tsaord
What Cities Does American Serve From Midway?
Sun Aug 21, 2005 2:25 pm
question what cities does american airlines serve directly from chicago midway? i was trying to research it but i couldnt find anything i was looking for. thanks!
EddieDude
Sun Aug 21, 2005 2:31 pm
I am just guessing: Probably AA's DFW and MIA hubs and LGA.
Upcoming AM MEX-LAX 73H, VA LAX-MEL 77W.
COEWRNJ
Sun Aug 21, 2005 2:33 pm
I believe it is mainline to DFW and Eagle to LGA.
Venezuela747
Sun Aug 21, 2005 2:43 pm
I found 5 flights to DFW today and thats all
ROLL TIDE!!!
jfklganyc
Sun Aug 21, 2005 10:57 pm
They stopped LGA last Dec. It was 3 flights a day on Eagle.
PJ
md90fan
Sun Aug 21, 2005 11:37 pm
Dont they have ORD with a 757?? I saw it on Flytecomm one day
http://www.devanwells.blogspot.com/
FriendlySkies
Mon Aug 22, 2005 12:47 am
Are you serious? ORD-MDW with a 757? Wow talk about a scheduling mishap.
aa777flyer
Mon Aug 22, 2005 1:14 am
Quoting MD90fan (Reply 5):
It was likely repositioning a aircraft after a charter. AA flies the Chicago Whitesox, they usually leave from MDW, airplane is from ORD.
The TSA was created to make the post office look efficient!
CHI787ORD
Mon Aug 22, 2005 11:41 am
Whoever is flying this flight needs to discover the "L".  Smile
tsaord
Mon Aug 22, 2005 12:44 pm
Quoting JFKLGANYC (Reply 4):
i guess im not up to snuff on airplanes on the technical side. but that little plane can make it from here to nyc?? i thought all the wide body/757's went out there from here. learned something new lol
drerx7
Mon Aug 22, 2005 12:48 pm
Quoting Tsaord (Reply 9):
LOL--first off--LGA is not that far from MDW--what is it? Maybe 1:45 if that? COEX is running ERJs from Houston to California.
HOUSTON, TEXAS
MAH4546
With ease. Regional jets fly plenty of routes much longer than LaGuardia-Midway.
Narrowbodies like the A319, A320, and 73G fly many trans-continental flights. The longest domestic flight in the lower-48, MIA-SEA, is flown with a 737.
a.
Tornado82
Mon Aug 22, 2005 1:28 pm
CO flies OKC-EWR, that's a bit further than MDW-LGA, although CO does have those 145-XR's.  Smile
md90fan
Wed Aug 24, 2005 10:19 pm
Quoting Tornado82 (Reply 12):
Dont forget IAH-BFL and IAH-BOI!! and AE LAX-XNA
[Edited 2005-08-24 15:21:22]
access-air
Thu Aug 25, 2005 1:50 am
Im at work right now and checking my reservations computer, MDW service for AA, they fly 4 RTs between MDW and DFW only with MD-80s.....They used to fly the route with Fokker 100s until they went byebye....
In modern times that seems to be the only route they have flown from MDW since they originally pulled out and moved to OHare....Altho I do remember in the early 90s AA jumped into the MDW-DFW presumably to fill the void left by the just Bankrupt Midway Airlines. Back then they used 727-100s. The recent re-startup was in response to ATAs entry into the MDW-DFW market. ATA also flies about 5 times per day to DFW using 738s.
Access-Air
Remember, Wherever you go, there you are!!!!
