keesje
Airbus Has Begun The A380’s Flutter-test Campaign
Tue Aug 16, 2005 11:03 pm
Regulators impose requirements aimed at ensuring double-deck giant’s crashworthiness matches existing airliners
Flight International
The US Federal Aviation Administration and European Aviation Safety Agency are seeking to make Airbus prove that passengers’ chances of survival in an A380-800 crash are equal to or better than in any other airliner.
The FAA proposal notes the A380’s greater volume should allow the airframe to absorb more energy on impact, which could reduce the forces felt by passengers and increase their chances of surviving the crash.
Airbus has begun the A380’s flutter-test campaign, which it expects to complete within 10 or 15 flights. The trials will be flown at progressively higher speeds up to the ultra-large aircraft’s maximum of 375kt (690km/h)/Mach 0.96.
http://www.flightinternational.com/A...vivability%E2%80%99+test+goal.html
kc135topboom
RE: Airbus Has Begun The A380’s Flutter-test Campaign
Wed Aug 17, 2005 12:26 am
Quoting Keesje (Thread starter):
Mach 0.96? I thought the max Mach number for the A-380 is 0.86. But, it should easily be able to get to 375 KIAS, at and below FL290. Above FL290, 375 KIAS will be above Mach 0.86.
The A-380 should easily have the same or better crash survivability than any other modern airliner.
But, it's greater volumn (and weight and fuel capacity) would produce greater crash forces than, say a B-747-400 (given the same speed and other factors).
But, the greater size should spread any impact over a larger area. Thus spreading the impact and actually reducing impact forces on different sections while increasing it in other sections.
eatmybologna
Wed Aug 17, 2005 12:57 am
So, how do they test for this? They can't crash one into the ground obviously.
e-m-b
Isn't knowledge more than just the acquisition of information? Shouldn't the acquired information be correct?
Vasu
Wed Aug 17, 2005 1:45 am
Quoting Eatmybologna (Reply 2):
I was wondering the same...
OldAeroGuy
Wed Aug 17, 2005 2:55 am
Timing for the flutter testing is interesting. I know flutter clearance is one first things that Boeing does when flight testing a new model. The logic is that if structural changes are needed, they should be started as soon as possible to preserve the Certification date, if feasible. In addition, you should show that the airplane structure is OK for all parts of the flight envelope as you're never sure of the flight conditions you may encounter as you explore handling characteristics.
Starting flutter tests four months after first flight seems a bit late, but I'm not sure if this is an Airbus standard practice.
A350
Fri Aug 19, 2005 8:50 am
They can, but they probably won't do it  biggrin
Quoting KC135TopBoom (Reply 1):
That's a very important point. Actually, it makes the A380 unattractive for terrorists.
A350
Vasu
Fri Aug 19, 2005 4:03 pm
Quoting A350 (Reply 5):
Maybe, but think of all those people onboard ... eek!
Udo
Fri Aug 19, 2005 4:23 pm
Quoting Vasu (Reply 6):
Not worse than on Corsair or Japanese domestic B747s.
Udo
Me & You & a Plane Named Blue...
stealthpilot
Fri Aug 19, 2005 7:37 pm
The flutter test is an extremely important test. One method is to attach 'fluttering' appendages to the wing tips which cause major disturbances to the aerodynamics and flight control characteristics. It is amazing how something as small as they are can cause a huge aircraft to behave so sporadically.
-Nikhil
eP007
art
Fri Aug 19, 2005 7:49 pm
Just a query on the figures here:
Mach 1 at sea level = ca 760mph/1260kph
Mach 1 at 36000ft = ca 640mph/1025kph
Can't see 690kph equalling mach 0.96 at any service altitude. Also, would they actually test an airliner up to mach 0.96 - strange things start happening this close to mach 1, don't they?
cfalk
Fri Aug 19, 2005 8:02 pm
Quoting Art (Reply 9):
They are talking about indicated airspeed, which indicates far slower than true airspeed due to the thin air at high altitude.
Charles
