Braybuddy
How To Differentiate Between Take-off And Landing
Thu Aug 25, 2005 7:22 am
The 747 below is taking off, which I know from reading the caption. Without a caption, I am unable to tell if it's taking off or landing. What are the telltale signs for the non-flyers amongst us to show whether it is taking-off or landing, the angle of the flaps, the angle of the aircraft?
Photo © Sam Chui
Lando
RE: How To Differentiate Between Take-off And Landing
Thu Aug 25, 2005 7:26 am
Well, I am no expert, but one way you can tell is if the plane is still near the beginning of the runway its landing...no plane would be touching down that far down the runway...it would have to go around...
Leezyjet
Thu Aug 25, 2005 7:31 am
Smoke from the tyres is a tell tale sign of a take off or landing too !!.
 Smile
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
Richard28
Thu Aug 25, 2005 7:32 am
Another way to tell is to look at the position of the flaps.
For take off they are generally at about 5 degrees, whereas for landing they are lowered to around 30 degrees.
You can see on the UA photo posted that the flaps are only slightly lowered, as it is taking off.
Rich.
OPNLguy
Quoting Braybuddy (Thread starter):
Generally speaking, the flaps will be out much further on landing. Takeoff flap settings are usually lower than landing flap settings.
If slats and flaps are only partly extended, it's normally a takeoff. If they are close to fully extended, it's a landing.
satx
Thu Aug 25, 2005 7:47 am
Landings...
Flaps and smoke:
Photo © Erwin
Thrust reversers:
Photo © Chris Starnes
Take-off is similar but no smoke, less flaps, and no thrust reversers.
Obviously, there are exceptions to every rule thanks to possible MX issues, pilot error, bizarre weather conditions, funny camera settings, and post-processing. However, these are some general guidelines you can use.
[Edited 2005-08-25 00:53:11]
Open Season on Consumer Protections is Just Around the Corner...
flanker
Thu Aug 25, 2005 9:12 am
The easiest way is the flap setting/TR.
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an unlicensed pharmacist
Braybuddy
Thu Aug 25, 2005 9:16 am
Thanks guys. It's looks as if the tyres on one of the wheels are barely touching the runway so I wouldn't expect the absence of smoke to indicate anything here. And don't the thrust reversers only come on when all the wheels have made contact with the runway?
satx
Thu Aug 25, 2005 10:41 am
Quoting Braybuddy (Reply 8):
Yes.
I guess when you said "the non-flyers amongst us," you REALLY meant it?!  Smile
SkyexRamper
Fri Aug 26, 2005 2:39 am
UP and DOWN...need I say more!?!??
Good Luck to all Skyway Pilots! It's been great working with you!
Fri Aug 26, 2005 2:45 am
Not All.There are exceptions.
The Position of the TE Flaps around 1,2,5 for T/O & 30 or 40 for landing normally.
Check for T/R deployment on Landing.
Check for Speedbrake Deployment on landing.
regds
MEL
satx
Fri Aug 26, 2005 3:03 am
Quoting HAWK21M (Reply 11):
Wow. I never knew of (and never experienced to my knowledge) any cases where thrust reversers were intentionally in operation while the plane was still in the air.
1. If only the main landing gear were on the runway, wouldn't deploying the thrust reversers risk slamming the nose gear too hard against the runway?
2. If none of the landing gear had yet made contact, wouldn't deploying the thrust reversers risk the loss of smooth and continued control over the plane itself?
I guess what I'm really asking is "What are the exceptions?"  Smile
lehpron
Fri Aug 26, 2005 3:06 am
Two words: flaps setting.
Most large airplanes takeoff with some flaps and land with full. Just look at the angle they 'flap' down, if it is steep, it it about to touch down. It's the only way I could tell. But if it were crusing at low speed and needed it's takeoff flaps setting, I would not be able to tell.
Olympus69
Fri Aug 26, 2005 3:47 am
Quoting SATX (Reply 12):
You will never see thrust reversers activated in the air on planes with engines below the wings. A rearward force below the center of gravity would cause a downward force on the nose. However, with rear engined planes the thrust is closer to the c. of g. and has less effect on the pitching moment. Even so, the only aircraft that regularly employs thrust reversers in the air is the Russian IL-62. There could be others but that plane is the only one I personally seen doing this. Here's one example
Photo © Red-phoenix AirPics
Fri Aug 26, 2005 3:49 am
Photo © Andy Martin - AirTeamImages
Photo © Johan Ljungdahl
Heard of the IL62.
regds
MEL
Fri Aug 26, 2005 3:53 am
Quoting Olympus69 (Reply 14):
Other examples of planes that can use idle T/R in the air:
C-17
VC-10 (IIRC)
Concorde
DC-8
kilavoud
Fri Aug 26, 2005 4:11 am
When taking off the incline of the plane is much steeper than when landing.
Cheers. Kilavoud.
satx
Fri Aug 26, 2005 4:44 am
Mucho THANKS Olympus69, HAWK21M, & Starlionblue!
Quoting Kilavoud (Reply 17):
This doesn't really seem like a consistent rule to me, even if just based on the photos here on A.net.
bond007
Fri Aug 26, 2005 9:16 am
SO....the true answer is unless you can see the location on the runway, there is no way of telling 100% in this configuration!
Might not use thrust reversers - might take-off at lower angle-of-attack - might land with only small amount of flaps....etc. etc.
Of course, if you see smoke, or flaps are fully deployed, or you see thrust reversers - it's landing.
Jimbo
Halophila
Fri Aug 26, 2005 4:19 pm
I believe at least one accident (an AC DC-8) occurred when T/R were deployed while the aircraft was still airborne above the runway, causing a hard landing, forcing a go-around, but the damage to the aircraft caused the plane to unfortunately crash while on repeat descent (I believe with all hands lost). Of course there's also the Lauda 767 which crashed when one T/R deployed at altitude, again sadly resulting in the loss of the aircraft and all souls aboard. Albeit the Lauda accident was not during T/O or landing.
Flown on 707, 717, 727, 732 733 734 735 73G 738 739 741 742 743 744 74SP 757 753 762 763 772 773 77W D10 DC9 M11 M80 M87
Olympus69
Sat Aug 27, 2005 12:19 am
Quoting Halophila (Reply 20):
Not true. It was spoilers being deployed that caused the hard landing, not thrust reversers.
spacecadet
Sat Aug 27, 2005 1:02 am
Quoting SATX (Reply 18):
It is a general rule, though, like all the other rules posted so far. Most planes will take off between 5 and 10 degrees and land almost flat (usually 2 or 3 degrees).
Of course, if you see a shot taken *during* takeoff rotation, it might look closer to a landing attitude, but then to think it was a landing you would expect to see trailing smoke because the wheels would be on the ground, which would rule that out. Plus, there'd still be the flaps to look at.
The shot at the top, I could tell was a takeoff just from the angle. 747's don't generally land with such an extreme angle of attack (that'd be about a 15 degree AOA, by the looks of it).
TimRees
Sat Aug 27, 2005 6:59 am
I think you can 'just tell' somehow
That UA 747 just looks like it's taking off....the angle of attack is just too steep and there are no flaps worth talking about.
If this aircraft was landing a tail strike would be a strong possibility.
Perhaps it's just that I've watched thousands of take offs/landings and you jet get a feel for it.
Of course if something isn't set up right a landing can look like a take off and vv!
