platz" (Red Square).
