kaitak744
Fuel In The Tail Plane
Mon Aug 15, 2005 5:42 am
Is it possible to put fuel in the vertical stabilizers and tail of an aircraft? And do airlines do so? From what I heard, the vertical stabilizers on the A380 are bigger than the A310 wing. So that would be a great place or fuel and would give a significant range boost.
utapao
RE: Fuel In The Tail Plane
Mon Aug 15, 2005 5:44 am
Depending on the amount, it could sure wreak havoc on weight and balance!
Sawasdee khrab!
as739x
Mon Aug 15, 2005 5:46 am
That would create a aweful weight and balance issue as well as would create structural problems. The tremendous weight to make the tail strong enough would add just to much dead weight.
ASSFO
N766UA
Mon Aug 15, 2005 5:47 am
I could swear Boeing was putting fuel in the tail section of the 777LR. Maybe I'm imagining things?
PhilSquares
Mon Aug 15, 2005 5:49 am
The 744 has fuel in the horizontal stabilizer. IIRC, it's standard on the pax version and an option on the ERF.
Fly fast, live slow
fxra
Mon Aug 15, 2005 5:55 am
MD-11's have a tail tank in the horizontal stabs. It helps with inflight CG to keep the aircraft in the optimum flight profile. If you plan to depart with fuel back there, better load the nose up. And once in flight when the CG starts to move forward as fuel is transferrred out fo the tanks, the flight begins to burn more fuel as it no longer has aft CG thats more economical.
Visualize Whirled Peas
FI642
Mon Aug 15, 2005 9:11 am
The wet tail on MD11's is a great thing, as long as the fuel management system is working!
737MAX, Cool Planes for the Worlds Coolest Airline.
kaitak744
Mon Aug 15, 2005 12:13 pm
Well, it definately would increase range by alot. But thanks for the answers!
RupesNZ
Mon Aug 15, 2005 12:38 pm
If you refer to pg 37 of the 747 AIRPLANE RESCUE AND FIRE FIGHTING INFORMATION guide ( http://www.boeing.com/assocproducts/aircompat/arff/arff747.pdf )
The Boeing 747-400 Passenger and Freighter version have fuel tanks in the horizontal stabilisers of 3300 gallons, with a surge tank in the starboard stabilizer tip.
The 777 only has fuel in the wings and in the wing root area with the 200LR series with an addional 1850 gallon tank in the belly.
( http://www.boeing.com/assocproducts/aircompat/arff/arff777.pdf )
Rupert
RupesNZ
Mon Aug 15, 2005 12:40 pm
Quoting RupesNZ (Reply 8):
Oops, that should have been 747-400 Passenger and Combi versions!
Mainliner
Mon Aug 15, 2005 1:09 pm
The A310-300 also carries fuel in its horizontal stabilizer.
Every flight counts.
utapao
Mon Aug 15, 2005 1:30 pm
An appropriate amount of crow has been consumed!!!
I would never have believed that fuel in the tail would not have had an aircraft standing on its tail after lifting off.
Fortunately I said "could wreak havoc"... but guess that sounds like a cop-out.
Thanks for the info!!!
Sawasdee khrab!
purplebox
Mon Aug 15, 2005 8:10 pm
Quoting Kaitak744 (Thread starter):
Yes it is possible - but there needs to be a 'Fight Trim' computer that is responsible for pumping fuel around the aircraft's tanks so as to keep the center of gravity correct.
Next Flights:LHR-BOG,BOG-GYE,MDE-BOG-PTY,PTY-BOG-CTG,SMR-BOG-LHR - all on AV
maddy
Mon Aug 15, 2005 8:16 pm
Today I saw a documentation about LH´s A340-600 and the captain said that they can pump up to 6 tons of fuel into the vertical stabilizer to equilibrate the plane. I´m not sure but I guess it was like that.
vc10
Mon Aug 15, 2005 8:18 pm
The Super VC-10 had fuel in the Fin [vertical stabilizer ] and it had a flight trim computer called the Flight Engineer. It is a sad thing but very little is new
Be happy little vc10
BCAL
Mon Aug 15, 2005 8:25 pm
Quoting Vc10 (Reply 14):
and I am sure that so did the Trident 2 and later versions.
MOL on SRB's latest attack at BA: "It's like a little Chihuahua barking at a dying Labrador. Nobody cares."
